12-28-2017, 02:35 | #32 (permalink) | |
Insane Poster Join Date: Jun 2008 Location: UK-PL
Member: 796570 Status: Offline Thanks Meter: 26 | Quote:
Message strictly lead to jpg file where there should be not problem with that ! Also If has running any apps in background especially any antyvirus, close them ! As first check maybe other source of download or try install that same package at other PC ! | |
12-29-2017, 01:17 | #34 (permalink) |
Major Poster Join Date: Feb 2002 Location: POLAND
Member: 9571 Status: Offline Thanks Meter: 7 | Easy Jtag Plus Box does not work Direct_eMMC_ODIN? Hi, EasyJTAG Classic Suite v2.9.0.0 Easy Jtag Plus Box does not work Direct_eMMC_ODIN? Shows: "host need a newest API version" After several attempts: eMMC are not detected, Open USB RETURNED 202 Easy Jtag works correctly. Motherboard SAMSUNG A500FU What should you do to make Direct_eMMC_ODIN work? Last edited by Bodek; 12-29-2017 at 01:27. Reason: gsmleszno.pl/z3x/host need a newest API version.png |
The Following User Says Thank You to Bodek For This Useful Post: |
12-29-2017, 11:01 | #35 (permalink) | |
No Life Poster Join Date: Sep 2006 Location: ---> Hope
Member: 355782 Status: Offline Thanks Meter: 1,265 | Samsung G532G boot repair done with Easy Jtag Plus Quote:
01-15-2018, 13:12 | #41 (permalink) |
Member: 796570 Status: Offline Thanks Meter: 26 | this same error burt works after comp. change Here is log from that same situation Problem signature: Problem Event Name: APPCRASH Application Name: EasyJtag.exe Application Version: 2.9.0.0 Application Timestamp: 72657669 Fault Module Name: StackHash_a317 Fault Module Version: 6.1.7601.19050 Fault Module Timestamp: 563259ff Exception Code: c0000374 Exception Offset: 00008518 OS Version: 6.1.7601.2.1.0.256.1 Locale ID: 2057 Additional Information 1: a317 Additional Information 2: a317a5c8ecf496886644623ef53704b4 Additional Information 3: 3ac2 Additional Information 4: 3ac217a8f0dc8c07f625f1c24e46047a OS: Windows 7 Pro 32bit CPU: Core 2 Duo E7500 RAM: 4GB DDR3 GFX: Intel Q45 When change compability setting on compability tab to Win Xp SP3 and where possible set admin priviliges and after that soft display message about error but gone after click OK and actually soft works ... react... still dont have time to ressurect something but soon will test it .... |
01-21-2018, 17:52 | #45 (permalink) |
Freak Poster Join Date: Mar 2011 Location: Chin
Member: 1531030 Status: Offline Sonork: Yahoo_Akm Thanks Meter: 118 | Deat Means (Release_v2.9.0.0+1) Not Working Properly ver2.5.0.9 Better Speed Then New versions,Many bugs Old Box Users. Last edited by Saffu~A.; 01-21-2018 at 18:01. |
