04-17-2015, 17:29 | #1 (permalink) |
Product Supporter Join Date: Mar 2005 Location: China
Member: 129885 Status: Offline Sonork: 100:1603514 Thanks Meter: 6,202 | Easy-JTAG HOT Update. v1.9.1.0. Repair dead EMMC KMVYL000LM-B503!! First in World Improved Samsung eMMC firmware update protocol Added Samsung eMMC firmwares for new eMMCs:
STEP BY STEP MANUAL HERE Added NEW eMMC TP pinouts (Look inside sw folder: /EMMC TP PINOUTS) Added via JTAG:
Added via eMMC DIRECT(ISP)
P.S. KMVYL000LM Repair solution are waiting for Advanced Copy'n'Pasters. P.P.S This solution are made in one day and free as every Z3X Update last 10 years. Last edited by blang; 04-17-2015 at 20:23. |
The Following 27 Users Say Thank You to NoName® For This Useful Post: |
04-17-2015, 18:56 | #2 (permalink) |
Crazy Poster Join Date: Feb 2009 Location: Myanmar
Member: 983242 Status: Offline Sonork: 100.1660072:om Thanks Meter: 3 | nice update sir. im using z3x box very use full this box. please update sandisk eMMC firmware update too |
The Following 2 Users Say Thank You to omshan For This Useful Post: |
04-17-2015, 19:16 | #3 (permalink) |
No Life Poster Join Date: Feb 2010 Location: india. kerala.
Member: 1245320 Status: Offline Sonork: 100.1612126 Thanks Meter: 140 | with out remoove emmc ic solution need. its hard .no more doing people..and emmc socket no have...when remoove eemc damege coming more..... |
The Following 5 Users Say Thank You to rasheedc007 For This Useful Post: |
04-17-2015, 19:20 | #4 (permalink) | |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,638 | Quote:
if this hard for you, then buy new emmc and solder inside(this is very easy). no more words.!!! | |
The Following 3 Users Say Thank You to blang For This Useful Post: |
04-17-2015, 19:29 | #5 (permalink) |
Freak Poster Join Date: May 2010
Member: 1306306 Status: Offline Sonork: 240888 Thanks Meter: 36 | Help team.. Running:SAMSUNG: eMMC firmware update... Confirmed eMMC Part Number: KMVYL000LM-B503 Z3X EasyJtag Software ver. 1.9.1.0 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: xxx, ,FW Ver.: 01.52 CMD Pullup Level:2134 mV CMD Active Level:2609 mV Setup firmware update mode, wait 2..30 sec... Success! Sending eMMC firmware... Success! Verifying eMMC firmware... Success! Flashing eMMC firmware... Success! Repairing eMMC CID... Now Reconnect all eMMC Lines [POWER, CMD, CLK, DAT0]! Do it until progress bar is moving (20 sec timeout)! Can't init device, Reason: OCR Ready Timeout Error [Check VCC or eMMC DEAD] Done. |
04-17-2015, 19:36 | #6 (permalink) | |
The Following User Says Thank You to blang For This Useful Post: |
04-17-2015, 19:55 | #8 (permalink) |
No Life Poster Join Date: Jan 2008 Location: Under the Sky
Member: 678886 Status: Offline Sonork: 100.1661586 Thanks Meter: 172 | mr blang tnx for good update but: 1-please change device selection drop box font to smaller size i cant see complete htc modes 2-and please make application save phone model on exit everytime when exiting application forgets last phone model |
04-17-2015, 20:03 | #9 (permalink) | |
Member: 129885 Status: Offline Sonork: 100:1603514 Thanks Meter: 6,202 | Quote:
Reconnect not after 20 sec !!! Reconnect during progress bar is moving, then wait fw update complete success. When don't reconnect before progress bar complete 20 sec timeout, CID write fail and eMMC name 000000, but operable. "Now Reconnect all eMMC Lines [POWER, CMD, CLK, DAT0]! Do it until progress bar is moving (20 sec timeout)!" Best Regards | |
04-17-2015, 20:17 | #11 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi KMVYL000LM-B503 Work Perfectly : Running:SAMSUNG: eMMC firmware update... EMMC NAME: VYL00M Z3X EasyJtag Software ver. 1.9.0.6 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: 0707080F587D5F84, ,FW Ver.: 01.52 CMD Pullup Level:2124 mV CMD Active Level:2691 mV Setup firmware update mode, wait 2..30 sec... Success! Sending eMMC firmware... Success! Verifying eMMC firmware... Success! Flashing eMMC firmware... Success! Repairing eMMC CID... Now Reconnect all eMMC Lines [POWER, CMD, CLK, DAT0]! Do it until progress bar is moving (20 sec timeout)! Success! eMMC firmware is updated now! Please reconnect all eMMC lines before next operation! Please don't forget to repair extCSD from backup! Please don't forget to configure BOOT sizes! Done. |
The Following 5 Users Say Thank You to BABAK NURI For This Useful Post: |
04-17-2015, 20:19 | #12 (permalink) | |
Member: 1306306 Status: Offline Sonork: 240888 Thanks Meter: 36 | Quote:
but still the same, I wait after that, until the progress bar move is completed (20 seconds) Unable to init the device, Reason: OCR errors Ready Timeout [Check VCC or eMMC OFF] Done. whether the chip may have been damaged in total? | |
04-17-2015, 20:22 | #13 (permalink) | |
If can't read Smart Report this eMMC can not be recovered. Typically 95% damaged chips can be recovered. Thanks Last edited by NoName®; 04-17-2015 at 20:32. | |
04-17-2015, 20:42 | #14 (permalink) | |
after failed then not connected anymore : Z3X EasyJtag Software ver. 1.9.1.0 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: xxx, ,FW Ver.: 01.52 CMD Pullup Level:2114 mV CMD Active Level:2516 mV Can't init device, Reason: OCR Ready Timeout Error [Check VCC or eMMC DEAD] Done. then I did connect a test point again, detected 0000 : Z3X EasyJtag Software ver. 1.9.1.0 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: xxx, ,FW Ver.: 01.52 CMD Pullup Level:2124 mV CMD Active Level:2619 mV eMMC Device Information EMMC CID : 150100303030303030002010021200E6 EMMC CSD : D02701320F5903FFF6DBFFE796404052 EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 00/2013 Rev.0x0 EMMC NAME: 000000 , S/N: 537920018 EMMC NAME (HEX): 30303030303000 EMMC ROM1 (Main User Data) Capacity: 8192 MB EMMC ROM2 (Boot Partition 1) Capacity: 1024 kB EMMC ROM3 (Boot Partition 2) Capacity: 1024 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 1024 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD rev 1.5 (MMC 4.41) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. Backup saved: 000000_ 537920018_20150306_0234.extcsd Done. smart report the results of the current condition of 0000 : Running:SAMSUNG: Read S.M.A.R.T Report... Z3X EasyJtag Software ver. 1.9.1.0 Skip loading eMMC Addon Firmware CMD Pullup Level:1155 mV CMD Active Level:1650 mV Reading S.M.A.R.T Can't init device, Reason: CARD Ready Timeout Error Done. log before updating the firmware : Z3X EasyJtag Software ver. 1.9.1.0 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: xxx, ,FW Ver.: 01.52 CMD Pullup Level:2124 mV CMD Active Level:2588 mV eMMC Device Information EMMC CID : 15010056594C30304D198ED776117E30 EMMC CSD : D02701320F5903FFF6DBFFEF8A404066 EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 07/2011 Rev.0x19 EMMC NAME: VYL00M , S/N: 2396485137 EMMC NAME (HEX): 56594C30304D00 EMMC ROM1 (Main User Data) Capacity: 15028 MB EMMC ROM2 (Boot Partition 1) Capacity: 512 kB EMMC ROM3 (Boot Partition 2) Capacity: 512 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD rev 1.5 (MMC 4.41) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. Backup saved: VYL00M_2396485137_20150306_0240.extcsd Done. Running:SAMSUNG: Read S.M.A.R.T Report... Z3X EasyJtag Software ver. 1.9.1.0 Skip loading eMMC Addon Firmware CMD Pullup Level:2124 mV CMD Active Level:2588 mV Reading S.M.A.R.T S.M.A.R.T Ver. 0 , Card Error mode : Normal Super Block size : 0x00400000 (4194304 bytes) Super Page size : 0x00008000 (32768 bytes) Optimal Write size : 0x00008000 (32768 bytes) Read Reclaim count : 0 Optimal TRIM size : 0x00040000 (262144 bytes) Total Number of banks : 2 Initial bad blocks per bank : 6,7,0,0 Runtime bad blocks per bank : 1,1,0,0 Reserved blocks left per bank : 134,133,0,0 All Erase counts (min,avg,max): 0,3167,65535 SLC Erase counts (min,avg,max): 0,24099,65535 MLC Erase counts (min,avg,max): 803,950,6402 S.M.A.R.T Report Done. after the last failed firmware update like this : Z3X EasyJtag Software ver. 1.9.1.0 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: 0800B006F662B313, ,FW Ver.: 01.52 CMD Pullup Level:2114 mV CMD Active Level:2516 mV Can't init device, Reason: OCR Ready Timeout Error [Check VCC or eMMC DEAD] Done. | |
The Following User Says Thank You to alanic For This Useful Post: |
04-17-2015, 20:58 | #15 (permalink) | |
Your eMMC was working before firmware update ? Did you disconnect TP after 000000 detection, before start firmware update? Thanks Last edited by NoName®; 04-17-2015 at 21:09. | |
