04-07-2015, 13:57 | #1 (permalink) |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,554 | Easy-JTAG Very HOT Update. v1.9.0.5 - KMVTU000LM REPAIR even totay dead emmc :) NO ANY ADDITION ACTIVATION, NO ANY ADAPTERS. LIKE USUALLY all hotest solution come free for all z3x users, 10years on market!!! Hope z3x users will repair today all bricked EMMC After 6month of playing with EMMC we have new solution for you: - KMVTU000LM-B503 [VTU00M] REPAIR - READY CONDITION TIMEOUT ERROR REPAIR - OCR READY TIMEOUT [EMMC BAD] REPAIR - TOTALLY DEAD 00FF8080 REPAIR This solution can repair 90% dead KMVTU000LM-B503 eMMC. For work with solution you just need connect 1 MAGIC Z3X-TP for force EMMC firmware emmc mode. Testpoint Location: HERE is step by step repair with screenshots! Here is Repair Manual: 1. Download latest Easy-Jtag install 2. Identify eMMC: LOG: OCR READY TIMEOUT [EMMC BAD] Done. 3. Disconnect eMMC from power lines and easy-jtag box connector (disconnect eMMC from box is important, because some voltage leakage via CMD, CLK, DAT0) 4. Make short testpoint [TP] to [GND] (solder small wire) 5. Plug eMMC power and connect Easy-Jtag box connector 6. Remove short [TP] to [GND] 7. Identify eMMC LOG: EMMC Date: 05/2005 Rev.0x56 EMMC NAME: 000000, S/N: 537986854 8. Start Custom Operation ->'SAMSUNG: eMMC Update Firmware' 9. Confirm eMMC Part Number 'KMVTU000LM-B503' LOG: Z3X EasyJtag Software ver. 1.9.0.5 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: XXXXXXXXXXXXXXXX, ,FW Ver.: 01.52 CMD Pullup Level:2052 mV CMD Active Level:2588 mV Setup firmware normal update mode, wait 2..30 sec... Success! Sending eMMC firmware... Success! Verifying eMMC firmware... Success! Flashing eMMC firmware... Success! Repairing eMMC CID... Success! eMMC firmware is updated now! Please reconnect eMMC power lines before next operation! Please don't forget to repair extCSDfrom backup! Please don't forget to configure BOOTsizes! Done. Now eMMC is alive !!! Enjoy!!! P.S. COPY PASTERS - time for copy our solution. time to wake up P.S2. Z3X users - we have lot of news for you in nearly future, be ready . Last edited by NoName®; 04-07-2015 at 22:38. |
The Following 54 Users Say Thank You to blang For This Useful Post: |
04-07-2015, 14:39 | #2 (permalink) |
No Life Poster Join Date: Oct 2009 Location: Rajasthan INDIA
Member: 1147254 Status: Offline Sonork: 100.1620677 Thanks Meter: 639 | Hello Sir @ blang What Is Mean Of This Lines: NO ANY ADDITION ACTIVATION, NO ANY ADAPTERS. LIKE USUALLY all hotest solution come free for all z3x users Hope z3x users will repair today all bricked EMMC My Question Is: I Have Z3X Box So I Can Use Easy-JTAG In New Update |
04-07-2015, 14:42 | #3 (permalink) | |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,554 | Quote:
all means in title: EASY-JTAG update. if you easy-jtag user - you no need pay for this update. | |
The Following 4 Users Say Thank You to blang For This Useful Post: |
04-07-2015, 14:47 | #4 (permalink) |
No Life Poster Join Date: Nov 2006 Location: turkey
Member: 384775 Status: Offline Sonork: 100.1605469 Thanks Meter: 159 | Z3X EasyJtag Software ver. 1.9.0.5 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: 1818031584A59CAF, ,FW Ver.: 01.52 CMD Pullup Level:2062 mV CMD Active Level:2382 mV eMMC Device Information EMMC CID : 1501005654553030300C20138686416E EMMC CSD : D02701320F5903FFF6DBFFFF8E40406C EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 04/2014 Rev.0xC EMMC NAME: VTU000 , S/N: 538150534 EMMC NAME (HEX): 56545530303000 EMMC ROM1 (Main User Data) Capacity: 15028 MB EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. Backup saved: VTU000_ 538150534_20150302_1643.extcsd later repaired log: Z3X EasyJtag Software ver. 1.9.0.5 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: 1818031584A59CAF, ,FW Ver.: 01.52 CMD Pullup Level:2062 mV CMD Active Level:2392 mV eMMC Device Information EMMC CID : 1501005654553030300C20138686416E EMMC CSD : D02701320F5903FFF6DBFFFF8E40406C EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 04/2014 Rev.0xC EMMC NAME: VTU000 , S/N: 538150534 EMMC NAME (HEX): 56545530303000 EMMC ROM1 (Main User Data) Capacity: 15028 MB EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. Backup saved: VTU000_ 538150534_20150302_1644.extcsd Done. |
The Following 3 Users Say Thank You to cemalefendi For This Useful Post: |
04-07-2015, 14:51 | #5 (permalink) |
No Life Poster Join Date: Feb 2010 Location: india. kerala.
Member: 1245320 Status: Offline Sonork: 100.1612126 Thanks Meter: 140 | cant understand testpoint conection??how can conect that/?bcz seems under emmc ic..so how can soldering???pls explain with picture... |
The Following 2 Users Say Thank You to rasheedc007 For This Useful Post: |
04-07-2015, 14:54 | #7 (permalink) | |
if you have other way - try. all in your hands, solution released. | |
04-07-2015, 15:07 | #10 (permalink) |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,554 | if skill very good, even no need remove emmc just need carefull play with strong gnd wire , but very carefull , if short GND wire to +5v under emmc - pcb can burned. |
The Following 5 Users Say Thank You to blang For This Useful Post: |
04-07-2015, 15:22 | #11 (permalink) |
Freak Poster Join Date: May 2010
Member: 1306306 Status: Offline Sonork: 240888 Thanks Meter: 36 | Verifying eMMC firmware fail: NO Error please help sir.. log : CMD Pullup Level:2145 mV CMD Active Level:2578 mV Setup firmware normal update mode, wait 2..30 sec... Success! Sending eMMC firmware... Success! Verifying eMMC firmware... Verifying eMMC firmware fail: NO Error Done. |
04-07-2015, 15:55 | #13 (permalink) | |
Product Supporter Join Date: May 2011
Member: 1569669 Status: Offline Thanks Meter: 257 | Quote:
This error: 'Verifying eMMC firmware fail: NO Error' happend because you didn't disconnect everything from eMMC (all lines : 1.8V, 2.8V, CLK, CMD, DAT0) before making short TP to GND !!!! Some current leakege apply from CMD, CLK, DAT0 box lines and eMMC goto wrong state, when disconnect only 1.8/2.8V power lines. eMMC wrong state cause 'Verifying eMMC firmware fail: NO Error' No Error - means no communication error, only firmware update error occurs. Disconnect everything from eMMC, make short TP to GND, plug eMMC power then remove TP to GND, plug into box, make sure that eMMC Identify 000000, start update firmware again. eMMC Update Firmware should be OK this time !!!!!!!!! DON'T FORGET TO REMOVE TP TO GND CONNECTION BEFORE FIRMWARE UPDATE, BECAUSE WILL BE SAME ERROR: 'Verifying eMMC firmware fail: NO Error' !!!!!!!!! Regards Viktor Last edited by vikboston; 04-07-2015 at 17:30. | |
04-07-2015, 16:04 | #14 (permalink) | |
Freak Poster Join Date: May 2014
Member: 2186335 Status: Offline Thanks Meter: 44 | THATS why I am the z3x Lover Quote:
The Following User Says Thank You to Mansour Pakdel For This Useful Post: |
04-07-2015, 16:07 | #15 (permalink) |
Member: 1569669 Status: Offline Thanks Meter: 257 | Hi, This error: 'Verifying eMMC firmware fail: NO Error' happend because you didn't disconnect everything from eMMC (all lines : 1.8V, 2.8V, CLK, CMD, DAT0) before making short TP to GND !!!! Some current leakege apply from CMD, CLK, DAT0 box lines and eMMC goto wrong state, when disconnect only 1.8/2.8V power lines. eMMC wrong state cause 'Verifying eMMC firmware fail: NO Error' No Error - means no communication error, only firmware update error occurs. Disconnect everything from eMMC, make short TP to GND, plug eMMC power then remove TP to GND, plug into box, make sure that eMMC Identify 000000, start update firmware again. eMMC Update Firmware should be OK this time !!!!!!!!! DON'T FORGET TO REMOVE TP TO GND CONNECTION BEFORE FIRMWARE UPDATE, BECAUSE WILL BE SAME ERROR: 'Verifying eMMC firmware fail: NO Error' !!!!!!!!! Regards Viktor Last edited by vikboston; 04-07-2015 at 17:30. |
The Following User Says Thank You to vikboston For This Useful Post: |
