07-09-2017, 14:47 | #1 (permalink) |
Junior Member Join Date: Apr 2014
Member: 2164476 Status: Offline Thanks Meter: 1 | easy jtag not working Microsoft Windows 7 (32 bit) build 7601 (6.1.7600.16385) Looking for EasyJTAG box... EasyJTAG API ver. 2008 Setting IO Levels to 1.8V Setting frequence to 14 Mhz HiPower mode is OFF EasyJTAG Box Serial = 1900B005700F983B Card Serial = AA5B-6BDE EasyJTAG Box Firmware = 01.58 Changelog: 28.05.2017 (ver 1.0.0.47) Fix: Bugs that have been found through your crash report Fix: Searching for partitions when scanning MBR Fix: Searching for MassStorage devices Add: AutoUpdate for the program HiPower mode is OFF CMD Pullup Level: 1691 mV CMD Active Level: 1773 mV Can't init device. Reason: CMD Timeout Error how can solve the problem br,dhkbd |
07-09-2017, 15:12 | #2 (permalink) | |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,557 | Quote:
07-09-2017, 22:27 | #4 (permalink) |
Insane Poster Join Date: Jun 2008
Member: 794019 Status: Offline Thanks Meter: 31 | first off all what connection are you using, is it socket or ISP? if it is an ISP connection what type of adapter did you use? the original or third party? and what kind of phone did you try to connect. you should learn the connection basics for emmc repair. |
