Old 07-14-2016, 03:19   #1 (permalink)
kothamamun's Avatar
Member: 2556542
Thanks Meter: 1,790
j500g j500h j500f no service problem solve
J500g bypass msl error solve
Originally Posted by mrkey2014
WRITE CERT EROR BYPAS MSL....
Operation: Write CERT
Selected model: SM-J500G
Selected port: COM66 SAMSUNG Mobile USB Serial Port
Software version: 25.8
Checking certificate file... OK
KEY ID: 0338
Waiting ADB device... OK
Reading phone info...
Model: SM-J500G
Android version: 5.1.1
Product code: Not Active
Phone version: J500GXXU1APA2
PDA version: J500GXXU1APA2
CSC version: J500GOLB1AOK2
CSC country code: INDONESIA
CSC sales code: XID
HW version:
Phone S/N:
Modem board: MSM8916
RF cal date: 2015.09.09
IMEI:
Initialization AT RIL... OK
Bypass MSL... error (2)
First reset MSL
Done with Samsung Tool PRO v.25.8
BACKUP INSTRUCTIONS:
Phone must be rooted!
If the software can't root the phone automatically,
then you must root your device manually.
1. Power on the phone.
2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options',
go to 'Settings'-'Developer options' and enable 'USB debugging'.
3. Connect the phone to PC with USB cable, install drivers if needed.
4. Select device in ADB settings.
5. Press 'Read EFS' button to read backup or 'Write EFS' to restore or
press 'Write CERT' to restore certificates.
To backup/restore QCN, phone diagnostic port must be enabled.
2. Type *#0808# and select 'DM+MODEM+ADB'.
3. Type *#9090# and select 'DM/DUN over HSIC'.
Or use 'Activate Diag' function from 'Repair' tab.
4. Connect phone to PC with USB cable, install drivers if needed.
5. Select diagnostic port in port settings.
6. Press 'Read QCN' button to read NV backup or 'Write QCN' to restore.
Selected port:
KEY ID: 0338
Model: SM-J500G
Phone version: J500GXXU1AOJ2
PDA version: J500GXXU1AOJ1
CSC version: J500GOLB1AOJ1
CSC country code: THAILAND
CSC sales code: THL
HW version:
Phone S/N: RV1GB14K39K
RF cal date: 2015.11.20
IMEI:
Bypass MSL... OK
Checking for compatible phone and cert... OK
Phone KEY ID: 0338
Writing CERT... OK
Checking CERT status... OK
Rebooting phone... OK
The Following 3 Users Say Thank You to kothamamun For This Useful Post:
Old 11-01-2016, 07:45   #2 (permalink)
Member: 742628
Thanks Meter: 6
Cert
Sir J500G no servis
Cert file plz
Old 11-01-2016, 09:40   #3 (permalink)
Member: 805738
great job fo z3x pro
Old 01-27-2017, 09:31   #4 (permalink)
Member: 2377174
Thanks Meter: 6
J500G no servis
Cert file plz
The Following User Says Thank You to klatredip For This Useful Post:
Old 02-22-2017, 11:24   #5 (permalink)
Member: 805738
j500g no service prob
i need good cert file plz..
The Following User Says Thank You to mel1989 For This Useful Post:
Old 10-17-2017, 20:26   #6 (permalink)
Member: 1708253
just read n write...? No need file?
Page generated in 0.20357 seconds with 8 queries
