10-03-2018, 20:09 | #1 (permalink) |
Freak Poster Join Date: Apr 2017
Member: 2707321 Status: Offline Thanks Meter: 6 | thnx i have a problem after i solder the pin and run easy repair it shows in the log Failed to open port... (\\.\COM3) ====> this port where the box is connected Last edited by layder; 10-20-2018 at 19:58. Reason: merge posts |
10-06-2018, 00:07 | #2 (permalink) |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | please: 1) make screenshot 2) post info about version of box, software, drivers |
The Following 2 Users Say Thank You to layder For This Useful Post: |
10-06-2018, 11:58 | #4 (permalink) |
Product Supporter Join Date: Mar 2005 Location: China
Member: 129885 Status: Offline Sonork: 100:1603514 Thanks Meter: 6,202 | Please Uninstall RIM Software. Its often block access to serial ports. |
The Following User Says Thank You to NoName® For This Useful Post: |
10-06-2018, 21:20 | #9 (permalink) |
Member: 2707321 Status: Offline Thanks Meter: 6 | i deleted balckberry desktop software but still same problem i face this problem Failed to open port... (\\.\COM4) Last edited by layder; 10-20-2018 at 19:59. Reason: merge posts |
10-08-2018, 22:28 | #11 (permalink) |
Member: 2707321 Status: Offline Thanks Meter: 6 | thnx sir i used my second computer with a fresh windows 7 but same problem i will install team vieawer now 1 082 501 536 this is my TM Id shall i give the password could you please help me or how can i contact PM please support any help Last edited by layder; 10-20-2018 at 19:59. Reason: merge posts |
10-12-2018, 13:26 | #12 (permalink) |
Member: 13148 Status: Offline Thanks Meter: 2,948 | We fix it as soon as possible. At this moment try to use old versions. This bug is created when we work with compatibility with windows 8/10. |
The Following User Says Thank You to layder For This Useful Post: |
10-12-2018, 13:30 | #13 (permalink) |
Member: 2707321 Status: Offline Thanks Meter: 6 | thnx one of our best support helped me to solve the problem but i need some help to find vcc vccq ..... on my jig if u dont mind i am new user sir i mean these pinout cause it's different from the one i have my isp adapter looks the same as this Last edited by layder; 10-20-2018 at 20:00. Reason: merge posts |
