12-30-2019, 22:11 | #1 (permalink) |
Moderator Join Date: Jan 2008 Location: <jeddah al saudia> Age: 36
Member: 668050 Status: Offline Sonork: 100.1656307 Thanks Meter: 991 | Dub-lx1 frp remove done Reading info.....OK Device Model: DUB-LX1 Device Firmware: DUB-LX1 8.2.0.151(C185) Device Lock: Image is origin | Verify mode is enforcing | Check root info is safe | Lock state is lock | Root State: UNROOT Waiting for server.....OK Reading data.....OK Posting data to server.....OK Waiting for server response.....OK Unlocking device.....Security is not supported Operation {Reset FRP using server} ID: B69FD03A897F83332BA716FCDF7D6957 Elapsed time 00:20 -- Version 1.7.9.1 =============== NO DOWNGRADE NO TRICKS WORK NO BOARD SOFTWARE WRITTEN ===========FINALLY EASY JTAG VIA EDL=========== PRESS REMOVE FRP HS-QUALCOM AUTO SELECT LOADER Operation: Remove FRP Search HS-USB QDLoader 9008 devices ... Qualcomm HS-USB QDLoader 9008 (COM67) is connected Connect to Sahara ... Connection with Sahara was successful Serial: 0x00000000924A7535 HW_ID: 0x0009A0E100150065 HASH: 0x6BC369511DA9CADB3A7AF61574F89DB385003D6241BDD1FF 573DBA61BF6AE119 SBL_SW: 0x0000000000000000 CPU: Qualcomm Snapdragon 450 (SDM450) Internal loader found Sending FlashLoader. Please, wait ... FlashLoader was successfully uploaded to the device. Connect to FlashLoader ... EMMC NAME: GP6BMB Vendor: SAMSUNG S/N: 82419BA2 EMMC ROM 1 (Main User Data) Capacity: 59640 MB (000E8F800000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) Connection with FlashLoader was successful Searching GPT ... GPT header is found and is valid GPT header successfully parsed FRP signature found (partname: frp) Erasing FRP partition ... If the device does not load for a long time - try wiping the data in the recovery All done |
The Following 4 Users Say Thank You to chand_gee For This Useful Post: |
01-02-2020, 17:15 | #2 (permalink) |
Member: 668050 Status: Offline Sonork: 100.1656307 Thanks Meter: 991 | AGAIN 1 MORE ========== Checking fastboot device.....OK Reading info.....OK Device Model: DUB-LX1 Device Firmware: DUB-LX1 8.2.0.151(C185) Device Lock: Image is origin | Verify mode is enforcing | Check root info is safe | Lock state is lock | Root State: UNROOT Waiting for server.....OK Reading data.....OK Posting data to server.....OK Waiting for server response.....OK Unlocking device.....Security is not supported Operation {Reset FRP using server} ID: 5692215BFE30422907803B16CEF73B29 Elapsed time 00:13 -- Version 1.7.9.1 ================ Operation: Remove FRP Search HS-USB QDLoader 9008 devices ... Qualcomm HS-USB QDLoader 9008 (COM68) is connected Connect to Sahara ... Connection with Sahara was successful Serial: 0x00000000E6FE3CA3 HW_ID: 0x0009A0E100150065 HASH: 0x6BC369511DA9CADB3A7AF61574F89DB385003D6241BDD1FF 573DBA61BF6AE119 SBL_SW: 0x0000000000000000 CPU: Qualcomm Snapdragon 450 (SDM450) Internal loader found Sending FlashLoader. Please, wait ... FlashLoader was successfully uploaded to the device. Connect to FlashLoader ... EMMC NAME: hB8aP> Vendor: SKHYNIX S/N: 02980C78 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) Connection with FlashLoader was successful Searching GPT ... GPT header is found and is valid GPT header successfully parsed FRP signature found (partname: frp) Erasing FRP partition ... If the device does not load for a long time - try wiping the data in the recovery All done |
The Following User Says Thank You to chand_gee For This Useful Post: |
01-19-2020, 15:15 | #3 (permalink) | |
Junior Member Join Date: Aug 2006 Location: EGYPT Age: 43
Member: 340450 Status: Offline Thanks Meter: 4 | Quote:
nice work ty for sharing bro | |
