Old 10-23-2018, 09:57   #1 (permalink)
Member: 1970633
Thanks Meter: 15
Is possible to recover data? no partition table found
Hello there! I have a wiko emmc where i try to recover data
box detect it but he say:
Operation: Find table from emmc
here is full log:
eMMC_tool Suite ver. 1.5.2.0 (release date: 06.08.2018)
Microsoft Windows 7 (64 bit) build 7601 (6.1.7601.23403)
Looking for EasyJTAG box...
EasyJTAG API ver. 2100
EasyJTAG Box Serial = 152E1C886C40EFCE
Card Serial = AAD0788C
EasyJTAG Box Firmware = 2.30
Changelog:
06.08.2018 (ver 1.5.2.0)
Fix: Bugs that have been found through your crash report
Fix: Writing ROM2 for Samsung (Write by vendor)
Fix: Freezing the program on a RandomVerify
Add: Folder for saving to Explorer (in settings)
Add: Extract from store.vol from emmc (explorer)
Add: Automatic repair of damaged store.vol when extracting (Explorer)
Add: Adding MountPoints for partitions (efs, userdata) when formatting
Add: Checking for an empty EFS before backup (Read by Vendor Samsung)
Setting interface to EasyJtag2/E-Socket
Setting bus width to 8 Bit
Setting frequence to 42 Mhz
EMMC Device Information :
EMMC CID: 11010030303447453001D1980249922B
EMMC CSD: D05E00320F5903FFFFFFFFE7924000E3
EMMC Manufacture : TOSHIBA , EMMC NAME: 004GE0 , HEX: 303034474530 , S/N: D1980249 , rev. 0x01
EMMC Manufacture ID: 0x11 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 9/2015
EMMC ROM 1 (Main User Data) Capacity: 3776 MB (0000EC000000)
EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 2048 KB (000000200000)
EMMC RPMB (Replay Protected Memory Block) Capacity: 512 KB (000000080000)
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
Extended CSD Information :
Extended CSD rev: 1.6 (MMC 4.5, MMC 4.51)
Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1)
Boot Bus Config: 0x00 , width 1bit
H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled
Supported partition features [PARTITIONING_SUPPORT]: 0x07
Device supports partitioning features
Device can have enhanced technological features in partitions and user data area
Device can have extended partitions attribute
Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: 004GE0_D1980249_20181023_105613.extcsd
EMMC Init completed.
Scanning soft partitions
Partition table not found
Get firmware version
Brand = WIKO
Manufacturer = WIKO
Model = SUNSET2
CPU Abi = armeabi-v7a
Mediatek platform = MT6572
Android release = 4.4.2
Firmware version = ALPS.KK1.MP7.V1
Firmware date = Wed Jan 6 16:49:02 CST 2016
Backup saved: 004GE0_D1980249_20181023_105627.extcsd
Vendor: Mediatek
Platform: MT6572
Searching GPT ...
GPT header is not found
Searching PMT (MediaTek) ...
Error reading at address: 000000800000 , error: -3, DATA RCV Timeout Error ... Retry #1
Error reading at address: 000000800000 , error: -3, DATA RCV Timeout Error ... Retry #2
Error reading at address: 000000800000 , error: -3, DATA RCV Timeout Error ... Retry #3
Error reading at address: 000000800000 , error: -3, DATA RCV Timeout Error ... Retry #4
Error reading at address: 000000800000 , error: -3, DATA RCV Timeout Error ... Retry #5
Too many errors. Reading has been stopped
Old 10-26-2018, 11:50   #2 (permalink)
Member: 2250995
Thanks Meter: 47
Yes Possible it is possible via Ultra Viwer i can do it
Page generated in 0.13783 seconds with 8 queries
