08-07-2018, 07:21 | #1 (permalink) |
No Life Poster Join Date: Oct 2007 Location: chennai Age: 38
Member: 616909 Status: Offline Sonork: 1672125 Thanks Meter: 648 | samsung j500f dead after apply frp patch Microsoft Windows 7 (32 bit) build 7601 (6.1.7600.16385) Looking for EasyJTAG box... EasyJTAG API ver. 2022 EasyJTAG Box Serial = B1AA4ABBBCB35E7A Card Serial = AA22-0D87 EasyJTAG Box Firmware = 2.23 Changelog: 12.12.2017 (ver 1.4.9.0) Fix: Bugs that have been found through your crash report Fix: RandomVerify function Fix: Creation of GPT for Samsung (write by vendor) Fix: Failed to mount large Fat partitions (explorer) Fix: Extraction from contact2.db (explorer) Fix: Error in the "build.prop" parser Fix: CID Parser Add: Support for EasyJtag Plus Box Add: Path for TempDir and InitialDir (option in settings) Add: Unpack Lenovo QSB (utilities) Add: Selecting a PIT file from CSC (write by vendor Samsung) Add: Detect for encrypted dumps from GPG Box Add: Detect for FullDiskEncryption Partition (explorer) Add: LinearVerify of the Partition (read by vendor) Add: Information base about emmc compatibility (thanks to phonemicrodb) Add: Resizing the window (for small screen resolutions) Add: Converting large partitions in SparseImage when reading by vendor (option in settings) Add: Mounting SparseImage (explorer) Add: Automatic backup of the EFS partition for Samsung (read by vendor) Add: Formatting of EFS partition for Samsung on request (write by vendor) Setting interface to EasyJtag2/ISP_HiPower Setting bus width to 1 Bit HiPower mode is ON Setting frequence to 18 Mhz CMD Pullup Level: 2119 mV CMD Active Level: 3037 mV EMMC Device Information : EMMC CID: 150100514E31364D420045B4D003A26F EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture Name: SAMSUNG , EMMC NAME: QN16MB , EMMC NAME (HEX): 514E31364D42 , S/N: 45B4D003 , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Manufacture Date: 10/2015 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 512 KB (000000080000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QN16MB_45B4D003_20180807_113308.extcsd EMMC Init completed. Warning: Health report is very BAD Device Life Time Estimation (MLC) [269]: 0x09 80% - 90% device life time used Device Life Time Estimation (SLC) [268]: 0x09 80% - 90% device life time used Pre EOL information [267]: 0x01 Normal Scanning soft partitions GPT header is found and is valid Partition: apnhlos, [000000400000 - 000001300000], size: 000000F00000 Partition: modem, [000001300000 - 000004C70000], size: 000003970000 Partition: sbl1, [000004C70000 - 000004CF0000], size: 000000080000 Partition: ddr, [000004CF0000 - 000004CF8000], size: 000000008000 Partition: aboot, [000004CF8000 - 000004EF8000], size: 000000200000 Partition: rpm, [000004EF8000 - 000004F78000], size: 000000080000 Partition: qsee, [000004F78000 - 000004FF8000], size: 000000080000 Partition: qhee, [000004FF8000 - 000005078000], size: 000000080000 Partition: fsg, [000005078000 - 000005378000], size: 000000300000 Partition: sec, [000005378000 - 00000537C000], size: 000000004000 Partition: pad, [00000537C000 - 000005E00000], size: 000000A84000 Partition: param, [000005E00000 - 000006800000], size: 000000A00000 Partition: efs, [000006800000 - 000007600000], size: 000000E00000 Partition: modemst1, [000007600000 - 000007900000], size: 000000300000 Partition: modemst2, [000007900000 - 000007C00000], size: 000000300000 Partition: boot, [000007C00000 - 000008900000], size: 000000D00000 Partition: recovery, [000008900000 - 000009800000], size: 000000F00000 Partition: fota, [000009800000 - 00000A480400], size: 000000C80400 Partition: backup, [00000A480400 - 00000AB7E000], size: 0000006FDC00 Partition: fsc, [00000AB7E000 - 00000AE7E000], size: 000000300000 Partition: ssd, [00000AE7E000 - 00000AE80000], size: 000000002000 Partition: persist, [00000AE80000 - 00000B680000], size: 000000800000 Partition: persistent, [00000B680000 - 00000B700000], size: 000000080000 Partition: persdata, [00000B700000 - 00000C000000], size: 000000900000 Partition: system, [00000C000000 - 00008E000000], size: 000082000000 Partition: cache, [00008E000000 - 00009A800000], size: 00000C800000 Partition: hidden, [00009A800000 - 00009EE00000], size: 000004600000 Partition: userdata, [00009EE00000 - 0001D1FFBE00], size: 0001331FBE00 GPT header successfully parsed Get firmware version Brand = samsung Manufacturer = samsung Model = SM-J500F Phone platform = msm8916 CPU Abi = armeabi-v7a Android release = 6.0.1 Firmware version = MMB29M.J500FXXU1BRC1 Firmware date = Fri Mar 16 15:08:55 KST 2018 Setting interface to EasyJtag2/ISP_HiPower Setting bus width to 1 Bit HiPower mode is ON Setting frequence to 18 Mhz CMD Pullup Level: 2117 mV CMD Active Level: 3038 mV EMMC Device Information : EMMC CID: 150100514E31364D420045B4D003A26F EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture Name: SAMSUNG , EMMC NAME: QN16MB , EMMC NAME (HEX): 514E31364D42 , S/N: 45B4D003 , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Manufacture Date: 10/2015 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 512 KB (000000080000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QN16MB_45B4D003_20180807_113400.extcsd EMMC Init completed. Reading S.M.A.R.T Report ... Device Life Time Estimation (MLC) [269]: 0x09 80% - 90% device life time used Device Life Time Estimation (SLC) [268]: 0x09 80% - 90% device life time used Pre EOL information [267]: 0x01 Normal Optimal Read Size [266]: 0x00 Not defined Optimal Write Size [265]: 0x08 32 KB Optimal Trim Unit Size [264]: 0x01 4 KB Reading MoviNand S.M.A.R.T Report ... Card Error mode: Normal Super Block size: 0x00800000 (8388608 bytes) Super Page size: 0x00008000 (32768 bytes) Optimal Write size: 0x00008000 (32768 bytes) Read Reclaim count: 0x0 Optimal TRIM size: 0x00001000 (4096 bytes) Erase Unit size: 0x00000000 (0 bytes) Total Number of banks: 0x1 Initial bad blocks per bank: 5,0,0,0 Runtime bad blocks per bank: 0,0,0,0 Reserved blocks left per bank : 23,0,0,0 All Erase counts (min,avg,max): 1596,2203,19677 SLC Erase counts (min,avg,max): 19590,19659,19677 MLC Erase counts (min,avg,max): 1596,1850,2984 Done i had done bl+ pit but same problem with me so what will i do for next ? if done j500f any one pls share success report and procedure |
08-07-2018, 08:46 | #2 (permalink) | |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | Quote:
You eMMC is very old, 90% life time used.... For best results you need to chang it | |
