04-10-2020, 15:12 | #1 (permalink) |
No Life Poster Join Date: Oct 2007 Location: EGYPT
Member: 601566 Status: Offline Sonork: 100.1637134 Thanks Meter: 551 | t585 died boot CMD Pullup Level: 391 mV CMD Active Level: 2670 mV EMMC Device Information : EMMC CID: 150100424A544434520067E45B2CB62A EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture : SAMSUNG , EMMC NAME: BJTD4R , HEX: 424A54443452 , S/N: 67E45B2C , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 11/2019 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 2 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x01 , width 4bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: BJTD4R_67E45B2C_20200410_160934.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: PIT, [000000004400 - 000000006400], size: 000000002000 (8.00 KB) Partition: MD5HDR, [000000006400 - 000000106400], size: 000000100000 (1.00 MB) Partition: ECT, [000000300000 - 000000400000], size: 000000100000 (1.00 MB) Partition: BOTA0, [000000400000 - 000000800000], size: 000000400000 (4.00 MB) Partition: BOTA1, [000000800000 - 000000C00000], size: 000000400000 (4.00 MB) Partition: EFS, [000000C00000 - 000002000000], size: 000001400000 (20.0 MB) Partition: CPEFS, [000002000000 - 000002800000], size: 000000800000 (8.00 MB) Partition: m9kefs1, [000002800000 - 000002C00000], size: 000000400000 (4.00 MB) Partition: m9kefs2, [000002C00000 - 000003000000], size: 000000400000 (4.00 MB) Partition: m9kefs3, [000003000000 - 000003400000], size: 000000400000 (4.00 MB) Partition: PARAM, [000003400000 - 000003C00000], size: 000000800000 (8.00 MB) Partition: BOOT, [000003C00000 - 000005C00000], size: 000002000000 (32.0 MB) Partition: RECOVERY, [000005C00000 - 000008200000], size: 000002600000 (38.0 MB) Partition: OTA, [000008200000 - 000008A00000], size: 000000800000 (8.00 MB) Partition: CDMA-RADIO, [000008A00000 - 000008E00000], size: 000000400000 (4.00 MB) Partition: RADIO, [000008E00000 - 00000E600000], size: 000005800000 (88.0 MB) Partition: TOMBSTONES, [00000E600000 - 00000E700000], size: 000000100000 (1.00 MB) Partition: DNT, [00000E700000 - 00000E800000], size: 000000100000 (1.00 MB) Partition: PERSISTENT, [00000E800000 - 00000E880000], size: 000000080000 (512. KB) Partition: PERSDATA, [00000E880000 - 00000F480000], size: 000000C00000 (12.0 MB) Partition: RESERVED2, [00000F480000 - 00000F800000], size: 000000380000 (3.50 MB) Partition: SYSTEM, [00000F800000 - 0000E4000000], size: 0000D4800000 (3.32 GB) Partition: CACHE, [0000E4000000 - 0000F0800000], size: 00000C800000 (200. MB) Partition: HIDDEN, [0000F0800000 - 0000F4400000], size: 000003C00000 (60.0 MB) Partition: CP_DEBUG, [0000F4400000 - 0000F4900000], size: 000000500000 (5.00 MB) Partition: USERDATA, [0000F4900000 - 000747BFBE00], size: 0006532FBE00 (25.3 GB) GPT header successfully parsed Get firmware version Firmware info not found |
04-11-2020, 12:28 | #2 (permalink) |
Member: 601566 Status: Offline Sonork: 100.1637134 Thanks Meter: 551 | Operation: Write by vendor (Samsung) Creating GPT-partitioninig Writing PrimaryGPT at address: 000000000000 Writing BackupGPT at address: 000747BFBE00 Writing PIT at address: 000000004400 GPT-partitioning done Unpacking file: cm.bin Unpacking Lz4: cm.bin.lz4 Unpacking file: sboot.bin Unpacking Lz4: sboot.bin.lz4 Unpacking file: param.bin Unpacking Lz4: param.bin.lz4 Unpacking file: boot.img Unpacking Lz4: boot.img.lz4 Unpacking file: recovery.img Unpacking Lz4: recovery.img.lz4 Unpacking file: modem.bin Unpacking file: system.img Unpacking Lz4: system.img.lz4 Unpacking file: cache.img Unpacking Lz4: cache.img.lz4 Unpacking file: hidden.img Unpacking Lz4: hidden.img.lz4 Unpacking file: modem_debug.bin Unpacking file: userdata.img Unpacking Lz4: userdata.img.lz4 Partition name: CM Filename: cm.bin , Offset: 000000000000 , filesize: 2445584 bytes eMMC switching to ROM3 Erasing partition... Writing partition... Done writing partition. Write speed: 200.14 KB/s Partition name: BOOTLOADER Filename: sboot.bin , Offset: 000000000000 , filesize: 1728784 bytes eMMC switching to ROM2 Erasing partition... Writing partition... Done writing partition. Write speed: 199.48 KB/s Partition name: PARAM Filename: param.bin , Offset: 000003400000 , filesize: 1269760 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 445.59 KB/s Partition name: BOOT Filename: boot.img , Offset: 000003C00000 , filesize: 18872608 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 649.12 KB/s Partition name: RECOVERY Filename: recovery.img , Offset: 000005C00000 , filesize: 23439648 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 648.11 KB/s Partition name: RADIO Filename: modem.bin , Offset: 000008E00000 , filesize: 34667216 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 651.00 KB/s Partition name: SYSTEM Filename: system.img , Offset: 00000F800000 , filesize: 3275946176 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 4746 Done writing partition. Write speed: 630.27 KB/s Partition name: CACHE Filename: cache.img , Offset: 0000E4000000 , filesize: 100516128 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 16 Done writing partition. Write speed: 640.79 KB/s Partition name: HIDDEN Filename: hidden.img , Offset: 0000F0800000 , filesize: 19735296 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 46 Done writing partition. Write speed: 616.57 KB/s Partition name: CP_DEBUG Filename: modem_debug.bin , Offset: 0000F4400000 , filesize: 5242880 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 637.91 KB/s Partition name: USERDATA Filename: userdata.img , Offset: 0000F4900000 , filesize: 330958176 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 84 Done writing partition. Write speed: 650.11 KB/s Check BootConfig for the selected vendor All done time: [02:50:26:934] |
04-11-2020, 12:30 | #3 (permalink) |
Member: 601566 Status: Offline Sonork: 100.1637134 Thanks Meter: 551 | info EMMC Init completed. Writing eMMC Register ... Reg: 179 Value: 0x48 Reg: 177 Value: 0x01 Reg: 162 Value: 0x01 Successfully Setting frequence to 21 MHz CMD Pullup Level: 391 mV CMD Active Level: 2650 mV EMMC Device Information : EMMC CID: 150100424A544434520067E45B2CB62A EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture : SAMSUNG , EMMC NAME: BJTD4R , HEX: 424A54443452 , S/N: 67E45B2C , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 11/2019 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 2 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x01 , width 4bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: BJTD4R_67E45B2C_20200411_132925.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: BOTA0, [000000400000 - 000000800000], size: 000000400000 (4.00 MB) Partition: BOTA1, [000000800000 - 000000C00000], size: 000000400000 (4.00 MB) Partition: EFS, [000000C00000 - 000002000000], size: 000001400000 (20.0 MB) Partition: CPEFS, [000002000000 - 000002800000], size: 000000800000 (8.00 MB) Partition: M9KEFS1, [000002800000 - 000002C00000], size: 000000400000 (4.00 MB) Partition: M9KEFS2, [000002C00000 - 000003000000], size: 000000400000 (4.00 MB) Partition: M9KEFS3, [000003000000 - 000003400000], size: 000000400000 (4.00 MB) Partition: PARAM, [000003400000 - 000003C00000], size: 000000800000 (8.00 MB) Partition: BOOT, [000003C00000 - 000005C00000], size: 000002000000 (32.0 MB) Partition: RECOVERY, [000005C00000 - 000008200000], size: 000002600000 (38.0 MB) Partition: OTA, [000008200000 - 000008A00000], size: 000000800000 (8.00 MB) Partition: CDMA-RADIO, [000008A00000 - 000008E00000], size: 000000400000 (4.00 MB) Partition: RADIO, [000008E00000 - 00000E600000], size: 000005800000 (88.0 MB) Partition: TOMBSTONES, [00000E600000 - 00000E700000], size: 000000100000 (1.00 MB) Partition: DNT, [00000E700000 - 00000E800000], size: 000000100000 (1.00 MB) Partition: PERSISTENT, [00000E800000 - 00000E880000], size: 000000080000 (512. KB) Partition: PERSDATA, [00000E880000 - 00000F480000], size: 000000C00000 (12.0 MB) Partition: RESERVED2, [00000F480000 - 00000F800000], size: 000000380000 (3.50 MB) Partition: SYSTEM, [00000F800000 - 0000E4000000], size: 0000D4800000 (3.32 GB) Partition: CACHE, [0000E4000000 - 0000F0800000], size: 00000C800000 (200. MB) Partition: HIDDEN, [0000F0800000 - 0000F4400000], size: 000003C00000 (60.0 MB) Partition: CP_DEBUG, [0000F4400000 - 0000F4900000], size: 000000500000 (5.00 MB) Partition: USERDATA, [0000F4900000 - 000747BFBE00], size: 0006532FBE00 (25.3 GB) GPT header successfully parsed Get firmware version Brand = samsung Manufacturer = samsung Device = gtaxllte Model = SM-T585 Phone platform = exynos5 CPU Abi = armeabi-v7a Android release = 8.1.0 Firmware version = M1AJQ.T585XXU6CTB1 Firmware date = Fri Feb 14 16:40:52 KST 2020 |
04-11-2020, 12:54 | #4 (permalink) |
Member: 601566 Status: Offline Sonork: 100.1637134 Thanks Meter: 551 | EasyJtag Suite Classic ver.: 3.6.2.3 / wxWidgets 3.1.3-W-U started. OS ver.: Windows 10 (build 18363), 64-bit edition. Admin rights FAIL Autorun Agent ver:1.0.0.0 Crash Reporting ver:1.4.0.3 EasyJTAG SPI Plugin ver:1.1.1.11 Android ADB API ver:2.0.0.0 FTDI API ver:3.2.4.0 LibUSB API ver:1.2.6.0 Visual C++ Runtime ver:10.0.30319.1 Setting box Pinout ... Box Drivers version: 10.0.18362.1, are OK Z3X Card Serial : AA63-6424 , ver: 22 Z3X Card Activation [JTAGPLUS] : NOT ACTIVATED Z3X Card Activation [LG] : NOT ACTIVATED Z3X Card Activation [SAMS] : NOT ACTIVATED Z3X Card Activation [JTAG] : ACTIVATED Found 3 serial devices COM96 USB\VID_0325&PID_0032&REV_0100&MI_00 USB Serial Device (COM96) COM123 root\rimports RIM Virtual Serial Port v2 (COM123) COM124 root\rimports RIM Virtual Serial Port v2 (COM124) Selected pinout: EasyJTAG GEN1 ISP Pinout Change EasyJTAG Pinout OK Z3X EasyJtag Software ver. 3.6.2.3 Loading eMMC GEN1 Firmware... IO: 3300 mV Box S/N: 10FFE00C1DB260E5, ,FW Ver.: 01.63 CMD Pullup Level:412 mV CMD Active Level:2588 mV Box IO Level:3300 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 150100424A544434520067E45B2CB62A eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 11/2019 Rev.0x0 eMMC NAME: BJTD4R , S/N: 1743018796 eMMC NAME (HEX): 424A54443452 EMMC ROM1 (Main User Data) Capacity: 29820 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB EMMC RPMB is programmed and written 2 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: BJTD4R_1743018796_20200411_1353.extcsd Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 3A3E000 sectors 29.1 GiB Soft (Partitioned) Disk/Image size: 3A3DFBC sectors 29.1 GiB Disk identifier (GUID): 52444E41-494F-2044-4D4D-43204449534B Logical sector size: 0x200 bytes ,First/Last usable sector: 34,61071326 Partition info successfully found ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x000F800000 (3.320GB) Short EXT fs info: Size: 3.288GB Block size: 4.0KB Inode size: 256 Inodes: 215568 Short Android info: Build ID: M1AJQ Display Build ID: M1AJQ.T585XXU6CTB1 Release Incremental ID: T585XXU6CTB1 Release Base ID: 8.1.0 Security Path: 2020-02-01 Device Model: SM-T585 Device Manufacturer: samsung Product ID: gtaxllte Device Name A: gtaxlltexx Device Name B: gtaxllte Architecture ABI: armeabi-v7a Device manufacturer: samsung Build Description: gtaxlltexx-user 8.1.0 M1AJQ T585XXU6CTB1 release-keys PDA ver.: T585XXU6CTB1 Samsung CPU: exynos7870 Device Board Name: universal7870 Device Platform: exynos5 FRP Partition Path: /dev/block/persistent Backup saved: BuildProp_20200411_1353.txt --------------------------------------------- Detected USERDATA USERDATA : 0x00F4900000 (25.298GB) Short EXT fs info: Size: 10.0GB Block size: 4.0KB Inode size: 256 Inodes: 327680 Short userdata info: Unable to read gesture.key , code 2 Done. |
