02-03-2018, 10:41 | #1 (permalink) |
Freak Poster Join Date: Dec 2006 Location: caribe look, Drunken master II
Member: 410843 Status: Offline Thanks Meter: 28 | easy jtag plus error cant run https://ibb.co/nLBqpR https://ibb.co/dHVBw6 any help from support? |
02-03-2018, 14:20 | #2 (permalink) | |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,558 | Quote:
what version of OS you have on pc? show device manager. also try keep CNTRL pressed and run software. this will help update box firmware. | |
02-04-2018, 01:28 | #3 (permalink) |
Member: 410843 Status: Offline Thanks Meter: 28 | latest version 2.9.0.1 pc 1 windows 8.1 64 bit with disable signature driver pc 2 windows 7 32 bit but same result keep CNTRL pressed and run software but same problem sir. |
02-04-2018, 04:02 | #4 (permalink) |
Registered User Join Date: Jan 2008 Location: Where never ends.
Member: 669673 Status: Offline Thanks Meter: 301 | 1st download this EasyJtag_Release_v2.9.0.1 version 2nd setup this version on my pc 3rd run only easyJTAG tool 4th auto update device Do all steps problem will be solve . Post result also. |
02-04-2018, 06:07 | #5 (permalink) | |
Member: 410843 Status: Offline Thanks Meter: 28 | Quote:
already formatted pc fresh os install but nothing change how to solve this | |
02-05-2018, 12:05 | #8 (permalink) |
Product Supporter Join Date: May 2011
Member: 1569669 Status: Offline Thanks Meter: 257 | Hi, I don't see card in device manager. It looks something is wrong with card connection to box. Please, try to remove/insert card from box (make sure that card inserted properly). If you have separate USB card reader, check card with Z3X Shell (to make sure that card is not damaged). If can't solve this problem, contact your reseller. Best Regards |
The Following User Says Thank You to vikboston For This Useful Post: |
09-20-2020, 18:30 | #12 (permalink) |
Freak Poster Join Date: May 2009 Location: Bandarban, Bangladesh
Member: 1040615 Status: Offline Thanks Meter: 23 | I buy easy jtag box yesterday 18 September 2020. but when connected box after software install then box card appear number. After some time red light and blue light blinking. I shut down computer and start the computer but the red light and blue light on box blinking continuously. Now today the box is off and not lights on is on. And box is dead. Thanks for advance |
09-21-2020, 08:12 | #13 (permalink) | |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | Quote:
flashing only left led - EasyJTAG box at update mode blinking RED led - error with initialize box: windows can't access to box (need restard PC and re-initialize USB devices) at flash mode use need install "EasyJTAG Update port driver" if uou use win 10 - you need disable driver sighning: run at command promt: bcdedit.exe -set loadoptions DISABLE_INTEGRITY_CHECKS | |
