09-01-2017, 11:51 | #1 (permalink) |
Junior Member Join Date: Jul 2017
Member: 2736169 Status: Offline Thanks Meter: 7 | CMD Timeout Error / Warning: CMD Pullup Level (0 mV) ------------------------------------------------------------ Z3X EasyJtag Software ver. 2.5.0.8 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: 05FFD006640A08E5, ,FW Ver.: 01.58 Warning: CMD Pullup Level (0 mV) too low , check cables etc.! CMD Active Level:0 mV Box IO Level:2800 mV CLK Rate:14000 khz HiPower mode is off! Can't init device, Reason: CMD Timeout Error Done. ------------------------------------------------------------ Why my CMD Pullup level is 0 mV? I tried connect few emmc directly from the z3x easy jtag, and with moorc adapter. I can't detect emmc with my box T_T Is it necessary to disassemble the box? if yes, why it can was happed? |
The Following User Says Thank You to Reutskiy For This Useful Post: |
09-01-2017, 13:11 | #2 (permalink) | |
No Life Poster Join Date: May 2009 Location: mumbai wadala
Member: 1037372 Status: Offline Thanks Meter: 557 | Quote:
upload pic your moorc adapter front and back pic | |
The Following 2 Users Say Thank You to royalnasim For This Useful Post: |
09-03-2017, 19:56 | #5 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi Please remove any adapter then press "Detect" and post log |
The Following User Says Thank You to BABAK NURI For This Useful Post: |
09-03-2017, 21:10 | #6 (permalink) |
Freak Poster Join Date: Mar 2004 Location: Turkey
Member: 60632 Status: Offline Sonork: 100.1616618 Thanks Meter: 48 | important Note in case of connection problems use pull-up resistors 5-200 ohm 0.25W from 1.8 to CMD and DAT0 lines %100 working |
The Following 2 Users Say Thank You to tedcen34 For This Useful Post: |
09-04-2017, 02:12 | #7 (permalink) | ||
Member: 2736169 Status: Offline Thanks Meter: 7 | Quote:
--------------------------------------------------------------------- Z3X EasyJtag Software ver. 2.5.0.8 Loading eMMC Addon Firmware... IO: 1800 mV Box S/N: 05FFD006640A08E5, ,FW Ver.: 01.58 Warning: CMD Pullup Level (0 mV) too low , check cables etc.! CMD Active Level:1258 mV Box IO Level:1800 mV CLK Rate:14000 khz HiPower mode is off! Can't init device, Reason: CMD Timeout Error Done. --------------------------------------------------------------------- Quote:
And with resistors 100 ohm --------------------------------------------------------------------- Z3X EasyJtag Software ver. 2.5.0.8 Loading eMMC Addon Firmware... IO: 1800 mV Box S/N: 05FFD006640A08E5, ,FW Ver.: 01.58 CMD Pullup Level: 835 mV CMD Active Level: 1412 mV Box IO Level:1800 mV CLK Rate:21000 khz HiPower mode is off! Can't init device, Reason: CMD Timeout Error Done. --------------------------------------------------------------------- with resistors something changed. it's the same error with any emmc voltag (1,8; 2,8; 3,3) And from box CMD pin, voltage 1.3 when in programm is 1.8. It's ok? The same pictures with other voltages too. | ||
09-23-2017, 18:08 | #14 (permalink) |
Member: 2736169 Status: Offline Thanks Meter: 7 | guys, I'm back again With new logs I'm soldered to emmc pinouts on phone board from z3x easy jtag (samsung i9082) always logs Compression is ON Z3X EasyJtag Software ver. 2.6.0.1 Loading eMMC GEN1 Firmware... IO: 1800 mV Box S/N: 05FFD006640A08E5, ,FW Ver.: 01.60 CMD Pullup Level:1093 mV CMD Active Level:1454 mV Box IO Level:1800 mV CLK Rate:14000 khz HiPower mode is off! Can't init device, Reason: CMD Timeout Error Done. But one time, when I changed resistors from 100 ohm to 51 ohm, I saw new log: Compression is ON Z3X EasyJtag Software ver. 2.6.0.1 Loading eMMC GEN1 Firmware... IO: 1850 mV Box С/Н: 05FFD006640A08E5, ,Микропрограмма Вер.: 01.60 CMD Pullup Leve :1144 mV CMD Active Level :1536 mV Box IO Level:1850 mV CLK Rate:14000 khz HiPower mode is off! ---------- eMMC Device Information ---------- EMMC CID : 1501004D3847315741004E1DF34A21FC EMMC CSD : D02701320F5903FFF6DBFFE18E404028 Изготовитель eMMC: ID: 0015 , OEM ID: 0100 EMMC Date: 02/2014 Rev.0x0 EMMC NAME: M8G1WA , S/N: 1310585674 EMMC NAME (HEX): 4D384731574100 Can't init EMMC, Reason: CARD Data FIFO Timeout Error Check Data Line! Done. second chance to detect emmc, old log is back HELP PLEASE I dont understand, why my box is dont working. or I need to send it throw into the trash. Im tired :/ What I need to do with that problem? It dont working with Moorc adapter and dont working without it. WHY? DMN. |
