Old 07-31-2013, 11:59   #1 (permalink)
s1emens's Avatar
Member: 40602
Thanks Meter: 118
Easy Jtag N7100 eMMC repair
is this log correct?
EasyJtag Suite ver.: 1.0.52.0 started.
Operating system ver.: Windows NT 6.2 (build 9200).
Successefuly connected to box on COM41
Box S/N: xxxxxxxxxxxx, ,FW Ver.: 01.47
Box Working Mode: JTAG Box.
Box Drivers version: 3.0.0.0, are OK
Z3X Card Serial : xxxxxxxxx
Z3X Card Version : 22
Z3X Card Activation [JTAG] : 1
Resources ver. : MainRC ver.OCD040Z001 (C)2012 z3x-team.com
Box S/N: xxxxxxxxxxxxxx, ,FW Ver.: 01.47
Loading eMMC Addon Firmware...
CMD Pullup Level:1650 mV
CMD Active Level:2330 mV
EMMC CID 1501003030303030300020110726589D
EMMC CSD 902701320F5903FFF6DBFFEF8A404023
EMMC Manufactorer ID: 15
EMMC OEM ID: 0100
EMMC Date: 05/2005 FW rev.0x0 HW rev.0x0
EMMC Serial #: 537986854
EMMC NAME: 000000
EMMC Capacity: 16384 MB (High Density Card)
Extended CSD rev 1.5 (MMC 4.41)
Card Supported Command sets [S_CMD_SET: 0x01]
HPI Features [HPI_FEATURE: 0x03]:
implementation based on CMD12
Background operations support [BKOPS_SUPPORT: 0x01]
Background operations status [BKOPS_STATUS: 0x00]
TRIM Multiplier [TRIM_MULT: 0x01]
Secure Feature support [SEC_FEATURE_SUPPORT: 0x15]
Secure Erase Multiplier [SEC_ERASE_MULT: 0x04]
Secure TRIM Multiplier [SEC_TRIM_MULT: 0x07]
Boot Information [BOOT_INFO: 0x07]
Device supports alternative boot method
Device supports dual data rate during boot
Device supports high speed timing during boot
Boot partition size [BOOT_SIZE_MULTI: 0x04]
Access size [ACC_SIZE: 0x08]
High-capacity erase unit size [HC_ERASE_GRP_SIZE: 0x01]
High-capacity erase timeout [ERASE_TIMEOUT_MULT: 0x01]
Reliable write sector count [REL_WR_SEC_C: 0x01]
High-capacity W protect group size [HC_WP_GRP_SIZE: 0x90]
Sleep current (VCC) [S_C_VCC: 0x07]
Sleep current (VCCQ) [S_C_VCCQ: 0x07]
Sleep/awake timeout [S_A_TIMEOUT: 0x13]
Sector Count [SEC_COUNT: 0x02000000]
Partition switching timing [PARTITION_SWITCH_TIME: 0x01]
Out-of-interrupt busy timing [OUT_OF_INTERRUPT_TIME: 0x01]
Card Type [CARD_TYPE: 0x07]
CSD structure version [CSD_STRUCTURE: 0x02]
Command set [CMD_SET: 0x00]
Command set revision [CMD_SET_REV: 0x00]
Power class [POWER_CLASS: 0x00]
High-speed interface timing [HS_TIMING: 0x00]
Erased memory content [ERASED_MEM_CONT: 0x00]
Boot configuration bytes [PARTITION_CONFIG: 0x00]
Not boot enable
No access to boot partition
Boot config protection [BOOT_CONFIG_PROT: 0x00]
Boot bus Conditions [BOOT_BUS_CONDITIONS: 0x00]
High-density erase group definition [ERASE_GROUP_DEF: 0x00]
Boot write protection status registers [BOOT_WP_STATUS]: 0x00
Boot Area Write protection [BOOT_WP]: 0x00
Power ReadOnly locking: possible
Permanent ReadOnly locking: possible
Read Only lock status: not locked
User area write protection register [USER_WP]: 0x00
FW configuration [FW_CONFIG]: 0x00
RPMB Size [RPMB_SIZE_MULT]: 0x01
Write reliability setting register [WR_REL_SET]: 0x1f
Write reliability parameter register [WR_REL_PARAM]: 0x05
Enable background operations handshake [BKOPS_EN]: 0x00
H/W reset function [RST_N_FUNCTION]: 0x00
HPI management [HPI_MGMT]: 0x00
Partitioning Support [PARTITIONING_SUPPORT]: 0x03
Device support partitioning feature
Device can have enhanced tech.
Max Enhanced Area Size [MAX_ENH_SIZE_MULT]: 0xd38000
Partitions attribute [PARTITIONS_ATTRIBUTE]: 0x00
Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00
General Purpose Partition Size
[GP_SIZE_MULT_4]: 0x000000
[GP_SIZE_MULT_3]: 0x000000
[GP_SIZE_MULT_2]: 0x000000
[GP_SIZE_MULT_1]: 0x000000
Enhanced User Data Area Size [ENH_SIZE_MULT]: 0x000000
Enhanced User Data Start Address [ENH_START_ADDR]: 0x000000
Bad Block Management mode [SEC_BAD_BLK_MGMNT]: 0x00
Box S/N: 0505090F25BD93C3, ,FW Ver.: 01.47
CMD Pullup Level:1629 mV
CMD Active Level:2320 mV
EMMC OEM ID: 0100
EMMC NAME: 000000
Not boot enable
it seems eMMC name is 00000 is this means eMMC damaged???
thanks
br,
s1emens
The Following User Says Thank You to s1emens For This Useful Post:
Old 08-02-2013, 10:16   #2 (permalink)
Member: 592636
Thanks Meter: 674
whats ur problem this time if u have same problem before writting emmc files i think emmc is damage becuase:
EMMC NAME: 000000
Old 08-02-2013, 10:52   #3 (permalink)
Ifonefreak's Avatar
Member: 1961436
Sonork: 100.1612163
Thanks Meter: 30
thanks
br,
s1emens
Why dont you people search forums !!!!!!!!!!
http://forum.gsmhosting.com/vbb/f672...000-a-1693322/
Old 08-02-2013, 14:18   #4 (permalink)
s1emens's Avatar
Member: 40602
Thanks Meter: 118
Thank you bro
br,
s1emens
Page generated in 0.15108 seconds with 8 queries
