11-13-2017, 09:52 | #1 (permalink) |
Junior Member Join Date: Feb 2016
Member: 2539056 Status: Offline Thanks Meter: 3 | Easy-JTAG eMMC HTC problem? I have had one of these before where it wasn't successful. The partition information does not get read in and it says: CMD Pullup Level:1722 mV CMD Active Level:1794 mV eMMC Device Information EMMC CID : 65646F4D204D4F5212A0000006154444 EMMC CSD : D07FFF320F59007FF6DB80001E40001C EMMC Manufacturer ID: 0065 , OEM ID: 646F EMMC Date: 04/2017 Rev.0xa0 EMMC NAME: M MOR , S/N: 1557 EMMC ROM1 (Main User Data) Capacity: 2095982 MB EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Extended CSD rev 1.5 (MMC 4.41) Boot configuration [PARTITION_CONFIG: 0x78] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x78. Backup saved: M MOR_ 1557_20171001_0844.extcsd Searching for partition tables... Partitioning not detected... Done. ALSO the below when I select more debug data: EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Extended CSD rev 1.5 (MMC 4.41) Boot configuration [PARTITION_CONFIG: 0x78] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x78. Backup saved: M MOR_ 1557_20171001_0844.extcsd ============================================= Extended CSD rev 1.5 (MMC 4.41) ============================================= Card Supported Command sets [S_CMD_SET: 0x01] HPI Features [HPI_FEATURE: 0x01]: implementation based on CMD13 Background operations support [BKOPS_SUPPORT: 0x00] Background operations status [BKOPS_STATUS: 0x00] 1st Initialisation Time after programmed sector [INI_TIMEOUT_AP: 0x00] Power class for 52MHz, DDR at 3.6V [PWR_CL_DDR_52_360: 0x00] Power class for 52MHz, DDR at 1.95V [PWR_CL_DDR_52_195: 0x00] Minimum Performance for 8bit at 52MHz in DDR mode: [MIN_PERF_DDR_W_8_52: 0x00] [MIN_PERF_DDR_R_8_52: 0x00] TRIM Multiplier [TRIM_MULT: 0x00] Secure Feature support [SEC_FEATURE_SUPPORT: 0x15] Secure Erase Multiplier [SEC_ERASE_MULT: 0x00] Secure TRIM Multiplier [SEC_TRIM_MULT: 0x00] Boot Information [BOOT_INFO: 0x01] Device supports alternative boot method Boot partition size [BOOT_SIZE_MULTI: 0x10] Access size [ACC_SIZE: 0x06] High-capacity erase unit size [HC_ERASE_GRP_SIZE: 0x01] High-capacity erase timeout [ERASE_TIMEOUT_MULT: 0x00] Reliable write sector count [REL_WR_SEC_C: 0x08] High-capacity W protect group size [HC_WP_GRP_SIZE: 0x01] Sleep current (VCC) [S_C_VCC: 0x00] Sleep current (VCCQ) [S_C_VCCQ: 0x00] Sleep/awake timeout [S_A_TIMEOUT: 0x00] Sector Count [SEC_COUNT: 0x003ab800] Minimum Write Performance for 8bit: [MIN_PERF_W_8_52: 0x00] [MIN_PERF_R_8_52: 0x00] [MIN_PERF_W_8_26_4_52: 0x00] [MIN_PERF_R_8_26_4_52: 0x00] Minimum Write Performance for 4bit: [MIN_PERF_W_4_26: 0x00] [MIN_PERF_R_4_26: 0x00] Power classes registers: [PWR_CL_26_360: 0x00] [PWR_CL_52_360: 0x00] [PWR_CL_26_195: 0x00] [PWR_CL_52_195: 0x00] Partition switching timing [PARTITION_SWITCH_TIME: 0x00] Out-of-interrupt busy timing [OUT_OF_INTERRUPT_TIME: 0x00] Card Type [CARD_TYPE: 0x03] HS eMMC @52MHz - at rated device voltage(s) CSD structure version [CSD_STRUCTURE: 0x02] Command set [CMD_SET: 0x00] Command set revision [CMD_SET_REV: 0x00] Power class [POWER_CLASS: 0x00] High-speed interface timing [HS_TIMING: 0x00] Erased memory content [ERASED_MEM_CONT: 0x00] Boot configuration bytes [PARTITION_CONFIG: 0x78] No access to boot partition Boot config protection [BOOT_CONFIG_PROT: 0x00] Boot bus Conditions [BOOT_BUS_CONDITIONS: 0x00] High-density erase group definition [ERASE_GROUP_DEF: 0x00] Boot write protection status registers [BOOT_WP_STATUS]: 0x00 Boot Area Write protection [BOOT_WP]: 0x00 Power ReadOnly locking: possible Permanent ReadOnly locking: possible Read Only lock status: not locked User area write protection register [USER_WP]: 0x00 FW configuration [FW_CONFIG]: 0x00 RPMB Size [RPMB_SIZE_MULT]: 0x01 Write reliability setting register [WR_REL_SET]: 0x00 Write reliability parameter register [WR_REL_PARAM]: 0x00 Enable background operations handshake [BKOPS_EN]: 0x00 H/W reset function [RST_N_FUNCTION]: 0x00 HPI management [HPI_MGMT]: 0x00 Partitioning Support [PARTITIONING_SUPPORT]: 0x03 Device support partitioning feature Device can have enhanced tech. Max Enhanced Area Size [MAX_ENH_SIZE_MULT]: 0x000100 Partitions attribute [PARTITIONS_ATTRIBUTE]: 0x00 Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 General Purpose Partition Size [GP_SIZE_MULT_4]: 0x000000 [GP_SIZE_MULT_3]: 0x000000 [GP_SIZE_MULT_2]: 0x000000 [GP_SIZE_MULT_1]: 0x000000 Enhanced User Data Area Size [ENH_SIZE_MULT]: 0x000000 Enhanced User Data Start Address [ENH_START_ADDR]: 0x000000 Bad Block Management mode [SEC_BAD_BLK_MGMNT]: 0x00 Done. There are a couple of other weird things on this one: 1. The NAND only ready for 128MB then stops with a read timeout error. 2. The data itself (hex) contains only "ER 18" and then the rest of a sector is zeros. 3. The fact that a previous case on this model came up as the exact same (even device serial number) and did the exact same, could it be something with the SK-Hynix chips that they are protected from being read? If this is posted in the wrong place sorry. |
11-14-2017, 00:37 | #2 (permalink) | |
Freak Poster Join Date: Sep 2009 Location: Indonesia
Member: 1112585 Status: Offline Sonork: 100.1645028 Thanks Meter: 91 | you have bad connection, bad voltage, or bad EMMC. Quote:
The Following User Says Thank You to pai_d For This Useful Post: |
03-12-2018, 11:06 | #4 (permalink) |
Member: 2539056 Status: Offline Thanks Meter: 3 | Hi krillekrokodil, I had to conclude this one as a dead eMMC, it may have been the eMMC that died, I may have applied too much heat to the device, impossible to say exactly what. |
