04-18-2015, 11:59 | #35 (permalink) |
Product Supporter Join Date: May 2011
Member: 1569669 Status: Offline Thanks Meter: 257 | Hi, Try version EasyJtag_Release_v1.9.1.1.exe from shell. If still can't repair eMMC, means another problem (not eMMC firmware). This solution tested 100% with corrupted eMMC firmware. Best Regards Last edited by vikboston; 04-18-2015 at 12:23. |
The Following User Says Thank You to vikboston For This Useful Post: |
04-18-2015, 14:40 | #37 (permalink) |
Freak Poster Join Date: Jan 2005 Location: iran-tehran Age: 42
Member: 110950 Status: Offline Thanks Meter: 29 | I TEST KMSJS000LM-B308 BUT i can't update it's firmware after disconnect tp i make tp after that emmc detect as name:0000 after that i want to repair emmc firmware with disconnected tp but when i fill product name manualy confirm key not work |
04-18-2015, 18:59 | #39 (permalink) | |
Member: 1569669 Status: Offline Thanks Meter: 257 | Quote:
Supported confirm name for SJS00M is KMSJS000KM-B308 or KMSJS000KM You can simply type KMSJS000KM-B308 then confirm and your SJS00M will be updated. To see supported confirm eMMC part numbers open file /eMMC Firmware/FW_CFW.bin with some text editor, but don't modify this file! Best Regards Last edited by vikboston; 04-18-2015 at 21:24. | |
04-18-2015, 19:23 | #40 (permalink) | |
Freak Poster Join Date: Dec 2012 Location: UFI#Wellcome Worlwide UFiXers
Member: 1853929 Status: Offline Sonork: 1653495 Thanks Meter: 426 | Quote:
Thanks EasyJtag Team, for in minute Amazing Update... Code: Z3X EasyJtag Software ver. 1.9.1.1 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: 0D00801C54A1B11E, ,FW Ver.: 01.52 CMD Pullup Level:2670 mV CMD Active Level:2753 mV eMMC Device Information EMMC CID : 150100303030303030002010021200E6 EMMC CSD : D02701320F5903FFF6DBFFE796404052 EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 00/2013 Rev.0x0 EMMC NAME: 000000 , S/N: 537920018 EMMC NAME (HEX): 30303030303000 EMMC ROM1 (Main User Data) Capacity: 8192 MB EMMC ROM2 (Boot Partition 1) Capacity: 1024 kB EMMC ROM3 (Boot Partition 2) Capacity: 1024 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 1024 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD rev 1.5 (MMC 4.41) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. Backup saved: 000000_ 537920018_20150300_0107.extcsd Done. Running:SAMSUNG: eMMC firmware update... Confirmed eMMC Part Number: KMVYL000LM Z3X EasyJtag Software ver. 1.9.1.1 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: 0D00801C54A1B11E, ,FW Ver.: 01.52 CMD Pullup Level:2670 mV CMD Active Level:2753 mV Setup firmware update mode, wait 2..30 sec... Success! Sending eMMC firmware... Success! Verifying eMMC firmware... Success! Flashing eMMC firmware... Success! Repairing eMMC CID... Now Reconnect all eMMC Lines [POWER, CMD, CLK, DAT0]! Do it until progress bar is moving (20 sec timeout)! Success! eMMC firmware is updated now! Please reconnect all eMMC lines before next operation! Please don't forget to repair extCSD from backup! Please don't forget to configure BOOT sizes! Done. Z3X EasyJtag Software ver. 1.9.1.1 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: 0D00801C54A1B11E, ,FW Ver.: 01.52 CMD Pullup Level:2660 mV CMD Active Level:2753 mV eMMC Device Information EMMC CID : 15010056594C30304D194DEE017A11D2 EMMC CSD : D02701320F5903FFF6DBFFEF8A404066 EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 01/2014 Rev.0x19 EMMC NAME: VYL00M , S/N: 1307443578 EMMC NAME (HEX): 56594C30304D00 EMMC ROM1 (Main User Data) Capacity: 15028 MB EMMC ROM2 (Boot Partition 1) Capacity: 512 kB EMMC ROM3 (Boot Partition 2) Capacity: 512 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD rev 1.5 (MMC 4.41) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. Backup saved: VYL00M_1307443578_20150300_0108.extcsd Done. | |
04-19-2015, 23:11 | #41 (permalink) | |
Freak Poster Join Date: May 2010
Member: 1306306 Status: Offline Sonork: 240888 Thanks Meter: 36 | Quote:
thanks success and tested with other emmc : ============================== Running:SAMSUNG: eMMC firmware update... EMMC NAME: VYL00M Z3X EasyJtag Software ver. 1.9.1.0 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: xxx, ,FW Ver.: 01.52 CMD Pullup Level:2134 mV CMD Active Level:2712 mV Setup firmware update mode, wait 2..30 sec... Success! Sending eMMC firmware... Success! Verifying eMMC firmware... Success! Flashing eMMC firmware... Success! Repairing eMMC CID... Now Reconnect all eMMC Lines [POWER, CMD, CLK, DAT0]! Do it until progress bar is moving (20 sec timeout)! Success! eMMC firmware is updated now! Please reconnect all eMMC lines before next operation! Please don't forget to repair extCSD from backup! Please don't forget to configure BOOT sizes! Done. ============================== | |
04-20-2015, 21:54 | #43 (permalink) | |
Some eMMCs write problem can be fixed with eMMC Firmware Update. Also you dont need TP if ayour eMMC is not in OCR Ready Timeout condition. Best Regards | |
04-20-2015, 22:10 | #44 (permalink) |
Member: 1569669 Status: Offline Thanks Meter: 257 | Hi, New software revision EasyJtag_Release_v1.9.1.2.exe available via shell. Changes: -fixed critical bugs in FW_CFG.bin (KMSJS00KA, KMSJS00KM confirm bug) -fixed eMMC name log for HYNIX eMMC (empty eMMC name for Hynix in log) -added new /eMMC TP Pinouts/eMMC_TP_TYPE_4.jpg Best Regards |
