12-27-2017, 19:47 | #122 (permalink) | |
Insane Poster Join Date: Jun 2008 Location: UK-PL
Member: 796570 Status: Offline Thanks Meter: 26 | Beginer ??? Quote:
I guess (based at question) You are new at GSM service so let me explain for You: Z3X is the name of team which create that hardware and software as well ! Team release at begining service box which has UART and USB connector at front box panel ! Also with purchase You will get Your unique Indentity card which has serial number (Your ID) ! Box and software are designed to service in major Samsung LG cell/smartphone ! Each Brand are like Brand activation at Your card ! As first purchase You could buy Samsung or LG z3x service box with or without set of service cables ! As alternative, if want "jump at higher level of repair" and are familiar with soldering You could buy Z3X team Easy JTAG box which has special interface called JTAG (IEEE Standard 1149.1-1990) ! This required mostly stripping device as that JTAG interface not always are clearly displayed/accessible but if achieve proper connection You can repair dead/bricked devices by writing directly to memory (or via IC chip to memory) booting files called mostly bootloader.. As far Team release second version of Easy Jtag box called "Easy Jtag Plus" ! So far they supply fantastic quality sockets/adapter which I highly recommend ! And promises like : UFS and NAND support with future update as hardware is already technicly ready for that sounds F****ng fanstastic and guess made every JTAG familiar coleagous goose-fleshes As far that was introduction.... so .... what color of pill you choice ?? | |
01-12-2018, 07:02 | #127 (permalink) |
Freak Poster Join Date: Jun 2015 Location: KORBA CHHATISHGARH INDIA
Member: 2418156 Status: Offline Sonork: 1677163 Thanks Meter: 16 | I BUY EASY JTAG LAST YEAR 2017 AUGUST 2017 TRY MANY TIME MANY SET BUT ALWAYS FAIL NOT CONNECT ANY HANDSET ALWAYS SAY THIS ERROR IN BOX SAYS CONNECT CLK GND 1.8 V 2.8V CMD DATO BUT MY ISP BORD GND NRST TDO RTC TCK TMS TDI\DO TRST\CLK VREF\CMD 2.8V 1.8V BUT NO DATO PLEASE HELP ME SIR I AM TRY LONG TIME BUT ALWAYS FAILD |
The Following User Says Thank You to ROOPKRB2015 For This Useful Post: |
01-13-2018, 06:37 | #129 (permalink) |
Insane Poster Join Date: Apr 2008 Location: Philippines
Member: 740892 Status: Offline Thanks Meter: 21 | Version 1.4.9.0 EasyJTAG Box Firmware = 2.21 Changelog: 12.12.2017 (ver 1.4.9.0) Fix: Bugs that have been found through your crash report Fix: RandomVerify function Fix: Creation of GPT for Samsung (write by vendor) Fix: Failed to mount large Fat partitions (explorer) Fix: Extraction from contact2.db (explorer) Fix: Error in the "build.prop" parser Fix: CID Parser Add: Support for EasyJtag Plus Box Add: Path for TempDir and InitialDir (option in settings) Add: Unpack Lenovo QSB (utilities) Add: Selecting a PIT file from CSC (write by vendor Samsung) Add: Detect for encrypted dumps from GPG Box Add: Detect for FullDiskEncryption Partition (explorer) Add: LinearVerify of the Partition (read by vendor) Add: Information base about emmc compatibility (thanks to phonemicrodb) Add: Resizing the window (for small screen resolutions) Add: Converting large partitions in SparseImage when reading by vendor (option in settings) Add: Mounting SparseImage (explorer) Add: Automatic backup of the EFS partition for Samsung (read by vendor) Add: Formatting of EFS partition for Samsung on request (write by vendor) Setting interface to EasyJtag2/ISP_HiPower Setting bus width to 1 Bit HiPower mode is ON Setting frequence to 18 Mhz CMD Pullup Level: 493 mV CMD Active Level: 2084 mV Can't init device. Reason: CMD Timeout Error what's the problem? [IMG][/IMG] |
01-19-2018, 02:21 | #132 (permalink) | |
No Life Poster Join Date: May 2005 Location: UK
Member: 143848 Status: Offline Thanks Meter: 125 | i m having similar issues. Quote:
i m having similar issues with isp adaptor. | |
01-23-2018, 03:37 | #133 (permalink) | |
Junior Member Join Date: Jul 2015 Location: thekte, mizoram
Member: 2430286 Status: Offline Sonork: 100.1668015 Thanks Meter: 0 | Quote:
Sent from my Coolpad 8297L-I00 using Tapatalk | |
