GSM-Forum (https://forum.gsmhosting.com/vbb/)
-   Easy-Jtag / Easy-Jtag Plus (https://forum.gsmhosting.com/vbb/f672/)
-   -   EasyJTAG Plus (eMMC Tool Shuite): Log of changes, khown bugs and info about fixing it (https://forum.gsmhosting.com/vbb/f672/easyjtag-plus-emmc-tool-shuite-log-changes-khown-bugs-info-about-fixing-2444381/)
layder 07-31-2018 18:44
eMMC Tool Shuite version history:
just about 17.05.2016 (ver 1.0.0)
- Initial Release
30.11.2016 (ver 1.0.0.39)
Fix: Bug with the smart card at the start of the program
Fix: Bug when processing sparse image
Fix: Bug with extract data from contacts2.db
Fix: Writing for some MTK images
Fix: Bug when opening MTK-partitions in the Explorer
Add: Reading tables from emmc on the Factory tab
(for writing partitions if you do not have a header file)
Add: Support GP-partitions
Add: Option "Write all eMMC Regions at once"
Add: Automatically sending crash reports
Add: Button "Sending crash report for the current log"
Add: Notification in the system tray
Add: Adding ROM2 when reading from the image
Add: Automatic writing configuration for MTK after flashing
Add: Some GUI changes
02.12.2016 (ver 1.0.0.40)
Fix: Bug with switching ROM
Fix: Bug with access to GP-partitions
Fix: Bug when searching for FRP
Add: Generic / Universal Factory Format (Toshiba, Hynix, etc.)
08.12.2016 (ver 1.0.0.41)
Fix: Bugs that have been found through your crash report
11.12.2016 (ver 1.0.0.42)
Fix: Fixed force erase timeouts detection (Universal Factory Format)
09.03.2017 (ver 1.0.0.43)
Add: Some improvements
Add: Write by vendor "Spreadtrum" (While only SC773X)
Add: Search for tables nVidia Tegra
Add: Completely rewritten Explorer
28.04.17 (ver 1.0.0.44)
Fixe: Bugs that have been found through your crash report
Fix: Minor changes to EasyFS.dll
Add: The project was completely rewritten as a Unicode version
Add: Option "Get firmware info" (version, date, etc.)
Add: Option "Skip unreadable blocks"
Add: Function "Remove WriteProtection"
Add: New S.M.A.R.T. information for EMMC revision 5.0 and higher
Add: Removing Android Locks ( Gesture PIN Password )
01.05.2017 (ver 1.0.0.45)
Add: eMMC chip name identification from cid (Preloader parser)
16.05.17 (ver 1.0.0.46)
Add: Scanning PIT from eMMC (Explorer)
Add: Scanning from MassStorage (E-MATE / KET / QC_9006)
28.05.2017 (ver 1.0.0.47)
Fix: Searching for partitions when scanning MBR
Fix: Searching for MassStorage devices
Add: AutoUpdate for the program
08.08.2017 (ver 1.4.8)
Fix: Saving VCF for contacts
Add: Multiple file selection for Samsung firmware
Add: Write full Extcsd or write only the boot configuration ("Repair Extcsd" button)
Add: Intel vendor (for easy read/write ROM2/ROM3/GP1)
Add: "Pinouts" tab (taken from the catalog of classic software)
Add: Checker for Sony TrimArea
Add: Speed graph for "Random verify emmc"
Add: Fat16/Fat32/exFat support (Explorer)
12.12.2017 (ver 1.4.9)
Fix: RandomVerify function
Fix: Creation of GPT for Samsung (write by vendor)
Fix: Failed to mount large Fat partitions (explorer)
Fix: Extraction from contact2.db (explorer)
Fix: Error in the "build.prop" parser
Fix: CID Parser
Add: Support for EasyJtag Plus Box
Add: Path for TempDir and InitialDir (option in settings)
Add: Unpack Lenovo QSB (utilities)
Add: Selecting a PIT file from CSC (write by vendor Samsung)
Add: Detect for encrypted dumps from GPG Box
Add: Detect for FullDiskEncryption Partition (explorer)
Add: LinearVerify of the Partition (read by vendor)
Add: Information base about emmc compatibility (thanks to phonemicrodb)
Add: Resizing the window (for small screen resolutions)
Add: Converting large partitions in SparseImage when reading by vendor (option in settings)
Add: Mounting SparseImage (explorer)
Add: Automatic backup of the EFS partition for Samsung (read by vendor)
Add: Formatting of EFS partition for Samsung on request (write by vendor)
16.04.2018 (ver 1.5.0)
Add: Showing Connected Pins for a Socket (Emmc check)
Add: Automatic search and write 8xxx_msimage and BootConfig (write by vendor)
Add: SmartReport for Sandisk
Add: Vendor Sony
Add: Automatic backup of the TrimArea partition for Sony (read by vendor)
Add: Grouping of extracted messages by sender (Explorer)
Add: Extract Calendar (Explorer)
Add: Checking FullDiskEncryption from Boot (Explorer)
Add: Scan FullFlash from devices with UFS-memory (Explorer)
Add: Converting EFS to Z3X-Samsung format (read by vendor Samsung)
Add: Ext4 formatting is completely rewritten (write by vendor)
Add: Reading files with emmc errors (Explorer)
Add: Skipping for existing files while saving (Explorer)
Add: Write protection for ROM 2/3
11.06.2018 (ver 1.5.1)
Add: Explorer NTFS Support (it will probably be slow on EasyJTAG V1)
Add: Extracting contacts from store.vol (currently only from a file on disk)
layder 08-03-2018 12:15
Bugs at current version and info about fix it
Easy JTAG Classic 3.0.0.0
- write Firmware errors on eMMC firmware on some boxes (fixed in 3.0.0.3);
- error when recovery eMMC firmware KMV3W000LM-B310: did not fit CID (will be fixed in 3.0.0.4 and higher);
- bad new eMMC firmware for KMKJS000VM-B309 (ver. 0x7) (fixed in 3.0.0.3, return to ver. 0x3).
eMMC Tool Suite 1.5.1
- errors are: "-8, DATA SND CRC Error" and "-3, DATA RCV Timeout Error" (partially fixed in 1.5.2);
- Write by Vendor - Samsung: some BL files are not written to ROM2 (fixed in 1.5.2); (before 1.5.2 released, use old 1.5.0)
- error when retrieving data from store.vol if the database is corrupted (fixed in 1.5.2);
- wrong mount point when formating a partition /userdata (fixed in 1.5.2);
- an empty EFS was saved with Read by Vendor - Samsung (fixed in 1.5.2);
- when Write by Vendor from Img, the files inserted in the lines did not fit, it was written from Img (fixed in 1.5.2);
- Read by Vendor - MTK (GPT) the scat file was not correctly saved, but when Write by Vendor - MTK, the tick for pgpt.bin was not automatically set (fixed in 1.5.2);
- hang of the box with the sequence: "Check eMMC Pins" - "eMMC Check" - "Random Verify Test" (fixed in 1.5.2).
layder 08-06-2018 11:21
06.08.2018 (ver 1.5.2)
Fix: Writing ROM2 for Samsung (Write by vendor)
Fix: Freezing the program on a RandomVerify
Add: Initial Folder for saving from Explorer (in settings)
Add: Extract from store.vol from eMMC (explorer)
Add: Automatic repair of damaged store.vol when extracting (Explorer)
Add: Adding MountPoints for partitions (efs, userdata) when formatting
Add: Checking for an empty EFS before backup (Read by Vendor Samsung)
p.s. Kaspersky software and Awast is warning for viruses - it's a false alarm ("taggant-system" for it is shutting down)
http://vmpsoft.com/20180505/ieee-ams...-31-july-2018/
layder 12-28-2018 09:05
28.12.2018 (ver 1.5.3)
Fix: Scatter file processing (MTK)
Fix: Contact Extractor
Fix: Preloader parser
Fix: FAT partitions mounting
Fix: Minor interface changes
Add: Explorer: Work with Qualcomm HS-USB QDLoader 9008 interface
Add: Reset FRP via Qualcomm HS-USB QDLoader 9008 interface (General - Advanced - Remove FRP)
Add: Remove Android locks via Qualcomm HS-USB QDLoader 9008 interface (General - Advanced - Remove Android Locks)
Add: Auto/Manual loaders select for Qualcomm HS-USB QDLoader 9008 interface
Add: Samsung firmware lz4 unpack support (Write by vendor - Samsung)
Add: Import from cm2qlm xml backups (Write by vendor - Qualcomm)
Add: Unpack Bootloader.img archive from Motorola firmware files
Add: Import GP partition parameters from ExtCSD backups (General - eMMC HW Partitions)
Add: Import Boot and RPMB sizes from ExtCSD backups (General - eMMC HW Partitions)
Add: Allow to create a GP with zero size (fix "Error writing at address: 000000000000", fine for Samsung eMMC, and may be destroy SanDisk and other eMMC)
Add: Explorer: Pin and Password decoding (only English and Russian letters)
layder 06-24-2019 09:01
23.06.2019 (ver 1.6.0)
Fix: Samsung GPT create (Write by vendor - Samsung)
Add: Support UFS Memory
Add: Showing eMMC RPMB Counter Status
Add: OPPO OFP firmware extractor (Utilites)
Add: LG TOT/KDZ firmware extractor (Utilites)
Add: "Disable Hi-Speed eMMC timing" option (Settings)
Add: Showing information about Xiaomi MiCloud (Explorer)
Add: Enter your account for Xiaomi EDL authorization
Add: Manually formatting partitions in EXT4
Add: New loaders for Qualcomm QDLoader 9008 port
layder 03-21-2021 10:50
EasyJTAG Plus 2.0 beta update from 17/03/21
Unpack this files to EasyJTAG Plus directory after 1.6.4 Plus installed
Add: LG KDZ write by vendor
Add: Support new kdz format
Fix: Latest API for UFS chips. Improve UFS chips connect stability
https://drive.google.com/file/d/1AdG...ew?usp=sharing
layder 05-06-2021 08:50
EastJtag eMMC Plus 05.05.2021 (ver 1.6.6.0) Relesed
Add: New keys for Oppo unpack
05.05.2021 (ver 2.0.1.0)
Add: Vendor LG
Add: Mediatek Preloader Parser
Add: OnePlus Unpacker
Add: Xiaomi Custom EDL Authorization
Add: Xiaomi Remove Mi Account (only Qualcomm)
http://updates.easy-jtag.com/easyjta...us_1.6.6.0.exe
Page generated in 0.17671 seconds with 6 queries
