Old 06-11-2019, 13:00   #1 (permalink)
umar342's Avatar
Member: 1246696
Sonork: 100.1681950
Thanks Meter: 650
realme 2 set dead after factry reset
HiPower mode is ON
Setting frequence to 21 Mhz
CMD Pullup Level: 2052 mV
CMD Active Level: 2970 mV
EMMC Device Information :
EMMC CID: 90014A484347386134A24D10492875A2
EMMC CSD: D02701328F5903FFFFFFFFEF8A400026
EMMC Manufacture : SKHYNIX , EMMC NAME: HCG8a4 , HEX: 484347386134 , S/N: 4D104928 , rev. 0xA2
EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 7/2018
EMMC ROM 1 (Main User Data) Capacity: 59640 MB (000E8F800000)
EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000)
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
Extended CSD Information :
Extended CSD rev: 1.8 (MMC 5.1)
Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area)
Boot Bus Config: 0x00 , width 1bit
H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled
Supported partition features [PARTITIONING_SUPPORT]: 0x07
Device supports partitioning features
Device can have enhanced technological features in partitions and user data area
Device can have extended partitions attribute
Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: HCG8a4_4D104928_20190611_172819.extcsd
EMMC Init completed.
Scanning soft partitions
GPT header is found and is valid
Partition: oppodycnvbk, [000000005000 - 000000A05000], size: 000000A00000 (10.0 MB)
Partition: oppostanvbk, [000000A05000 - 000001405000], size: 000000A00000 (10.0 MB)
Partition: modemst1, [000001405000 - 000001585000], size: 000000180000 (1.50 MB)
Partition: modemst2, [000001585000 - 000001705000], size: 000000180000 (1.50 MB)
Partition: persist, [000001705000 - 000003705000], size: 000002000000 (32.0 MB)
Partition: opporeserve1, [000003705000 - 000003F05000], size: 000000800000 (8.00 MB)
Partition: opporeserve2, [000003F05000 - 000007F05000], size: 000004000000 (64.0 MB)
Partition: fsc, [000007F05000 - 000007F05400], size: 000000000400 (1.00 KB)
Partition: ssd, [000007F06000 - 000007F08000], size: 000000002000 (8.00 KB)
Partition: sbl1, [000007F08000 - 000007F88000], size: 000000080000 (512. KB)
Partition: rpm, [000007F88000 - 000008008000], size: 000000080000 (512. KB)
Partition: tz, [000008008000 - 000008208000], size: 000000200000 (2.00 MB)
Partition: devcfg, [000008208000 - 000008248000], size: 000000040000 (256. KB)
Partition: sbl1bak, [000008248000 - 0000082C8000], size: 000000080000 (512. KB)
Partition: rpmbak, [0000082C8000 - 000008348000], size: 000000080000 (512. KB)
Partition: tzbak, [000008348000 - 000008548000], size: 000000200000 (2.00 MB)
Partition: devcfgbak, [000008548000 - 000008588000], size: 000000040000 (256. KB)
Partition: dsp, [000008588000 - 000009588000], size: 000001000000 (16.0 MB)
Partition: DDR, [000009800000 - 000009808000], size: 000000008000 (32.0 KB)
Partition: fsg, [000009808000 - 000009C08000], size: 000000400000 (4.00 MB)
Partition: sec, [000009C08000 - 000009C0C000], size: 000000004000 (16.0 KB)
Partition: aboot, [000009C0C000 - 000009D0C000], size: 000000100000 (1.00 MB)
Partition: abootbak, [000009D0C000 - 000009E0C000], size: 000000100000 (1.00 MB)
Partition: modem, [000009E0C000 - 000011E0C000], size: 000008000000 (128. MB)
Partition: dtbo, [000011E0C000 - 00001260C000], size: 000000800000 (8.00 MB)
Partition: vbmeta, [00001260C000 - 00001261C000], size: 000000010000 (64.0 KB)
Partition: boot, [00001261C000 - 00001661C000], size: 000004000000 (64.0 MB)
Partition: recovery, [00001661C000 - 00001A61C000], size: 000004000000 (64.0 MB)
Partition: devinfo, [00001A61C000 - 00001A71C000], size: 000000100000 (1.00 MB)
Partition: splash, [00001A800000 - 00001B300000], size: 000000B00000 (11.0 MB)
Partition: LOGO, [00001B300000 - 00001D300000], size: 000002000000 (32.0 MB)
Partition: DRIVER, [00001D300000 - 00001F300000], size: 000002000000 (32.0 MB)
Partition: cache, [00001F300000 - 00002F300000], size: 000010000000 (256. MB)
Partition: misc, [00002F300000 - 00002F400000], size: 000000100000 (1.00 MB)
Partition: keystore, [00002F400000 - 00002F480000], size: 000000080000 (512. KB)
Partition: config, [00002F480000 - 00002F488000], size: 000000008000 (32.0 KB)
Partition: log, [00002F488000 - 000033488000], size: 000004000000 (64.0 MB)
Partition: oem, [000033488000 - 000033588000], size: 000000100000 (1.00 MB)
Partition: limits, [000033800000 - 000033808000], size: 000000008000 (32.0 KB)
Partition: mota, [000034000000 - 000034080000], size: 000000080000 (512. KB)
Partition: dip, [000034080000 - 000034180000], size: 000000100000 (1.00 MB)
Partition: mdtp, [000034180000 - 000036180000], size: 000002000000 (32.0 MB)
Partition: syscfg, [000036180000 - 000036200000], size: 000000080000 (512. KB)
Partition: mcfg, [000036200000 - 000036600000], size: 000000400000 (4.00 MB)
Partition: lksecapp, [000036800000 - 000036820000], size: 000000020000 (128. KB)
Partition: cmnlib, [000036820000 - 000036920000], size: 000000100000 (1.00 MB)
Partition: cmnlib64, [000036920000 - 000036A20000], size: 000000100000 (1.00 MB)
Partition: keymaster, [000036A20000 - 000036B20000], size: 000000100000 (1.00 MB)
Partition: lksecappbak, [000036B20000 - 000036B40000], size: 000000020000 (128. KB)
Partition: cmnlibbak, [000036B40000 - 000036C40000], size: 000000100000 (1.00 MB)
Partition: cmnlib64bak, [000036C40000 - 000036D40000], size: 000000100000 (1.00 MB)
Partition: keymasterbak, [000036D40000 - 000036E40000], size: 000000100000 (1.00 MB)
Partition: apdp, [000037000000 - 000037040000], size: 000000040000 (256. KB)
Partition: msadp, [000037040000 - 000037080000], size: 000000040000 (256. KB)
Partition: dpo, [000037080000 - 000037082000], size: 000000002000 (8.00 KB)
Partition: logdump, [000037082000 - 00003B082000], size: 000004000000 (64.0 MB)
Partition: vm-kystore, [00003B082000 - 00003B182000], size: 000000100000 (1.00 MB)
Partition: vm-data, [00003B182000 - 00003BB82000], size: 000000A00000 (10.0 MB)
Partition: hyp, [00003C000000 - 00003C800000], size: 000000800000 (8.00 MB)
Partition: vm-system, [00003C800000 - 000040800000], size: 000004000000 (64.0 MB)
Partition: vm-linux, [000040800000 - 000042800000], size: 000002000000 (32.0 MB)
Partition: system, [000042800000 - 000119100000], size: 0000D6900000 (3.35 GB)
Partition: vendor, [000119100000 - 00015B060000], size: 000041F60000 (1.03 GB)
Partition: userdata, [00015B800000 - 000E8F7FBE00], size: 000D33FFBE00 (52.8 GB)
GPT header successfully parsed
Get firmware version
Error: Mount [log] failed PartType: FAT32
Manufacturer = OPPO
CPU Abi = arm64-v8a
Android release = 8.1.0
Page generated in 0.13781 seconds with 8 queries
