Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Easy-Jtag
Old 07-25-2017, 12:15   #46 (permalink)
Member: 1112585
Sonork: 100.1645028
Thanks Meter: 84
Originally Posted by vorasalim View Post
the program can't start because libusb0.dll is missing from your computer
when open spi exe
thanks
https://sourceforge.net/projects/lib...eases/1.2.6.0/
Old 07-28-2017, 07:46   #47 (permalink)
Member: 1933433
Thanks Meter: 2
please help team easy jtag
DESIER 610 DEAD BOOT REPAIR ERRRO HOW TO SOLVE THIS HELP
Compression is ON
Z3X EasyJtag Software ver. 2.6.0.1
Loading eMMC GEN1 Firmware... IO: 2800 mV
Box S/N: xxxxxxxxxxxxxx, ,FW Ver.: 01.60
CMD Pullup Level:2103 mV
CMD Active Level:2598 mV
Box IO Level:2800 mV
CLK Rate:14000 khz
HiPower mode is ON!
---------- eMMC Device Information ----------
EMMC CID : 90014A4838473165050401F2297F711C
EMMC CSD : D02701320F5903FFFFFFFFEF8A4040D2
EMMC Manufacturer ID: 0090 , OEM ID: 014A
EMMC Date: 07/2014 Rev.0x4
EMMC NAME: H8G1e , S/N: 32647551
EMMC NAME (HEX): 48384731652000
EMMC ROM1 (Main User Data) Capacity: 7456 MB
EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB
EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
EMMC Password Locked: No
Extended CSD rev 1.7 (MMC 5.0)
Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured.
Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00.
H/W reset function [RST_N_FUNCTION]: 0x01
High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000]
Partitioning Support [PARTITIONING_SUPPORT]: 0x07
Device support partitioning feature
Device can have enhanced tech.
Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: H8G1e _ 32647551_20170728_1239.extcsd
Done.
Checking NAND Image : C:\Users\********** 1\Desktop\htc desire 610 dead boot repair\HTC_Desire_610_emmc_dump_1GB\HTC_Desire_610 _emmc_dump_1GB\HTC_Desire_610_emmc_dump_1GB.bin
Autodetected RAW data
Warning! Disk size is smaller than the main header indicates! Loading
Caution: invalid backup GPT header, but valid main header!
Warning! Error 22 reading partition table for CRC check!
Warning! One or more CRCs don't match. You should repair the disk!
Partition table scan:
GPT: damaged
Caution: Found protective or hybrid MBR and corrupt GPT.
Partition info successfully found
Linux partitions is not found in image...
File successefuly loaded!
Real (Hardware) Disk/Image size: 200000 sectors 1024.0 MiB
Soft (Partitioned) Disk/Image size: E87FDD sectors 7.3 GiB
Logical sector size: 0x200 bytes
Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20
First usable sector: 34
Last usable sector: 15237119
Processing file...C:\Users\********** 1\Desktop\htc desire 610 dead boot repair\HTC_Desire_610_emmc_dump_1GB\HTC_Desire_610 _emmc_dump_1GB\HTC_Desire_610_emmc_dump_1GB.bin
ROM2 Are not selected , skip writing ROM2
ROM3 Are not selected , skip writing ROM3
Writing as RAW data
Skip loading eMMC Addon Firmware
CMD Pullup Level:2083 mV
CMD Active Level:2371 mV
Input file : C:\Users\********** 1\Desktop\htc desire 610 dead boot repair\HTC_Desire_610_emmc_dump_1GB\HTC_Desire_610 _emmc_dump_1GB\HTC_Desire_610_emmc_dump_1GB.bin
Writing 0040000000 bytes to 0000000000... ROM1 (USER ROM)
Write Block Failed, Reason: Write Block Verify Error
Done.
Done with error(s)
Old 07-28-2017, 07:48   #48 (permalink)
Member: 1933433
Thanks Meter: 2
Gpt damage how solve this . Gide step by step
Old 07-28-2017, 07:50   #49 (permalink)
Member: 1933433
Thanks Meter: 2
Backup saved: H8G1e _ 32647551_20170728_1249.extcsd
Caution: invalid main GPT header, but valid a backup header!
Warning! Main and backup partition tables differ!n
GPT: damaged
Real (Hardware) Disk/Image size: E90000 sectors 7.3 GiB
Soft (Partitioned) Disk/Image size: E8FFE6 sectors 7.3 GiB
Disk identifier (GUID): 00000000-0000-0000-0000-000000000000
First usable sector: 13
Last usable sector: 15269875
Found Data areas (firmware parts) count is: 0
------ Android information ------
Done.
READ SOFT PARTITION INFO LIK E THIS
Old 07-29-2017, 02:31   #50 (permalink)
Member: 2491104
Thanks Meter: 8
pls update for samsung g930a s7 boot repair
Old 07-29-2017, 18:47   #51 (permalink)
Member: 2076643
Sonork: 100.1650096
Thanks Meter: 53
http://s1.postimg.org/fc5s43k1r/rom1.png
Old 07-29-2017, 18:49   #52 (permalink)
Member: 2076643
Sonork: 100.1650096
Thanks Meter: 53
Old 07-31-2017, 19:36   #53 (permalink)
alamtelecom458's Avatar
Member: 2006027
Sonork: 1645658
Thanks Meter: 28
plz add asus Z010d Boot reapir in next update medusa alredy suport but not suport in Easy jtag
Sent from my SM-J710F using Tapatalk
Old 08-01-2017, 23:30   #54 (permalink)
NoName®'s Avatar
Member: 129885
Sonork: 100:1603514
Thanks Meter: 5,790
What is medusa ?????????????
Old 08-02-2017, 18:16   #55 (permalink)
Member: 2076643
Sonork: 100.1650096
Thanks Meter: 53
Old 08-03-2017, 02:03   #56 (permalink)
Member: 840780
Thanks Meter: 11
solution for libusb error
1. download from link- https://sourceforge.net/projects/lib...e=typ_redirect
2. unzip
3. open bin folder
4. run inf wizard
5. install
6. run spi flasher.
done.
edit: In above after step 5, select jtag from list.
Old 08-04-2017, 12:52   #57 (permalink)
Member: 2006027
Sonork: 1645658
Thanks Meter: 28
octuplus Jtag
Old 08-05-2017, 13:53   #58 (permalink)
Member: 2744375
hi im new here please welcome me
how much this box i want to buy one ..
Old 08-06-2017, 23:08   #59 (permalink)
spagman's Avatar
Member: 1783314
Sonork: 100.1620532
Thanks Meter: 127
is the Easy JTAG Single Package Repair only for emmc / ISP repair ? Is there a way to make JTAG repair packages ? ( through JTAG connection) Thank you!
The Following User Says Thank You to spagman For This Useful Post:
Old 08-17-2017, 05:20   #60 (permalink)
Member: 1825716
Thanks Meter: 4
Add to support pinout SM-J510FN, SM-A310F. Other programmers already have these pinouts and even dumps.
Page generated in 0.38354 seconds with 8 queries
