Old 03-13-2020, 16:24   #1 (permalink)
Member: 1391134
Thanks Meter: 47
jkm-lx1 boot repair done
huawei jkm-lx1 after flash is dead
eMMC_tool Suite ver. 1.6.2.0 (release date: 30.06.2019)
Microsoft Windows 7 (64 bit) build 7601 (6.1.7601.18015)
Looking for EasyJTAG box...
EasyJTAG API ver. 3307
EasyJTAG Box Serial = 0A00E013F603DAEE
Card Serial = AAEC997E
EasyJTAG Box Firmware = 1.63
Changelog:
30.06.2019 (ver 1.6.1.0)
Fix: Bugs that have been found through your crash report
HiPower mode is ON
Setting frequence to 3 MHz
CMD Pullup Level: 3145 mV
CMD Active Level: 3248 mV
EMMC Device Information :
EMMC CID: 13014E53304A333859100D4B2A58269A
EMMC CSD: D05F01328F5913FFFFFFFFEF964000A8
EMMC Manufacture : MICRON , EMMC NAME: S0J38Y , HEX: 53304A333859 , S/N: 0D4B2A58 , rev. 0x10
EMMC Manufacture ID: 0x13 , OEM ID: 0x4E , Device Type: BGA (Discrete embedded) , Date: 2/2019
EMMC ROM 1 (Main User Data) Capacity: 59640 MB (000E8F800000)
EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 4166 , Response: Not Clean
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
Extended CSD Information :
Extended CSD rev: 1.8 (MMC 5.1)
Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1)
Boot Bus Config: 0x02 , width 8bit
H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled
Supported partition features [PARTITIONING_SUPPORT]: 0x07
Device supports partitioning features
Device can have enhanced technological features in partitions and user data area
Device can have extended partitions attribute
Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: S0J38Y_0D4B2A58_20200313_003039.extcsd
EMMC Init completed.
Scanning soft partitions
GPT header is found and is valid
Partition: bota0, [000000400000 - 000000800000], size: 000000400000 (4.00 MB)
Partition: bota1, [000000800000 - 000000C00000], size: 000000400000 (4.00 MB)
Partition: efs, [000000C00000 - 000002000000], size: 000001400000 (20.0 MB)
Partition: cpefs, [000002000000 - 000002800000], size: 000000800000 (8.00 MB)
Partition: m9kefs1, [000002800000 - 000002C00000], size: 000000400000 (4.00 MB)
Partition: m9kefs2, [000002C00000 - 000003000000], size: 000000400000 (4.00 MB)
Partition: m9kefs3, [000003000000 - 000003400000], size: 000000400000 (4.00 MB)
Partition: carrier, [000003400000 - 000003500000], size: 000000100000 (1.00 MB)
Partition: param, [000003500000 - 000003D00000], size: 000000800000 (8.00 MB)
Partition: boot, [000003D00000 - 000005D00000], size: 000002000000 (32.0 MB)
Partition: recovery, [000005D00000 - 000008300000], size: 000002600000 (38.0 MB)
Partition: ota, [000008300000 - 000008B00000], size: 000000800000 (8.00 MB)
Partition: cdma-radio, [000008B00000 - 000008F00000], size: 000000400000 (4.00 MB)
Partition: radio, [000008F00000 - 00000E700000], size: 000005800000 (88.0 MB)
Partition: tombstones, [00000E700000 - 00000E800000], size: 000000100000 (1.00 MB)
Partition: dnt, [00000E800000 - 00000E900000], size: 000000100000 (1.00 MB)
Partition: persistent, [00000E900000 - 00000E980000], size: 000000080000 (512. KB)
Partition: persdata, [00000E980000 - 00000F580000], size: 000000C00000 (12.0 MB)
Partition: reserved2, [00000F580000 - 00000F800000], size: 000000280000 (2.50 MB)
Partition: system, [00000F800000 - 000093000000], size: 000083800000 (2.05 GB)
Partition: cache, [000093000000 - 00009F800000], size: 00000C800000 (200. MB)
Partition: hidden, [00009F800000 - 0000A2000000], size: 000002800000 (40.0 MB)
Partition: userdata, [0000A2000000 - 000747C00000], size: 0006A5C00000 (26.5 GB)
GPT header successfully parsed
Get firmware version
Firmware info not found
HiPower mode is ON
CMD Pullup Level: 3165 mV
CMD Active Level: 3238 mV
Backup saved: S0J38Y_0D4B2A58_20200313_003707.extcsd
Opening file: JKM-BD_1.0.0.29_Download.xml
HiPower mode is ON
CMD Pullup Level: 3155 mV
CMD Active Level: 3258 mV
Backup saved: S0J38Y_0D4B2A58_20200313_003729.extcsd
Opening file: Hisi_AT_Partially_Erase_kirin670.xml
HiPower mode is ON
Backup saved: S0J38Y_0D4B2A58_20200313_003758.extcsd
HiPower mode is ON
Backup saved: S0J38Y_0D4B2A58_20200313_003918.extcsd
HiPower mode is ON
CMD Pullup Level: 3135 mV
Backup saved: S0J38Y_0D4B2A58_20200313_003931.extcsd
HiPower mode is ON
CMD Active Level: 3269 mV
Backup saved: S0J38Y_0D4B2A58_20200313_004638.extcsd
Operation: Writing all eMMC Regions...
Operation: Writing BootConfig ...
Reg: 179 Value: 0x08
Reg: 177 Value: 0x02
Reg: 162 Value: 0x01
Done
Writing to: ROM2 , start: 0x000000000000 , size: 0x000000400000
Filename: boot1.bin
eMMC switching to ROM2
Writing partition...
Done writing partition. Write speed: 108.93 KB/s
Writing to: ROM3 , start: 0x000000000000 , size: 0x000000400000
Filename: boot2.bin
eMMC switching to ROM3
Writing to: ROM1 , start: 0x000000000000 , size: 0x000100000000
Filename: userarea_4GiB.bin
eMMC switching to ROM1
Error writing at address: 000000000000 , error: 512, 512 Unknown error ... Retry #1
Done writing partition. Write speed: 177.82 KB/s
All done time: [06:34:24:918]
after boot repair with easy jtag phone is ok
txxxxx z3x team
The Following 4 Users Say Thank You to sagad For This Useful Post:
Old 03-15-2020, 14:43   #2 (permalink)
rico_deep's Avatar
Member: 159757
Thanks Meter: 461
can you share eMMC dump file?
Old 03-16-2020, 01:06   #3 (permalink)
Registered User
Member: 1725884
Sonork: swimming
Thanks Meter: 293
you could write board firmware by write by vendor
https://firmware.gem-flash.com/index...file&id=133599
The Following User Says Thank You to abo anas zayan For This Useful Post:
Old 03-25-2020, 19:26   #4 (permalink)
johnoroo37's Avatar
Member: 2025428
Thanks Meter: 445
Emmc pinout needed pls
Page generated in 0.22747 seconds with 9 queries
