Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Easy-Jtag
Old 04-11-2018, 23:10   #46 (permalink)
otherboy123's Avatar
Member: 2006794
Sonork: 100.1664636
Thanks Meter: 121
nand support is for ipad and iphone
Old 04-12-2018, 05:58   #47 (permalink)
rico_deep's Avatar
Member: 159757
Thanks Meter: 430
Bug on eMMC HW Partition
Compression is ON
Z3X EasyJtag Software ver. 2.9.0.2
Loading eMMC GEN1 Firmware... IO: 2800 mV
Box S/N: TresMarias, ,FW Ver.: 01.62
CMD Pullup Level:1794 mV
CMD Active Level:2289 mV
Box IO Level:2800 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
HiPower mode is off!
---------- eMMC Device Information ----------
EMMC CID : 90014A48344732611101B4A3EC8BA242
EMMC CSD : D02701320F5903FFFFFFFFEF8A4040D2
EMMC Manufacturer ID: 0090 , OEM ID: 014A
EMMC Date: 10/2015 Rev.0x1
EMMC NAME: H4G2a , S/N: 3030641803
EMMC NAME (HEX): 48344732612000
EMMC ROM1 (Main User Data) Capacity: 3728 MB
EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB
EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
EMMC Password Locked: No
Extended CSD rev 1.6 (MMC 4.5)
Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1)
Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x48.
H/W reset function [RST_N_FUNCTION]: 0x01
High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00004000]
Partitioning Support [PARTITIONING_SUPPORT]: 0x07
Device support partitioning feature
Device can have enhanced tech.
Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: H4G2a _3030641803_20180412_1153.extcsd
Done.
Running:JEDEC: Partitions config burn...
Skip loading eMMC Addon Firmware
CLK Rate:21000 kHz
GP Multiplier: 800000, 8192 Kb, 8Mb
Partition configuration:
No enhanced user data area
User partition write reliability: off
No GP1 partition
GP1 write reliability: on
No GP2 partition
GP2 write reliability: on
No GP3 partition
GP3 write reliability: on
No GP4 partition
GP4 write reliability: on
All GP Partitions are 0 set size of at least one GP Partition
HW Parts Config Fail.
Done on Easy Jtag eMMC Tool Suite V1.4.9.0
CMD Pullup Level: 1773 mV
CMD Active Level: 2279 mV
EMMC Device Information :
EMMC CID: 90014A48344732611101B4A3EC8BA242
EMMC CSD: D02701320F5903FFFFFFFFEF8A4040D2
EMMC Manufacture Name: SKHYNIX , EMMC NAME: H4G2a , EMMC NAME (HEX): 483447326100 , S/N: B4A3EC8B , rev. 0x01
EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Manufacture Date: 10/2015
EMMC ROM 1 (Main User Data) Capacity: 3728 MB (0000E9000000)
EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000)
Extended CSD Information :
Extended CSD rev: 1.6 (MMC 4.5, MMC 4.51)
Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1)
Boot Bus Config: 0x00 , width 1bit
H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled
Supported partition features [PARTITIONING_SUPPORT]: 0x07
Device supports partitioning features
Device can have enhanced technological features in partitions and user data area
Device can have extended partitions attribute
Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: H4G2a_B4A3EC8B_20180412_115419.extcsd
EMMC Init completed.
Operation: Changing GP sizes (final write) ...
GP1 size: 0 MB , WR_REL: 1 , ENH 1
GP1 size: 0 MB , WR_REL: 1 , ENH 0
Successfully
Reconnect all eMMC Lines [POWER, CMD, CLK, DAT0] to finalize operation
After reconnect, make sure that the size of ROM1 has been changed.
The Following 2 Users Say Thank You to rico_deep For This Useful Post:
Old 04-12-2018, 06:40   #48 (permalink)
bijoychowdry's Avatar
Member: 1984655
Sonork: 119.30.39.25
Thanks Meter: 54
blang
symphony mobile add plz bangladesh
The Following User Says Thank You to bijoychowdry For This Useful Post:
Old 04-12-2018, 13:03   #49 (permalink)
Member: 1451558
Thanks Meter: 21
EasyJtag Classic v2.9.0.2 entry point not found error
Old 04-12-2018, 13:05   #50 (permalink)
LEENO's Avatar
Member: 38084
Thanks Meter: 92
Originally Posted by recan21 View Post
here is J510FN pinout
https://ibb.co/gTKyRc
only under emmc?
Leeno
Old 04-12-2018, 16:25   #51 (permalink)
Member: 2650126
Thanks Meter: 36
same with me good report
Sent from my Mi 4i using Tapatalk
Old 04-12-2018, 16:30   #52 (permalink)
Member: 2650126
Thanks Meter: 36
Originally Posted by juliusorbiso View Post
oppo a11w and oppo r831k and r1001 error 4032 in flashing after jtag repair process.
any idea about this problem?
before it will flash success but cannot turns on only vibrate. then i decide to repair in z3x jtag success in jtag repair process but when im going to reflash using flasher it will show error 4032 even the same file ive used it before.
dont post here .please make a new thread !!!
nb . im always done repair oppo r1001 r831 r831k r827 r1201 a11w by easy jtag . no error 4032
Old 04-12-2018, 16:34   #53 (permalink)
Member: 2226456
Sonork: jerrenn
Thanks Meter: 77
please add nand memory isp for v2 isp adpater
Old 04-13-2018, 08:45   #54 (permalink)
Member: 1451558
Thanks Meter: 21
EasyJtag v2.9.0.1 working in xp sp3 but EasyJtag Classic v2.9.0.2 not working in xp sp3 error entry point not found EasyJtag Classic v2.9.0.2 working in windows 7
Old 04-15-2018, 11:33   #55 (permalink)
mutunmobile's Avatar
Member: 570193
Thanks Meter: 31
good update blang sir....
Old 04-16-2018, 12:19   #56 (permalink)
Member: 513870
sorry! but can't download. shell or browse can't download it. please fix link!
notthing found in web!
Old 04-16-2018, 17:11   #57 (permalink)
Member: 1971074
Thanks Meter: 11
please fix fimware box
box fimware b2.22 cant open samsung tool pro 31.3 if have activated on card.
when inset card in dongle,samsung tool pro 31.3 is ok
Old 04-16-2018, 22:48   #58 (permalink)
Member: 1314806
Sonork: 100.1000
Thanks Meter: 77
4/16/2018 12:27:08 PM> Looking for EasyJTAG box...
4/16/2018 12:27:08 PM> EasyJTAG API ver. 2022
4/16/2018 12:27:08 PM> Setting IO Levels to 1.8V
4/16/2018 12:27:08 PM> Setting frequence to 24 Mhz
4/16/2018 12:27:08 PM> EasyJTAG Box Serial = 7B3FF048XXXX
4/16/2018 12:27:09 PM> Setting interface to EasyJtag2/ISP_HiPower
4/16/2018 12:27:09 PM> Setting bus width to 1 Bit
4/16/2018 12:27:09 PM> HiPower mode is ON
4/16/2018 12:27:09 PM> Setting frequence to 24 Mhz
4/16/2018 12:27:09 PM> CMD Pullup Level: 1727 mV
4/16/2018 12:27:09 PM> CMD Active Level: 1826 mV
4/16/2018 12:27:09 PM> eMMC Init returned = 0
4/16/2018 12:27:09 PM> EMMC Device Information :
4/16/2018 12:27:09 PM> EMMC CID: FE014E50314A39354B1350AD4D78523D
4/16/2018 12:27:09 PM> EMMC CSD: D07F01320F5913FFFFFFFFEF924000A3
4/16/2018 12:27:09 PM> EMMC Manufacture Name: MICRON , EMMC NAME: P1J95K , EMMC NAME (HEX): 50314A39354B , S/N: 50AD4D78 , rev. 0x13
4/16/2018 12:27:09 PM> EMMC Manufacture ID: 0xFE , OEM ID: 0x4E , Device Type: BGA (Discrete embedded) , Manufacture Date: 5/2015
4/16/2018 12:27:09 PM> EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000)
4/16/2018 12:27:09 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
4/16/2018 12:27:09 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000)
4/16/2018 12:27:09 PM> EMMC Permanent Write Protection: No
4/16/2018 12:27:09 PM> EMMC Temporary Write Protection: No
4/16/2018 12:27:09 PM> Extended CSD Information :
4/16/2018 12:27:09 PM> Extended CSD rev: 1.6 (MMC 4.5, MMC 4.51)
4/16/2018 12:27:09 PM> Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area)
4/16/2018 12:27:09 PM> Boot Bus Config: 0x00 , width 1bit
4/16/2018 12:27:09 PM> H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled
4/16/2018 12:27:09 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07
4/16/2018 12:27:09 PM> Device supports partitioning features
4/16/2018 12:27:09 PM> Device can have enhanced technological features in partitions and user data area
4/16/2018 12:27:09 PM> Device can have extended partitions attribute
4/16/2018 12:27:09 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
4/16/2018 12:27:09 PM> Backup saved: P1J95K_50AD4D78_20180416_122709.extcsd
4/16/2018 12:27:09 PM> EMMC Init completed.
4/16/2018 12:27:10 PM> Opening file: C:\Users\kopito\Desktop\COREPRIMELTE_EUR_OPEN.pit
4/16/2018 12:27:10 PM> Pit: COREPRIMELTE_EUR_OPEN.pit
4/16/2018 12:27:10 PM> Entry count: 31
4/16/2018 12:27:10 PM> The size of the last section has been updated
4/16/2018 12:30:06 PM> Selected file: C:\Users\kopito\Desktop\SM-G360F_1_20170615153000_7e184c4f8n_fac\BL_G360FXXS1 BQD2_CL953652_QB13119115_REV00_user_low_ship_MULTI _CERT.tar.md5
4/16/2018 12:30:06 PM> BL_G360FXXS1BQD2_CL953652_QB13119115_REV00_user_lo w_ship_MULTI_CERT.tar.md5
4/16/2018 12:30:06 PM> The list of files in the firmware:
4/16/2018 12:30:06 PM> aboot.mbn
4/16/2018 12:30:06 PM> sbl1.mbn
4/16/2018 12:30:06 PM> rpm.mbn
4/16/2018 12:30:06 PM> tz.mbn
4/16/2018 12:30:06 PM> hyp.mbn
4/16/2018 12:30:06 PM> non-hlos.bin
4/16/2018 12:30:06 PM> sec.dat
4/16/2018 12:30:08 PM> Selected file: C:\Users\kopito\Desktop\SM-G360F_1_20170615153000_7e184c4f8n_fac\AP_G360FXXS1 BQD2_CL953652_QB13119115_REV00_user_low_ship_MULTI _CERT.tar.md5
4/16/2018 12:30:08 PM> AP_G360FXXS1BQD2_CL953652_QB13119115_REV00_user_lo w_ship_MULTI_CERT.tar.md5
4/16/2018 12:30:08 PM> The list of files in the firmware:
4/16/2018 12:30:08 PM> boot.img
4/16/2018 12:30:08 PM> recovery.img
4/16/2018 12:30:08 PM> system.img.ext4
4/16/2018 12:30:08 PM> persist.img.ext4
4/16/2018 12:30:11 PM> Selected file: C:\Users\kopito\Desktop\SM-G360F_1_20170615153000_7e184c4f8n_fac\CP_G360FXXS1 BQA2_REV00_CL1981445_QB5541753.tar.md5
4/16/2018 12:30:11 PM> CP_G360FXXS1BQA2_REV00_CL1981445_QB5541753.tar.md5
4/16/2018 12:30:11 PM> The list of files in the firmware:
4/16/2018 12:30:11 PM> modem.bin
4/16/2018 12:30:13 PM> Selected file: C:\Users\kopito\Desktop\SM-G360F_1_20170615153000_7e184c4f8n_fac\CSC_MEO_G360 FMEO1BOJ1_CL823270_QB6491466_REV00_user_low_ship_M ULTI_CERT.tar.md5
4/16/2018 12:30:13 PM> CSC_MEO_G360FMEO1BOJ1_CL823270_QB6491466_REV00_use r_low_ship_MULTI_CERT.tar.md5
4/16/2018 12:30:13 PM> The list of files in the firmware:
4/16/2018 12:30:13 PM> coreprimelte_eur_open_hidden40m.pit
4/16/2018 12:30:13 PM> cache.img.ext4
4/16/2018 12:30:13 PM> hidden.img.ext4
4/16/2018 12:30:15 PM> Looking for EasyJTAG box...
4/16/2018 12:30:15 PM> EasyJTAG API ver. 2022
4/16/2018 12:30:15 PM> Setting IO Levels to 1.8V
4/16/2018 12:30:15 PM> Setting frequence to 24 Mhz
4/16/2018 12:30:15 PM> EasyJTAG Box Serial = 7B3FFXXXX
4/16/2018 12:30:15 PM> EasyJTAG Box Firmware = 2.22
4/16/2018 12:30:15 PM> Setting interface to EasyJtag2/ISP_HiPower
4/16/2018 12:30:15 PM> Setting bus width to 1 Bit
4/16/2018 12:30:15 PM> HiPower mode is ON
4/16/2018 12:30:15 PM> CMD Pullup Level: 1660 mV
4/16/2018 12:30:15 PM> CMD Active Level: 1804 mV
4/16/2018 12:30:15 PM> eMMC Init returned = 0
4/16/2018 12:30:15 PM> EMMC Device Information :
4/16/2018 12:30:15 PM> EMMC CID: FE014E50314A39354B1350AD4D78523D
4/16/2018 12:30:15 PM> EMMC CSD: D07F01320F5913FFFFFFFFEF924000A3
4/16/2018 12:30:15 PM> EMMC Manufacture Name: MICRON , EMMC NAME: P1J95K , EMMC NAME (HEX): 50314A39354B , S/N: 50AD4D78 , rev. 0x13
4/16/2018 12:30:15 PM> EMMC Manufacture ID: 0xFE , OEM ID: 0x4E , Device Type: BGA (Discrete embedded) , Manufacture Date: 5/2015
4/16/2018 12:30:15 PM> EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000)
4/16/2018 12:30:15 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
4/16/2018 12:30:15 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000)
4/16/2018 12:30:15 PM> EMMC Permanent Write Protection: No
4/16/2018 12:30:16 PM> EMMC Temporary Write Protection: No
4/16/2018 12:30:16 PM> Extended CSD Information :
4/16/2018 12:30:16 PM> Extended CSD rev: 1.6 (MMC 4.5, MMC 4.51)
4/16/2018 12:30:16 PM> Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area)
4/16/2018 12:30:16 PM> Boot Bus Config: 0x00 , width 1bit
4/16/2018 12:30:16 PM> H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled
4/16/2018 12:30:16 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07
4/16/2018 12:30:16 PM> Device supports partitioning features
4/16/2018 12:30:16 PM> Device can have enhanced technological features in partitions and user data area
4/16/2018 12:30:16 PM> Device can have extended partitions attribute
4/16/2018 12:30:16 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
4/16/2018 12:30:16 PM> Backup saved: P1J95K_50AD4D78_20180416_123016.extcsd
4/16/2018 12:30:16 PM> EMMC Init completed.
4/16/2018 12:30:16 PM> Operation: Write by vendor (Samsung)
4/16/2018 12:30:16 PM> Creating GPT-partitioninig
4/16/2018 12:30:16 PM> Writing PIT at address: 000000004400
4/16/2018 12:30:16 PM> GPT-partitioning done
4/16/2018 12:30:16 PM> Unpacking file: non-hlos.bin
4/16/2018 12:30:17 PM> Unpacking file: modem.bin
4/16/2018 12:30:17 PM> Unpacking file: sbl1.mbn
4/16/2018 12:30:17 PM> Unpacking file: aboot.mbn
4/16/2018 12:30:17 PM> Unpacking file: rpm.mbn
4/16/2018 12:30:17 PM> Unpacking file: tz.mbn
4/16/2018 12:30:17 PM> Unpacking file: hyp.mbn
4/16/2018 12:30:17 PM> Unpacking file: sec.dat
4/16/2018 12:30:17 PM> Unpacking file: boot.img
4/16/2018 12:30:17 PM> Unpacking file: recovery.img
4/16/2018 12:30:18 PM> Unpacking file: persist.img.ext4
4/16/2018 12:30:18 PM> Unpacking file: system.img.ext4
4/16/2018 12:30:45 PM> Unpacking file: cache.img.ext4
4/16/2018 12:30:45 PM> Unpacking file: hidden.img.ext4
4/16/2018 12:30:45 PM> Partition name: APNHLOS
4/16/2018 12:30:45 PM> Filename: non-hlos.bin , Offset: 000000400000 , filesize: 13485824 bytes
4/16/2018 12:30:45 PM> eMMC switching to ROM1
4/16/2018 12:30:46 PM> Erasing partition...
4/16/2018 12:30:47 PM> Writing partition...
4/16/2018 12:30:53 PM> Done writing partition. Write speed: 2496.75 KB/s
4/16/2018 12:30:53 PM> Partition name: MODEM
4/16/2018 12:30:53 PM> Filename: modem.bin , Offset: 000001300000 , filesize: 46532352 bytes
4/16/2018 12:30:53 PM> eMMC switching to ROM1
4/16/2018 12:30:53 PM> Erasing partition...
4/16/2018 12:30:55 PM> Writing partition...
4/16/2018 12:31:13 PM> Done writing partition. Write speed: 2574.31 KB/s
4/16/2018 12:31:13 PM> Partition name: SBL1
4/16/2018 12:31:13 PM> Filename: sbl1.mbn , Offset: 000004C70000 , filesize: 280468 bytes
4/16/2018 12:31:13 PM> eMMC switching to ROM1
4/16/2018 12:31:13 PM> Erasing partition...
4/16/2018 12:31:13 PM> Writing partition...
4/16/2018 12:31:14 PM> Done writing partition. Write speed: 1491.67 KB/s
4/16/2018 12:31:14 PM> Partition name: ABOOT
4/16/2018 12:31:14 PM> Filename: aboot.mbn , Offset: 000004CF8000 , filesize: 1041384 bytes
4/16/2018 12:31:14 PM> eMMC switching to ROM1
4/16/2018 12:31:14 PM> Erasing partition...
4/16/2018 12:31:14 PM> Writing partition...
4/16/2018 12:31:15 PM> Done writing partition. Write speed: 2263.56 KB/s
4/16/2018 12:31:15 PM> Partition name: RPM
4/16/2018 12:31:15 PM> Filename: rpm.mbn , Offset: 000004EF8000 , filesize: 187764 bytes
4/16/2018 12:31:15 PM> eMMC switching to ROM1
4/16/2018 12:31:15 PM> Erasing partition...
4/16/2018 12:31:16 PM> Writing partition...
4/16/2018 12:31:16 PM> Done writing partition. Write speed: 1332.03 KB/s
4/16/2018 12:31:16 PM> Partition name: QSEE
4/16/2018 12:31:16 PM> Filename: tz.mbn , Offset: 000004F78000 , filesize: 520588 bytes
4/16/2018 12:31:16 PM> eMMC switching to ROM1
4/16/2018 12:31:16 PM> Erasing partition...
4/16/2018 12:31:17 PM> Writing partition...
4/16/2018 12:31:17 PM> Done writing partition. Write speed: 2200.97 KB/s
4/16/2018 12:31:17 PM> Partition name: QHEE
4/16/2018 12:31:17 PM> Filename: hyp.mbn , Offset: 000004FF8000 , filesize: 90368 bytes
4/16/2018 12:31:17 PM> eMMC switching to ROM1
4/16/2018 12:31:17 PM> Erasing partition...
4/16/2018 12:31:18 PM> Writing partition...
4/16/2018 12:31:18 PM> Done writing partition. Write speed: 978.70 KB/s
4/16/2018 12:31:18 PM> Partition name: SEC
4/16/2018 12:31:18 PM> Filename: sec.dat , Offset: 000005378000 , filesize: 684 bytes
4/16/2018 12:31:18 PM> eMMC switching to ROM1
4/16/2018 12:31:18 PM> Erasing partition...
4/16/2018 12:31:19 PM> Writing partition...
4/16/2018 12:31:19 PM> Done writing partition. Write speed: 12.46 KB/s
4/16/2018 12:31:19 PM> Partition name: BOOT
4/16/2018 12:31:19 PM> Filename: boot.img , Offset: 000007C00000 , filesize: 10273040 bytes
4/16/2018 12:31:19 PM> eMMC switching to ROM1
4/16/2018 12:31:19 PM> Erasing partition...
4/16/2018 12:31:20 PM> Writing partition...
4/16/2018 12:31:24 PM> Done writing partition. Write speed: 2559.07 KB/s
4/16/2018 12:31:24 PM> Partition name: RECOVERY
4/16/2018 12:31:24 PM> Filename: recovery.img , Offset: 000008900000 , filesize: 10955024 bytes
4/16/2018 12:31:24 PM> eMMC switching to ROM1
4/16/2018 12:31:24 PM> Erasing partition...
4/16/2018 12:31:25 PM> Writing partition...
4/16/2018 12:31:29 PM> Done writing partition. Write speed: 2510.03 KB/s
4/16/2018 12:31:29 PM> Partition name: PERSIST
4/16/2018 12:31:29 PM> Filename: persist.img.ext4 , Offset: 00000A700000 , filesize: 4350076 bytes
4/16/2018 12:31:29 PM> eMMC switching to ROM1
4/16/2018 12:31:29 PM> Erasing partition...
4/16/2018 12:31:30 PM> Writing partition...
4/16/2018 12:31:30 PM> Sparse image found v.1.0 Total chunks: 8
4/16/2018 12:31:32 PM> Done writing partition. Write speed: 2264.76 KB/s
4/16/2018 12:31:32 PM> Partition name: SYSTEM
4/16/2018 12:31:32 PM> Filename: system.img.ext4 , Offset: 00000B800000 , filesize: 1320231292 bytes
4/16/2018 12:31:32 PM> eMMC switching to ROM1
4/16/2018 12:31:32 PM> Erasing partition...
4/16/2018 12:32:11 PM> Writing partition...
4/16/2018 12:32:11 PM> Sparse image found v.1.0 Total chunks: 2760
4/16/2018 12:41:34 PM> Done writing partition. Write speed: 2291.29 KB/s
4/16/2018 12:41:34 PM> Partition name: CACHE
4/16/2018 12:41:34 PM> Filename: cache.img.ext4 , Offset: 000069400000 , filesize: 7438556 bytes
4/16/2018 12:41:34 PM> eMMC switching to ROM1
4/16/2018 12:41:34 PM> Erasing partition...
4/16/2018 12:41:40 PM> Writing partition...
4/16/2018 12:41:40 PM> Sparse image found v.1.0 Total chunks: 16
4/16/2018 12:41:43 PM> Done writing partition. Write speed: 2328.35 KB/s
4/16/2018 12:41:43 PM> Partition name: HIDDEN
4/16/2018 12:41:43 PM> Filename: hidden.img.ext4 , Offset: 000075C00000 , filesize: 30044560 bytes
4/16/2018 12:41:43 PM> eMMC switching to ROM1
4/16/2018 12:41:43 PM> Erasing partition...
4/16/2018 12:41:44 PM> Writing partition...
4/16/2018 12:41:44 PM> Sparse image found v.1.0 Total chunks: 31
4/16/2018 12:41:56 PM> Done writing partition. Write speed: 2419.96 KB/s
4/16/2018 12:41:58 PM> Critical error: Access violation at address 00E1387E in module 'eMMC_tool.exe'. Read of address 00000004.
G360F onluy qcomm driver, need help
Old 04-17-2018, 08:22   #59 (permalink)
Member: 1569669
Thanks Meter: 250
We already fixed this problem (fw 2.23).
Bugfix will be available in next release.
Thank you for testing.
Best Regards.
The Following User Says Thank You to vikboston For This Useful Post:
Old 04-19-2018, 11:50   #60 (permalink)
Member: 409210
How to connect nand chip? And iphone nand support?
Page generated in 0.42008 seconds with 8 queries
