Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Easy-Jtag
Old 12-03-2019, 07:39   #1 (permalink)
Member: 2222183
Thanks Meter: 31
Unhappy EasyJtag J100H Boot Repair Please Guide Me?
i have simple easy jtag box.
before flashing mobile hang on logo after flashing mobile dead.
see info
Z3X EasyJtag Software ver. 3.6.1.15
Loading eMMC GEN1 Firmware... IO: 2800 mV
Box S/N: 1616FE04ACD6A1EB, ,FW Ver.: 01.63
CMD Pullup Level:2041 mV
CMD Active Level:2516 mV
Box IO Level:2800 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
HiPower mode is off!
---------- eMMC Device Information ----------
eMMC CID : 90014A483447326211011A58EDF8421A
eMMC CSD : D07F01320F5903FFFFFFFFEF8A4040DA
eMMC Manufacturer ID: 0090 , OEM ID: 014A
eMMC Date: 04/2015 Rev.0x1
eMMC NAME: H4G2b , S/N: 442035704
eMMC NAME (HEX): 483447326220
EMMC ROM1 (Main User Data) Capacity: 3728 MB , 0x748000 pages , 0xE9000000 bytes
EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB
EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB
EMMC RPMB is not yet programmed (clear) or RPMB General failure
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
EMMC Password Locked: No
Extended CSD rev 1.6 (MMC 4.5)
Boot configuration [PARTITION_CONFIG: 0x08] Boot from:ROM2 (Boot Partition 1)
Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x08.
H/W reset function [RST_N_FUNCTION]: 0x00
High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000]
Partitioning Support [PARTITIONING_SUPPORT]: 0x07
Device support partitioning feature
Device can have enhanced tech.
Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: H4G2b_ 442035704_20191203_1135.extcsd
Card Supported Command sets [S_CMD_SET: 0x01]
HPI Features [HPI_FEATURE: 0x01]:
implementation based on CMD13
Background operations support [BKOPS_SUPPORT: 0x01]
Max Packet Read Cmd [MAX_PACKED_READS: 0x08]
Max Packet Write Cmd [MAX_PACKED_WRITES: 0x08]
Data TAG support [DATA_TAG_SUPPORT: 0x01]
Data TAG Unit Size [TAG_UNIT_SIZE: 0x00]
Tag Resources Size [TAG_RES_SIZE: 0x06]
Context Management Capabilities [CONTEXT_CAPABILITIES: 0x78]
Large Unit Size [LARGE_UNIT_SIZE_M1: 0x01]
Extended partition attribute support [EXT_SUPPORT: 0x03]
Generic CMD6 Timer [GENERIC_CMD6_TIME: 0xa0]
Power off notification [POWER_OFF_LONG_TIME: 0x50]
Cache Size [CACHE_SIZE] is 512 KiB
Background operations status [BKOPS_STATUS: 0x00]
1st Initialisation Time after programmed sector [INI_TIMEOUT_AP: 0x0a]
Power class for 52MHz, DDR at 3.6V [PWR_CL_DDR_52_360: 0x00]
Power class for 52MHz, DDR at 1.95V [PWR_CL_DDR_52_195: 0x00]
Power class for 200MHz at 3.6V [PWR_CL_200_360: 0x00]
Power class for 200MHz, at 1.95V [PWR_CL_200_195: 0x00]
Minimum Performance for 8bit at 52MHz in DDR mode:
[MIN_PERF_DDR_W_8_52: 0x00]
[MIN_PERF_DDR_R_8_52: 0x00]
TRIM Multiplier [TRIM_MULT: 0x02]
Secure Feature support [SEC_FEATURE_SUPPORT: 0x55]
Boot Information [BOOT_INFO: 0x07]
Device supports alternative boot method
Device supports dual data rate during boot
Device supports high speed timing during boot
Boot partition size [BOOT_SIZE_MULTI: 0x20]
Access size [ACC_SIZE: 0x06]
High-capacity erase unit size [HC_ERASE_GRP_SIZE: 0x01]
High-capacity erase timeout [ERASE_TIMEOUT_MULT: 0x02]
Reliable write sector count [REL_WR_SEC_C: 0x01]
High-capacity W protect group size [HC_WP_GRP_SIZE: 0x10]
Sleep current (VCC) [S_C_VCC: 0x07]
Sleep current (VCCQ) [S_C_VCCQ: 0x07]
Sleep/awake timeout [S_A_TIMEOUT: 0x13]
Sector Count [SEC_COUNT: 0x00748000]
Minimum Write Performance for 8bit:
[MIN_PERF_W_8_52: 0x08]
[MIN_PERF_R_8_52: 0x08]
[MIN_PERF_W_8_26_4_52: 0x08]
[MIN_PERF_R_8_26_4_52: 0x08]
Minimum Write Performance for 4bit:
[MIN_PERF_W_4_26: 0x08]
[MIN_PERF_R_4_26: 0x08]
Power classes registers:
[PWR_CL_26_360: 0x00]
[PWR_CL_52_360: 0x00]
[PWR_CL_26_195: 0x00]
[PWR_CL_52_195: 0x00]
Partition switching timing [PARTITION_SWITCH_TIME: 0x01]
Out-of-interrupt busy timing [OUT_OF_INTERRUPT_TIME: 0x05]
I/O Driver Strength [DRIVER_STRENGTH: 0x01]
Card Type [CARD_TYPE: 0x17]
CSD structure version [CSD_STRUCTURE: 0x02]
Command set [CMD_SET: 0x00]
Command set revision [CMD_SET_REV: 0x00]
Power class [POWER_CLASS: 0x00]
High-speed interface timing [HS_TIMING: 0x00]
Erased memory content [ERASED_MEM_CONT: 0x00]
Boot configuration bytes [PARTITION_CONFIG: 0x08]
No access to boot partition
Boot config protection [BOOT_CONFIG_PROT: 0x00]
Boot bus Conditions [BOOT_BUS_CONDITIONS: 0x00]
High-density erase group definition [ERASE_GROUP_DEF: 0x00]
Boot write protection status registers [BOOT_WP_STATUS]: 0x00
Boot Area Write protection [BOOT_WP]: 0x00
Power ReadOnly locking: possible
Permanent ReadOnly locking: possible
Read Only lock status: not locked
User area write protection register [USER_WP]: 0x00
FW configuration [FW_CONFIG]: 0x00
RPMB Size [RPMB_SIZE_MULT]: 0x20
Write reliability setting register [WR_REL_SET]: 0x1f
Write reliability parameter register [WR_REL_PARAM]: 0x05
Enable background operations handshake [BKOPS_EN]: 0x00
HPI management [HPI_MGMT]: 0x00
Max Enhanced Area Size [MAX_ENH_SIZE_MULT]: 0x0000e9
Partitions attribute [PARTITIONS_ATTRIBUTE]: 0x00
General Purpose Partition Size [GP_SIZE_MULT_4]: 0x000000
[GP_SIZE_MULT_3]: 0x000000
[GP_SIZE_MULT_2]: 0x000000
[GP_SIZE_MULT_1]: 0x000000
Enhanced User Data Area Size [ENH_SIZE_MULT]: 0x000000
Enhanced User Data Start Address [ENH_START_ADDR]: 0x000000
Bad Block Management mode [SEC_BAD_BLK_MGMNT]: 0x00
Periodic Wake-up [PERIODIC_WAKEUP]: 0x00
Program CID/CSD in DDR mode support [PROGRAM_CID_CSD_DDR_SUPPORT]: 0x01
Native sector size [NATIVE_SECTOR_SIZE]: 0x00
Sector size emulation [USE_NATIVE_SECTOR]: 0x00
Sector size [DATA_SECTOR_SIZE]: 0x00
1st initialization after disabling sector size emulation [INI_TIMEOUT_EMU]: 0x0a
Class 6 commands control [CLASS_6_CTRL]: 0x00
Number of addressed group to be released[DYNCAP_NEEDED]: 0x00
Exception events control [EXCEPTION_EVENTS_CTRL]: 0x0000
Exception events status [EXCEPTION_EVENTS_STATUS]: 0x0000
Extended Partitions Attribute [EXT_PARTITIONS_ATTRIBUTE]: 0x0000
Packed command status [PACKED_COMMAND_STATUS]: 0x00
Packed command failure index [PACKED_FAILURE_INDEX]: 0x00
Power Off Notification [POWER_OFF_NOTIFICATION]: 0x00
Control to turn the Cache ON/OFF [CACHE_CTRL]: 0x00
Partition info not found
Done.
then i write pit file + bl file from Direct eMMC Samsung Flasher but mobile is still dead condition...after detect EasyJTAG Tool so write dump files so come this error ( Writing 0010000000 bytes to 0000000000... ROM1 (USER ROM)
Write Block Failed, Reason: Write Block Verify Error )
Processing file...C:\Users\akhtar\Desktop\J100H\H4G2b _2165950698_20170316_1248.extcsd
Processing file...C:\Users\akhtar\Desktop\J100H\EMMC_ROM1_H4G 2b_2165950698_00000000_10000000.bin
Processing file...C:\Users\akhtar\Desktop\J100H\EMMC_ROM2_H4G 2b_2165950698_00000000_00400000.bin
Processing file...C:\Users\akhtar\Desktop\J100H\EMMC_ROM3_H4G 2b_2165950698_00000000_00400000.bin
Running:Repair extCSD...
Skip loading eMMC Addon Firmware
CLK Rate:14000 kHz
------------Parsing extCSD------------
------------Done parsing------------
Writing as extCSD 4.5
Done.
Input file : C:\Users\akhtar\Desktop\J100H\EMMC_ROM1_H4G2b_2165 950698_00000000_10000000.bin
Done.
Done with error(s)
Input file : C:\Users\akhtar\Desktop\J100H\EMMC_ROM2_H4G2b_2165 950698_00000000_00400000.bin
Writing 0000400000 bytes to 0000000000 ...ROM2 (BOOT1 ROM)
Done, time taken: 5 sec. Average Write Speed: 769 kB/s
Input file : C:\Users\akhtar\Desktop\J100H\EMMC_ROM3_H4G2b_2165 950698_00000000_00400000.bin
Writing 0000400000 bytes to 0000000000 ...ROM3 (BOOT2 ROM)
Done, time taken: 5 sec. Average Write Speed: 749 kB/s
plz tell me how to recover.....?
Old 12-03-2019, 08:24   #2 (permalink)
Member: 13148
Thanks Meter: 1,388
Write error - you need replace eMMC
Page generated in 0.25580 seconds with 7 queries
