easy jteg gpg (old hadware) not connecting any emmc Z3X EasyJtag Software ver. 3.2.0.3 Loading eMMC GEN1 Firmware... IO: 3300 mV Box S/N: 0F0F1010BF8FEF3B, ,FW Ver.: 01.63 CMD Pullup Level:391 mV CMD Active Level:2846 mV Box IO Level:3300 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is off! Can't init device, Reason: OCR Ready Timeout Error [Check VCC or eMMC DEAD] Done. Z3X EasyJtag Software ver. 3.2.0.3 Loading eMMC GEN1 Firmware... IO: 2800 mV Box S/N: 0F0F1010BF8FEF3B, ,FW Ver.: 01.63 CMD Pullup Level:381 mV CMD Active Level:2330 mV Box IO Level:2800 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is off! Can't init device, Reason: OCR Ready Timeout Error [Check VCC or eMMC DEAD] Done. i m using this adopter with a charger https://www.5g-m.com/it/boxes-dongle...1-adapter.html |
Can't init device, Reason: OCR Ready Timeout Error [Check VCC or eMMC DEAD] means your emmc dead or external power supply problem Do one more time but this time use (cmd , clk , dato, gnd )and connect usb poswer to motherboard and check do not use 1.8 and 2.8 |
Code: Box Drivers version: 0.0.0.0, may affect on box performance |
this time trying with fully working samsung e5 but still didnt conect Compression is ON Z3X EasyJtag Software ver. 3.1.0.0 Loading eMMC GEN1 Firmware... IO: 3300 mV Box S/N: 0F0F1010BF8FEF3B, ,FW Ver.: 01.63 Warning: CMD Pullup Level (61 mV) too low , check cables etc.! CMD Active Level:1515 mV Box IO Level:3300 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is off! Can't init device, Reason: CMD Timeout Error Done. |
Use 2 100ohm resistor 1st cmd to 1.8v 2nd dato to 1.8 And try again |
Compression is ON Z3X EasyJtag Software ver. 3.1.0.0 Loading eMMC GEN1 Firmware... IO: 3300 mV Box S/N: 0F0F1010BF8FEF3B, ,FW Ver.: 01.63 CMD Pullup Level:464 mV CMD Active Level:2444 mV Box IO Level:3300 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is ON! ---------- eMMC Device Information ---------- eMMC CID : 15010056325730304D00568953538084 eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 08/2013 Rev.0x0 eMMC NAME: V2W00M , S/N: 1451840339 eMMC NAME (HEX): 56325730304D IC Name: Samsung , KMV2W000LM-B506/32GB @FBGA169 EMMC ROM1 (Main User Data) Capacity: 29820 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 512 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.7 (MMC 5.0) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: V2W00M_1451840339_20180929_2021.extcsd Blocks Reading Error (0x0 , 1 , Reason: CMD CRC Error ) |
n900 repair done but facing problem in j200g phon received in kernal enforcing and binary blocked by frp i try to flesh but faild.i try to flesh in octopuse all ways pit file error this is the log from phon with emmc ---------- eMMC Device Information ---------- eMMC CID : 150100464E31324D4200AAA9D060A2FE eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 10/2015 Rev.0x0 eMMC NAME: FN12MB , S/N: 2863255648 eMMC NAME (HEX): 464E31324D42 IC Name: Samsung , KMFN10012M-B214/8GB @BGA221 EMMC ROM1 (Main User Data) Capacity: 7456 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 512 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.7 (MMC 5.0) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: FN12MB_2863255648_20180930_1244.extcsd Partition table scan: GPT: not present Done. Z3X EasyJtag Software ver. 3.1.0.0 Skip loading eMMC Addon Firmware CMD Pullup Level:412 mV CMD Active Level:1784 mV Length limit is enabled! Input file : C:\Users\joni\Downloads\Compressed\SAMSUNG_SM-J200G\boot1.bin Writing 0000100000 bytes to 0000000000... ROM1 (USER ROM) Full Verify Enabled! Done, time taken: 4 sec. Average Write Speed: 237 kB/s Z3X EasyJtag Software ver. 3.1.0.0 Skip loading eMMC Addon Firmware CMD Pullup Level:412 mV CMD Active Level:1784 mV Input file : C:\Users\joni\Downloads\Compressed\SAMSUNG_SM-J200G\boot2.bin Writing 0000400000 bytes to 0000000000 ...ROM2 (BOOT1 ROM) Full Verify Enabled! Done, time taken: 15 sec. Average Write Speed: 270 kB/s |
i have same error Box Drivers version: 0.0.0.0, may affect on box performance. Jtag Classic suite ver 3.2.0.3 any ideea is welcome |
EasyJtag Suite Classic ver.: 3.2.0.3 / wxWidgets 3.1.0-W-U started. Box Drivers version: 0.0.0.0, may affect on box performance. same |
