05-02-2015, 06:41 | #19 (permalink) | |
Freak Poster Join Date: Jun 2007 Location: Chittagong, Bangladesh, Age: 41
Member: 537240 Status: Offline Sonork: 100.1660416 Thanks Meter: 233 | Quote:
05-02-2015, 08:34 | #20 (permalink) |
Freak Poster Join Date: Oct 2014 Location: India
Member: 2282226 Status: Offline Thanks Meter: 52 | contact your nearest reseller : http://forum.gsmhosting.com/vbb/f672...llers-1573137/ |
05-02-2015, 15:25 | #22 (permalink) |
No Life Poster Join Date: Apr 2006 Location: INDIA Age: 50
Member: 256461 Status: Offline Sonork: 100.1608049 Thanks Meter: 90 | Good update. What about the test points.Can we access it from jtag also?.or only through emmc test points. And you have mentioned about:Support MBR disk partitioning ( HTC Method) can we repair partitions in htc devices such as htc one m7 which were damaged after easy repair with this file:HTC_ONE_M7_PN0712000_SPL1_56_boot_v1_00 pls elaborate. |
The Following User Says Thank You to sajidmirza For This Useful Post: |
05-03-2015, 09:20 | #23 (permalink) |
No Life Poster Join Date: Jul 2002 Location: Hungary, Győr Age: 46
Member: 13569 Status: Offline Sonork: 1619596 Thanks Meter: 72 | It will be the best tool if the remaining functions (Rename, Delete, Import File) will be active. It could be very usefull with Mio Moov navigators, when the usb connection is broken due to AppStartupSec.exe deletion/removation. It is easy to rename back or import the right file and the navigator is back to working via USB connection. Waiting for next update. Last edited by dazexy; 05-03-2015 at 11:19. |
05-12-2015, 16:43 | #28 (permalink) |
No Life Poster Join Date: Apr 2005 Location: india
Member: 135945 Status: Offline Thanks Meter: 85 | can we connect a phone which hangs on startup and read the emmc ? or need to connect jtag connection to the emmc to read the data? pls infom? i have a zte v967s of my friend and he wants the data before flashing the phone to revive it! WBR ReyTech. |
05-13-2015, 10:28 | #30 (permalink) |
Freak Poster Join Date: Jan 2011 Location: Sant'Antioco (Ci) Italy
Member: 1483775 Status: Offline Thanks Meter: 22 | I'm triing to use it but not work. i see all files but when i try to open it, files seems damaged. now i'm triing another tool with the dump |
