12-16-2014, 14:25 | #48 (permalink) |
Freak Poster Join Date: Oct 2008 Location: Romania -city:BUZAU
Member: 887688 Status: Offline Sonork: talibans Thanks Meter: 42 | sm-g7102 dead boot i make card with "Samsung_SM-G7102_G7102XXUBNG4_GPT_UEFI_4.4.2.zbin" inser this card in phone insert jig in phone usb conector and nothing somebody can explain how work this update ? need torevive phone,please help |
12-16-2014, 16:54 | #49 (permalink) |
No Life Poster Join Date: Mar 2007 Location: on moon right now !
Member: 469192 Status: Offline Thanks Meter: 48 | i tried also with 3 phones i create zbin sd card recovery and use hand to jig usb nothing change no download mode show in dead boot phone i used different kind of sd 4 8 16 32 GB same same as the manual show there is nothing to do only to choose the last (newer) file and create it in sd card then only jig if there is more please tell |
12-17-2014, 16:44 | #52 (permalink) | |
Product Supporter Join Date: Mar 2005 Location: China
Member: 129885 Status: Offline Sonork: 100:1603514 Thanks Meter: 6,202 | Quote:
TP Location are in attach. | |
12-19-2014, 18:39 | #58 (permalink) |
Member: 469192 Status: Offline Thanks Meter: 48 | so its not only but sd card in and force download mode by jig or hand we have to make something like test point to complete the job can u explain which phone we have to make short and in which case |
12-19-2014, 19:19 | #59 (permalink) | |
12-20-2014, 10:12 | #60 (permalink) |
Product Supporter Join Date: May 2011
Member: 1569669 Status: Offline Thanks Meter: 257 | Hi, Short instruction for SM-G7102 SD Card Repair: 1. Use SD Card Imaging Toll plugin and write .zbin file to SD Card. Only SDHS/SDXC Cards are compatible with phone's boot !!! 2. Plug SD Card into phone. 3. Solder short wire to CMD test point (look emmc_direct pinout jpeg at support). Make short this wire to GND. 4. Plug DM Jig into USB ,if available, than insert fully charged battery, in 25 sec Download Mode appear on the screen. If DM Jig is not available, insert fully charged battery, press and hold HOME + VOL DOWN buttons, than press PWR button, in 3 sec release PWR button and keep holding HOME + VOL DOWN buttons, in 25 sec phone Download Mode appear on the screen. 5. Don't turn off phone, disconnect CMD test point from GND, plug USB cable from PC to phone. 6. Use ODIN to flash phone's firmware, use Re-Partition option to write PIT (available on the support SD Card Repair folder). Notes: 1. In some cases (when phone fully bricked) short between CMD testpoint and GND are not required. 2. CMD testpoint also can be shorted to 2.8V instead to GND by tweezers (resistor between CMD and 2.8V), but this is inconvenient to keep LCD connected. 3. When press and keep PWR button more than 5 sec, phone will not boot from SD Card, because pressing PWR > 5 sec turn off power, like PC power button. 4. All .zbin from support are tested. 5. When DM Jig is not plugged and HOME + VOL DOWN buttons are not holded after pressing PWR button and releasing in 3 sec, phone must show logo in 25 sec "Samsung SM-G7102" and stuck. 6. For advanced users possible to use Samsung Download Jig cable with USB to UART IC or microUART Jig cable with Samsung Box and UART terminal at baud 115200 to see SD Repair Boot process LOG: ... [15530] Failure getting OCR response from MMC Card [15530] MMC card failed to respond, try for SD card [15600] SET BUS WIDTH [15600] Done initialization of the card ... Don't forget to post results for success SD Card Repair ! Last edited by vikboston; 12-20-2014 at 10:58. |
The Following 2 Users Say Thank You to vikboston For This Useful Post: |
