Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Easy-Jtag
Old 12-28-2018, 02:24   #1 (permalink)
NoName®'s Avatar
Member: 129885
Sonork: 100:1603514
Thanks Meter: 6,125
Smile Easy JTAG Plus Suite Released v1.5.3.0
Fixed:
- Bugs that have been found through your crash report
- Scatter file processing (MTK)
- Contact Extractor
- Preloader parser
- FAT partitions mounting
- Minor interface changes
Added:
- Explorer: Work with Qualcomm HS-USB QDLoader 9008 interface
- Reset FRP via Qualcomm HS-USB QDLoader 9008 interface (General - Advanced - Remove FRP)
- Remove Android locks via Qualcomm HS-USB QDLoader 9008 interface (General - Advanced - Remove Android Locks)
- Auto/Manual loaders select for Qualcomm HS-USB QDLoader 9008 interface
- Samsung firmware lz4 unpack support (Write by vendor - Samsung)
- Import from cm2qlm xml backups (Write by vendor - Qualcomm)
- Unpack Bootloader.img archive from Motorola firmware files
- Import GP partition parameters from ExtCSD backups (General - eMMC HW Partitions)
- Import Boot and RPMB sizes from ExtCSD backups (General - eMMC HW Partitions)
- Allow to create a GP with zero size (fix "Error writing at address: 000000000000", fine for Samsung eMMC, and may be destroy SanDisk and other eMMC)
- Explorer: Pin and Password decoding (only English and Russian letters)
The Following 59 Users Say Thank You to NoName® For This Useful Post:
Old 12-28-2018, 03:26   #2 (permalink)
Member: 920138
Thanks Meter: 81
support oppo a3s factory reset and reset frp in general advanced needed
The Following 3 Users Say Thank You to ninozacal For This Useful Post:
Old 12-28-2018, 05:16   #3 (permalink)
Member: 1734313
Sonork: 100.1620886
Thanks Meter: 68
Originally Posted by NoName® View Post
28.12.2018 (ver 1.5.3.0)
  • Fix: Bugs that have been found through your crash report
  • Fix: Scatter file processing (MTK)
  • Fix: Contact Extractor
  • Fix: Preloader parser
  • Fix: FAT partitions mounting
  • Fix: Minor interface changes
  • Add: Explorer: Work with Qualcomm HS-USB QDLoader 9008 interface
  • Add: Reset FRP via Qualcomm HS-USB QDLoader 9008 interface (General - Advanced - Remove FRP)
  • Add: Remove Android locks via Qualcomm HS-USB QDLoader 9008 interface (General - Advanced - Remove Android Locks)
  • Add: Auto/Manual loaders select for Qualcomm HS-USB QDLoader 9008 interface
  • Add: Samsung firmware lz4 unpack support (Write by vendor - Samsung)
  • Add: Import from cm2qlm xml backups (Write by vendor - Qualcomm)
  • Add: Unpack Bootloader.img archive from Motorola firmware files
  • Add: Import GP partition parameters from ExtCSD backups (General - eMMC HW Partitions)
  • Add: Import Boot and RPMB sizes from ExtCSD backups (General - eMMC HW Partitions)
  • Add: Allow to create a GP with zero size (fix "Error writing at address: 000000000000", fine for Samsung eMMC, and may be destroy SanDisk and other eMMC)
  • Add: Explorer: Pin and Password decoding (only English and Russian letters)
Direct downloads ling will be added as soon as uploading finished!
Download Link pls sir
The Following 3 Users Say Thank You to mobirepair For This Useful Post:
Old 12-28-2018, 05:20   #4 (permalink)
Member: 534478
Thanks Meter: 39
The program EasyJtag_Release_v3.4.RC5 is incomplete. Opened as ver 1.5.2.0
The Following User Says Thank You to numsung For This Useful Post:
Old 12-28-2018, 05:47   #5 (permalink)
Taguro-GSMLover's Avatar
Member: 2669319
Thanks Meter: 401
exe is Not available on Shell yet!
pls Upload it
Old 12-28-2018, 06:52   #6 (permalink)
Member: 2521152
Thanks Meter: 10
Add OPpo a3s and realme 2 password unlock
The Following User Says Thank You to ashekh04 For This Useful Post:
Old 12-28-2018, 08:10   #7 (permalink)
Member: 13148
Thanks Meter: 1,286
Easy JTAG Plus Suite is everyday himself checks for updates and automatic install it
Old 12-28-2018, 09:55   #8 (permalink)
Member: 2669319
Thanks Meter: 401
Not this time
The Following User Says Thank You to Taguro-GSMLover For This Useful Post:
Old 12-28-2018, 10:21   #9 (permalink)
Member: 2573542
Thanks Meter: 11
Download Links Please, setup not available anywhere.
The Following User Says Thank You to Sonu™ For This Useful Post:
Old 12-28-2018, 10:32   #10 (permalink)
SAJONDUTTA's Avatar
Member: 926902
Sonork: 100.1655575
Thanks Meter: 475
can support new oppo mi pattern frp unlock this update
Old 12-28-2018, 11:39   #11 (permalink)
gencom's Avatar
Member: 1918391
Thanks Meter: 61
how i can translate plus version
Old 12-28-2018, 14:56   #12 (permalink)
rico_deep's Avatar
Member: 159757
Thanks Meter: 439
very nice ....................
Old 12-29-2018, 04:37   #13 (permalink)
Member: 2128671
Thanks Meter: 38
Please support factory reset all android via emmc
Old 12-29-2018, 04:42   #14 (permalink)
Member: 840372
Thanks Meter: 11
Oppo A3s
is support for Oppo A3s or for new security ?
The Following 2 Users Say Thank You to aliang For This Useful Post:
Old 12-29-2018, 08:32   #15 (permalink)
Member: 13148
Thanks Meter: 1,286
You need find 9008 firehose to model. If firehose loader successfully sended to phone, it auto-add save to loaders base and sended to EasyJTAG server.
we are will be collect successfully loaded loader from all users, who using EasyJTAG Plus Suite, and add it to new version
The Following 14 Users Say Thank You to layder For This Useful Post:
Page generated in 0.40875 seconds with 8 queries
