10-16-2019, 15:53 | #196 (permalink) | |
Freak Poster Join Date: Jun 2010
Member: 1326433 Status: Offline Sonork: yahoo Thanks Meter: 23 | easy jtag plus Quote:
http://postimg.cc/hJ2c5MMC but my box not detected http://postimg.cc/3WRCVRr9 only this messag (Can't init device, Reason: CMD Timeout Error ) tri to-HiPower mode is off/on tri to all methods but not success this handset 100% ok no problem,jast for test tri to all set but pls help sir | |
10-16-2019, 19:50 | #197 (permalink) | |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | Quote:
I wrote to you about this before | |
11-08-2019, 12:12 | #199 (permalink) |
Freak Poster Join Date: May 2009
Member: 1042338 Status: Offline Thanks Meter: 8 | emmc from huawei mate 20 lite hi ALL i have a emmc from huawei mate 20 lite and i need read thhe emmc chip, but the sw see like a dead emmc. i tried with a different vendor but the answer is the same eMMC_tool Suite ver. 1.6.2.0 (release date: 30.06.2019) Microsoft Windows 7 (32 bit) build 7601 (6.1.7601.18015) Looking for EasyJTAG box... EasyJTAG API ver. 3307 EasyJTAG Box Serial = 42062D4361FF9492 Card Serial = AAAA220E EasyJTAG Box Firmware = 2.44 Changelog: 30.06.2019 (ver 1.6.1.0) Fix: Bugs that have been found through your crash report Setting interface to EasyJtag2/E-Socket Setting bus width to 4 Bit Setting frequence to 14 MHz Can't init device. Reason: OCR Ready Timeout Error [Check VCC or eMMC DEAD] Can't init device. Reason: OCR Ready Timeout Error [Check VCC or eMMC DEAD] Can't init device. Reason: OCR Ready Timeout Error [Check VCC or eMMC DEAD] Setting interface to EasyJtag2/E-Socket Setting bus width to 4 Bit Setting frequence to 14 MHz Can't init device. Reason: CMD Timeout Error Canceled Setting interface to EasyJtag2/E-Socket Setting bus width to 4 Bit Setting frequence to 14 MHz Can't init device. Reason: CMD Timeout Error Canceled Setting interface to EasyJtag2/E-Socket Setting bus width to 4 Bit Setting frequence to 14 MHz Can't init device. Reason: CMD Timeout Error Canceled Setting interface to EasyJtag2/E-Socket Setting bus width to 4 Bit Setting frequence to 14 MHz Can't init device. Reason: CMD Timeout Error Can't init device. Reason: OCR Ready Timeout Error [Check VCC or eMMC DEAD] Can't init device. Reason: OCR Ready Timeout Error [Check VCC or eMMC DEAD] Setting interface to EasyJtag2/E-Socket Setting bus width to 4 Bit Setting frequence to 14 MHz Can't init device. Reason: OCR Ready Timeout Error [Check VCC or eMMC DEAD] Can't init device. Reason: OCR Ready Timeout Error [Check VCC or eMMC DEAD] Can't init device. Reason: OCR Ready Timeout Error [Check VCC or eMMC DEAD] Setting interface to EasyJtag2/E-Socket Setting bus width to 4 Bit Setting frequence to 14 MHz Can't init device. Reason: OCR Ready Timeout Error [Check VCC or eMMC DEAD] Can't init device. Reason: OCR Ready Timeout Error [Check VCC or eMMC DEAD] Canceled |
11-12-2019, 00:58 | #200 (permalink) |
Junior Member Join Date: Dec 2008
Member: 926043 Status: Offline Sonork: jjgg Thanks Meter: 0 | Is there someone working in there?? I have writen thousands of emails and none of then have been answerd by you . i need to activate my Easy Jtag card sn: AA6F-2D17 that i bought on Aliexpress and is from GPG Industries China reseller,, at least answer this email please |
11-12-2019, 10:20 | #201 (permalink) | |
If you seller is bad - change seller when you buy a phone in a store, you do not write to the factory about the fact that the store sold you a damaged device or sold, for example, a fake Last edited by layder; 11-12-2019 at 10:39. | |
11-12-2019, 12:57 | #202 (permalink) |
Freak Poster Join Date: Mar 2013 Location: Madrid
Member: 1898289 Status: Offline Thanks Meter: 39 | Hi, I was decided to buy this tool, which seller or kit you recommend for take it? I saw different packages, like with MOORC E-MATE already included, or some sockets, I wish to have as full as possible for no troubles in short and go for any adaptor/socket etc. Thanks in advance. |
11-12-2019, 20:05 | #203 (permalink) |
Member: 13148 Status: Offline Thanks Meter: 2,948 | I recomended https://gsmserver.com/z3x-easy-jtag-...l-upgrade-set/ and native sockets (https://gsmserver.com/z3x-easy-jtag-...ocket-adapter/) For BGA254 wait few time |
The Following User Says Thank You to layder For This Useful Post: |
11-16-2019, 12:15 | #204 (permalink) |
Member: 1898289 Status: Offline Thanks Meter: 39 | And then be possible to recover data from newer models like Samsung S9? For UFS is fully working now or not if data are crypted? Enviado desde mi SM-G960F mediante Tapatalk |
11-21-2019, 10:03 | #207 (permalink) |
Freak Poster Join Date: May 2011 Location: algeria
Member: 1582098 Status: Offline Thanks Meter: 17 | Hello is it possible to upgrade from normal Z3x to easyjtag plus i found easyjtag plus and sockets but without simcard , can i buy it and activate it with my current z3x box ? |
11-21-2019, 10:18 | #208 (permalink) | |
