Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Easy-Jtag
Old 05-06-2018, 12:47   #31 (permalink)
Member: 1741973
Thanks Meter: 109
old box jtag not work in x64 win 7, any solution to solve this problem in win 7 x64 bit
Old 05-08-2018, 04:35   #32 (permalink)
Sniper_04's Avatar
Member: 704097
Sonork: 100.1607742
Thanks Meter: 807
I'm using win7 64bit w/o any problem
same on win7 32bit,win10 64bit
check your driver
Old 05-09-2018, 14:21   #33 (permalink)
ATHI's Avatar
Member: 667142
Sonork: 100.1659975
Thanks Meter: 2,272
EasyJtag Plus v 1.5.0.0
Have Many Bugs Pls Fix It
I Am Done Boot Repair G532F In Version 1.4.9.0 Many Set
But 1.5.0.0 Write Error
Unfortunatlly I Am Close Tab So I Don't Have Image
Again I Am Using V.1.4.9.0
V.1.5.0.0 No Use
Old 05-12-2018, 07:31   #34 (permalink)
kzafquiel's Avatar
Member: 1318721
Thanks Meter: 129
old easy jtag box
alright work
win 7 64x
any problems
show us your problem with picture
Old 05-21-2018, 12:33   #35 (permalink)
Member: 2838800
hi, found a 'bug'. Remote desktop sessions give issues with the security. So, if i login in on the laptop it is fine. If i login via remote desktop service from other pc (with reader still attached to the laptop) is crashes on the security thing.
Would love to see this fixed
Old 05-26-2018, 11:48   #36 (permalink)
anjuman's Avatar
Member: 667941
Sonork: 100.1611812
Thanks Meter: 51
hello dear support i buy new easy jtag plus box with full set. now i getting problem to connect emmc direct with e.socket its getting heat .and not detected.its just connect only one emmc i9060 all other i cant detect i try g570 emmc and some other also but all are getting heat.i change emmc direction .but same result.plz help me
Old 05-26-2018, 15:35   #37 (permalink)
Member: 2047179
Thanks Meter: 25
every mobile emmc cmd timeout error
i check i545, j100h, j120, all give error
Can't init device, Reason: CMD Timeout Error
i545 working phone
j100h, j120f dead but all same error
Old 05-31-2018, 01:25   #38 (permalink)
Member: 2554174
Thanks Meter: 3
why i cant find this version on the shell
there is only v1.4.9.0
& V2.9.0.2 of the classic suite
Old 06-10-2018, 05:13   #39 (permalink)
rico_deep's Avatar
Member: 159757
Thanks Meter: 429
why it take too long to format userdata? on older version it will only take less than a minute
Old 06-10-2018, 05:44   #40 (permalink)
Member: 2554174
Thanks Meter: 3
it depends on partition size
Sent from my Redmi Note 4 using Tapatalk
Old 06-10-2018, 06:36   #41 (permalink)
rico_deep's Avatar
Member: 159757
Thanks Meter: 429
then why it takes only less than 1 min on v1.4.9.0 version? 8gb emmc
v1.4.9.0 format userpartition takes less than 1min
v 1.5.0.0 format userpartition takes almost 1 hour
Old 06-12-2018, 02:50   #42 (permalink)
Member: 2554174
Thanks Meter: 3
You can Report Bug To Blang
Old 06-12-2018, 07:42   #43 (permalink)
Member: 13148
Thanks Meter: 146
May be "write check for ROM1" at setting tab checked?
Old 06-12-2018, 10:23   #44 (permalink)
rico_deep's Avatar
Member: 159757
Thanks Meter: 429
thanks but solve by eMMC_tool Suite ver. 1.5.1.0
thanks easy
Old 06-15-2018, 21:45   #45 (permalink)
Member: 1551430
when i read emmc i create bin file
this file including user data ?
how can i, recover deleted data , from the "bad" emmc (not only to read the existing data on the chip)?
Page generated in 0.39353 seconds with 7 queries
