Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Easy-Jtag
Old 08-03-2017, 22:38   #1 (permalink)
Member: 331917
Thanks Meter: 210
Easy Jtag plus cant run because admin rights (I have them)
Hello, it wont run
I can not execute the software, it says it needs admins rights, but account has admins rights.
same error on .47
I tried with XP and Seven 64.
what the problem?
thanks
Old 08-08-2017, 02:52   #2 (permalink)
hervie's Avatar
Member: 2714943
Thanks Meter: 81
use windows 7 32bit...........
Old 08-08-2017, 03:28   #3 (permalink)
darkcloudgsmph's Avatar
Member: 1714045
Sonork: 100.1596047
Thanks Meter: 86
my OS is windows7 64bit
Easy Jtag plus is working
Old 08-08-2017, 04:00   #4 (permalink)
Member: 331917
Thanks Meter: 210
Sorry, I tried, xp, seven 32 and seven 64, different computers....
same result.... O_O
Old 08-08-2017, 04:33   #5 (permalink)
Member: 1112585
Sonork: 100.1645028
Thanks Meter: 87
Make new Administrator Account & login on that account.
Or
make 1 admin & 1 Standard account.
& put password on that admin account,
& Run Easy+ with Standard account,
& Select Admin acc to put Password,
& don't turn Off User Account Control.
The Following User Says Thank You to pai_d For This Useful Post:
Old 08-08-2017, 04:34   #6 (permalink)
Member: 1112585
Sonork: 100.1645028
Thanks Meter: 87
Or
Old 08-08-2017, 04:56   #7 (permalink)
Member: 331917
Thanks Meter: 210
I will try
the strange thing is that I have admin rights already.....
thanks
Old 08-08-2017, 05:21   #8 (permalink)
Member: 205157
Sonork: 100.1574537
Thanks Meter: 81
Originally Posted by Nicogalan View Post
I will try
thanks
Go to Command Prompt type
net user administrator /active:yes
enter
Then Go to Start button and select log off select administrator
From now ur PC have Administrative Rights (From Now) No need to select Right Click And Select Run As Adnministrator
Any OS
The Following User Says Thank You to cellncare For This Useful Post:
Old 08-08-2017, 05:24   #9 (permalink)
Member: 331917
Thanks Meter: 210
I tried both options, from Pai_d and Cellncare, but same error.
this is very strange...
I do have admin rights already.... O_O
Old 08-08-2017, 05:28   #10 (permalink)
Member: 205157
Sonork: 100.1574537
Thanks Meter: 81
Check Your PM
Give Team ID
Old 08-08-2017, 12:08   #11 (permalink)
adi sukmono's Avatar
Member: 695310
Thanks Meter: 144
maybe need reinstal driver smartcard, cause auto dieferent call box when open suite clasic
The Following User Says Thank You to adi sukmono For This Useful Post:
Old 08-09-2017, 07:54   #12 (permalink)
Member: 331917
Thanks Meter: 210
Still same probem, even after teamviewer help....
I do have admin rights, its very strange....
is your soft checking admin rights? or vmprotect has that option?
thanks
Old 08-09-2017, 09:06   #13 (permalink)
Member: 331917
Thanks Meter: 210
Solved by creating a custom asm loader....
I needed to do some reversing, but it was needed....
Old 08-15-2017, 08:08   #14 (permalink)
Member: 331917
Thanks Meter: 210
Just in case, if someone else has the same problem...
check at 00DB4582
Old 08-15-2017, 21:06   #15 (permalink)
blang's Avatar
Member: 2368
Sonork: 100.111111
Thanks Meter: 176,647
Hello, it wont run
same error on .47
what the problem?
thanks
did you try on other pc?
Page generated in 0.36036 seconds with 8 queries
