Originally Posted by vikboston
(Post 12091875)
Hi,
We already fixed some can't open .tot file bugs.
You can download easyjtag_emmc_plus_1.0.0.36.exe from support.
Best Regards | Everything is fine Code:
Looking for EasyJTAG box...
EasyJTAG API ver. 2003
Setting IO Levels to 2.8V
Setting frequence to 21 Mhz
HiPower mode is OFF
EasyJTAG Box Serial = xxxxxxxxxxx
EasyJTAG Box Firmware = 01.55
HiPower mode is OFF
CMD Pullup Level: 2681 mV
CMD Active Level: 2763 mV
EMMC Device Information :
EMMC CID: 45010053454D3136471C27E7CC7B917C
EMMC CSD: D00F00320F5903FFFFFFFFFF8A40407E
EMMC Manufacture Name: SANDISK
EMMC NAME: SEM16G , S/N: 27E7CC7B , rev. 1C
EMMC NAME (HEX): 53454D313647
EMMC ROM 1 (Main User Data) Capacity: 15028 MB
EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB
Backup saved: SEM16G_27E7CC7B_20161011_094714.extcsd
EMMC Init completed.
Filename: LGD821AT-00-V10e-NXS-XX-JUN-12-2014-KTU84M-USER-16G+0.tot
Model: D821
Software: LGD821AT-00-V10e-NXS-XX-JUN-12-2014-KTU84M-USER-16G+0
BuildTime:
Total Files: 32
The size of the last section has been updated
HiPower mode is OFF
Backup saved: SEM16G_27E7CC7B_20161011_094728.extcsd
Creating GPT-partitioninig
GPT-partitioning done
Model: D821
BuildTime:
Total Files: 32
Unpacking files from the firmware. Please wait ...
Unpack done
Partition name: MODEM
Filename: modem_1024 , Offset: 000000080000 , filesize: 46661632 bytes
eMMC switching to ROM1
Erasing partition...
Writing partition...
Done writing partition. Write speed: 970,20 Kb/s
Partition name: SBL1
Filename: sbl1_132096 , Offset: 000004080000 , filesize: 524288 bytes
Done writing partition. Write speed: 1158,90 Kb/s
Partition name: RPM
Filename: rpm_134144 , Offset: 000004180000 , filesize: 524288 bytes
Done writing partition. Write speed: 1360,71 Kb/s
Partition name: TZ
Filename: tz_135168 , Offset: 000004200000 , filesize: 524288 bytes
Done writing partition. Write speed: 1220,67 Kb/s
Partition name: SDI
Filename: sdi_136192 , Offset: 000004280000 , filesize: 524288 bytes
Done writing partition. Write speed: 1685,39 Kb/s
Partition name: ABOOT
Filename: aboot_137216 , Offset: 000004300000 , filesize: 524288 bytes
Done writing partition. Write speed: 1169,60 Kb/s
Partition name: SBL1B
Filename: sbl1b_142336 , Offset: 000004580000 , filesize: 524288 bytes
Done writing partition. Write speed: 1147,04 Kb/s
Partition name: TZB
Filename: tzb_144384 , Offset: 000004680000 , filesize: 524288 bytes
Done writing partition. Write speed: 1218,28 Kb/s
Partition name: RPMB
Filename: rpmb_145408 , Offset: 000004700000 , filesize: 524288 bytes
Done writing partition. Write speed: 1358,56 Kb/s
Partition name: ABOOTB
Filename: abootb_146432 , Offset: 000004780000 , filesize: 524288 bytes
Done writing partition. Write speed: 1181,45 Kb/s
Partition name: MISC
Filename: misc_160768 , Offset: 000004E80000 , filesize: 8388608 bytes
Done writing partition. Write speed: 1738,44 Kb/s
Partition name: PERSIST
Filename: persist_193536 , Offset: 000005E80000 , filesize: 4718592 bytes
Done writing partition. Write speed: 1737,62 Kb/s
Partition name: IMGDATA
Filename: imgdata_226304 , Offset: 000006E80000 , filesize: 1572864 bytes
Done writing partition. Write speed: 823,61 Kb/s
Partition name: LAF
Filename: laf_232448 , Offset: 000007180000 , filesize: 13631488 bytes
Done writing partition. Write speed: 952,57 Kb/s
Partition name: BOOT
Filename: boot_277504 , Offset: 000008780000 , filesize: 8912896 bytes
Done writing partition. Write speed: 922,04 Kb/s
Partition name: RECOVERY
Filename: recovery_322560 , Offset: 000009D80000 , filesize: 9961472 bytes
Done writing partition. Write speed: 946,69 Kb/s
Partition name: SYSTEM
Filename: system_376832 , Offset: 00000B800000 , filesize: 134742016 bytes
Done writing partition. Write speed: 976,05 Kb/s
Filename: system_643608 , Offset: 000013A43000 , filesize: 132120576 bytes
Done writing partition. Write speed: 920,14 Kb/s
Filename: system_905232 , Offset: 00001BA02000 , filesize: 132644864 bytes
Done writing partition. Write speed: 908,20 Kb/s
Filename: system_1167896 , Offset: 000023A43000 , filesize: 132120576 bytes
Done writing partition. Write speed: 916,57 Kb/s
Filename: system_1429520 , Offset: 00002BA02000 , filesize: 132644864 bytes
Done writing partition. Write speed: 910,21 Kb/s
Filename: system_1692184 , Offset: 000033A43000 , filesize: 76546048 bytes
Done writing partition. Write speed: 921,23 Kb/s
Filename: system_1949696 , Offset: 00003B800000 , filesize: 524288 bytes
Done writing partition. Write speed: 1743,30 Kb/s
Filename: system_2211840 , Offset: 000043800000 , filesize: 524288 bytes
Done writing partition. Write speed: 1742,49 Kb/s
Partition name: CACHE
Filename: cache_2535424 , Offset: 00004D600000 , filesize: 13631488 bytes
Done writing partition. Write speed: 1736,80 Kb/s
Filename: cache_2797568 , Offset: 000055600000 , filesize: 524288 bytes
Done writing partition. Write speed: 1740,46 Kb/s
Filename: cache_3059712 , Offset: 00005D600000 , filesize: 524288 bytes
Done writing partition. Write speed: 1741,81 Kb/s
Filename: cache_3321856 , Offset: 000065600000 , filesize: 524288 bytes
Done writing partition. Write speed: 1735,02 Kb/s
Filename: cache_3584000 , Offset: 00006D600000 , filesize: 524288 bytes
Done writing partition. Write speed: 1741,19 Kb/s
Filename: cache_3846144 , Offset: 000075600000 , filesize: 524288 bytes
Done writing partition. Write speed: 1726,02 Kb/s
All done |
