09-14-2015, 06:14 | #65 (permalink) |
Freak Poster Join Date: Nov 2004 Location: iran Age: 37
Member: 90307 Status: Offline Sonork: not hav e Thanks Meter: 24 | hi to all yesterday i wase i9301i dead boot emmc problem i use odin and select pit and a down a flash file from z3x support and clik on write emmc from yesterday 12:00 till now 9:00 oclock i mean more than15 houers it is writing am i doing write or am i chosing file error Looking for EasyJTAG box... EasyJTAG API v.1905 Setting IO Levels to 2.8V OpenUSB returned=0 Power Controller returned=0 EasyJTAG Box Serial=0B0B151354C839B0 EasyJTAG Box Firmware=01.52 eMMC Init returned=0 eMMC NAME = eMMC Blocks Count ROM1 = 1024 eMMC Blocks Count ROM2 = 0 eMMC Blocks Count ROM3 = 0 eMMC Init completed. ODIN: Writing PIT... Creating GPT-partitioninig Unpacking file non-hlos.bin and adding to image Offset for APNHLOS is 00400000 ODIN: Writing ROM1 <- non-hlos.bin - 0x00000008 blocks to eMMC offset 00400000 Offset for C:\Program Files\Z3X\EASYJTAG\temp\non-hlos.bin is 00400000 ODIN: Filesize 6981376 Blocks 13635 ODIN: Misalign 256 Bytes ODIN: FIX Filesize 6981632 Blocks 13636 ODIN: Now misalign is 0 Bytes ODIN: eMMC switching to ROM1 Done writing partition... Unpacking file modem.bin and adding to image Offset for MODEM is 01200000 ODIN: Writing ROM1 <- modem.bin - 0x00000008 blocks to eMMC offset 01200000 Offset for C:\Program Files\Z3X\EASYJTAG\temp\modem.bin is 01200000 ODIN: Filesize 42518272 Blocks 83043 ODIN: Misalign 256 Bytes ODIN: FIX Filesize 42518528 Blocks 83044 ODIN: Now misalign is 0 Bytes ODIN: eMMC switching to ROM1 Done writing partition... Unpacking file sbl1.mbn and adding to image Offset for SBL1 is 043C0000 ODIN: Writing ROM1 <- sbl1.mbn - 0x00000008 blocks to eMMC offset 043C0000 Offset for C:\Program Files\Z3X\EASYJTAG\temp\sbl1.mbn is 043C0000 ODIN: Filesize 265288 Blocks 518 ODIN: Misalign 72 Bytes ODIN: FIX Filesize 265728 Blocks 519 ODIN: Now misalign is 0 Bytes ODIN: eMMC switching to ROM1 Done writing partition... Unpacking file sdi.mbn and adding to image Offset for DBI is 04440000 ODIN: Writing ROM1 <- sdi.mbn - 0x00000008 blocks to eMMC offset 04440000 Offset for C:\Program Files\Z3X\EASYJTAG\temp\sdi.mbn is 04440000 ODIN: Filesize 32400 Blocks 63 ODIN: Misalign 144 Bytes ODIN: FIX Filesize 32768 Blocks 64 ODIN: Now misalign is 0 Bytes ODIN: eMMC switching to ROM1 Done writing partition... Unpacking file aboot.mbn and adding to image Offset for ABOOT is 04450000 ODIN: Writing ROM1 <- aboot.mbn - 0x00000008 blocks to eMMC offset 04450000 Offset for C:\Program Files\Z3X\EASYJTAG\temp\aboot.mbn is 04450000 ODIN: Filesize 931172 Blocks 1818 ODIN: Misalign 356 Bytes ODIN: FIX Filesize 931328 Blocks 1819 ODIN: Now misalign is 0 Bytes ODIN: eMMC switching to ROM1 Done writing partition... Unpacking file rpm.mbn and adding to image Offset for RPM is 04650000 ODIN: Writing ROM1 <- rpm.mbn - 0x00000008 blocks to eMMC offset 04650000 Offset for C:\Program Files\Z3X\EASYJTAG\temp\rpm.mbn is 04650000 ODIN: Filesize 162884 Blocks 318 ODIN: Misalign 68 Bytes ODIN: FIX Filesize 163328 Blocks 319 ODIN: Now misalign is 0 Bytes ODIN: eMMC switching to ROM1 Done writing partition... Unpacking file tz.mbn and adding to image Offset for TZ is 046D0000 ODIN: Writing ROM1 <- tz.mbn - 0x00000008 blocks to eMMC offset 046D0000 Offset for C:\Program Files\Z3X\EASYJTAG\temp\tz.mbn is 046D0000 ODIN: Filesize 357544 Blocks 698 ODIN: Misalign 168 Bytes ODIN: FIX Filesize 357888 Blocks 699 ODIN: Now misalign is 0 Bytes ODIN: eMMC switching to ROM1 Done writing partition... Unpacking file boot.img and adding to image Offset for BOOT is 06650000 ODIN: Writing ROM1 <- boot.img - 0x00000008 blocks to eMMC offset 06650000 Offset for C:\Program Files\Z3X\EASYJTAG\temp\boot.img is 06650000 ODIN: Filesize 7897360 Blocks 15424 ODIN: Misalign 272 Bytes ODIN: FIX Filesize 7897600 Blocks 15425 ODIN: Now misalign is 0 Bytes ODIN: eMMC switching to ROM1 Done writing partition... Unpacking file recovery.img and adding to image Offset for RECOVERY is 07050000 ODIN: Writing ROM1 <- recovery.img - 0x00000008 blocks to eMMC offset 07050000 Offset for C:\Program Files\Z3X\EASYJTAG\temp\recovery.img is 07050000 ODIN: Filesize 9105680 Blocks 17784 ODIN: Misalign 272 Bytes ODIN: FIX Filesize 9105920 Blocks 17785 ODIN: Now misalign is 0 Bytes ODIN: eMMC switching to ROM1 Done writing partition... Unpacking file system.img.ext4 and adding to image Offset for SYSTEM is 09F50000 ODIN: Writing ROM1 <- system.img.ext4 - 0x00000008 blocks to eMMC offset 09F50000 Offset for C:\Program Files\Z3X\EASYJTAG\temp\system.img.ext4 is 09F50000 ODIN: Filesize 1858958420 Blocks 3630778 ODIN: eMMC switching to ROM1 Sparse image found v. 00000001.00000001 Sparse header size : 0000001C Chunk header size : 0000000C Data Block size : 00001000 8 pages Total blocks : 512000 Total chunks : 3162 Image CRC32 : 00000000 ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 00000001 Total data size: 0000100C CHUNK_TYPE_RAW : 00000028 is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 00000001 Total data size: 0000100C CHUNK_TYPE_RAW : 00001034 is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 00000010 Total data size: 0001000C CHUNK_TYPE_RAW : 00002040 is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 00000010 Total data size: 0001000C CHUNK_TYPE_RAW : 0001204C is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 000001F4 Total data size: 001F400C CHUNK_TYPE_RAW : 00022058 is RAW ------------------------------ Chunk type : CAC3 Reserved data : 0000 Output data size : 00001D4C Total data size: 0000000C CHUNK_TYPE_DONT_CARE : 00216064 is DONT CARE ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 00001F40 Total data size: 01F4000C CHUNK_TYPE_RAW : 00216070 is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 00000001 Total data size: 0000100C CHUNK_TYPE_RAW : 0215607C is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 00000001 Total data size: 0000100C CHUNK_TYPE_RAW : 02157088 is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 00000001 Total data size: 0000100C CHUNK_TYPE_RAW : 02158094 is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 00000001 Total data size: 0000100C CHUNK_TYPE_RAW : 021590A0 is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 00000018 Total data size: 0001800C CHUNK_TYPE_RAW : 0215A0AC is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 0000017A Total data size: 0017A00C CHUNK_TYPE_RAW : 021720B8 is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 00000001 Total data size: 0000100C CHUNK_TYPE_RAW : 022EC0C4 is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 00000001 Total data size: 0000100C CHUNK_TYPE_RAW : 022ED0D0 is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 00000069 Total data size: 0006900C CHUNK_TYPE_RAW : 022EE0DC is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 00000037 Total data size: 0003700C CHUNK_TYPE_RAW : 023570E8 is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 0000009A Total data size: 0009A00C CHUNK_TYPE_RAW : 0238E0F4 is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 00000039 Total data size: 0003900C CHUNK_TYPE_RAW : 02428100 is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 000001A6 Total data size: 001A600C CHUNK_TYPE_RAW : 0246110C is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 00000058 Total data size: 0005800C CHUNK_TYPE_RAW : 02607118 is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 00000047 Total data size: 0004700C CHUNK_TYPE_RAW : 0265F124 is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 0000000A Total data size: 0000A00C CHUNK_TYPE_RAW : 026A6130 is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 0000001F Total data size: 0001F00C CHUNK_TYPE_RAW : 026B013C is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 00000279 Total data size: 0027900C CHUNK_TYPE_RAW : 026CF148 is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 00000089 Total data size: 0008900C CHUNK_TYPE_RAW : 02948154 is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 00000001 Total data size: 0000100C CHUNK_TYPE_RAW : 029D1160 is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 00000021 Total data size: 0002100C CHUNK_TYPE_RAW : 029D216C is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 00000001 Total data size: 0000100C CHUNK_TYPE_RAW : 029F3178 is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 00000001 Total data size: 0000100C CHUNK_TYPE_RAW : 029F4184 is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 00000001 Total data size: 0000100C CHUNK_TYPE_RAW : 029F5190 is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 00000001 Total data size: 0000100C CHUNK_TYPE_RAW : 029F619C is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 00000003 Total data size: 0000300C CHUNK_TYPE_RAW : 029F71A8 is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 00000001 Total data size: 0000100C CHUNK_TYPE_RAW : 029FA1B4 is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 00000013 Total data size: 0001300C CHUNK_TYPE_RAW : 029FB1C0 is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 00000001 Total data size: 0000100C CHUNK_TYPE_RAW : 02A0E1CC is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 00000001 Total data size: 0000100C CHUNK_TYPE_RAW : 02A0F1D8 is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 00000001 Total data size: 0000100C CHUNK_TYPE_RAW : 02A101E4 is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 00000001 Total data size: 0000100C CHUNK_TYPE_RAW : 02A111F0 is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 00000001 Total data size: 0000100C CHUNK_TYPE_RAW : 02A121FC is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 00000001 Total data size: 0000100C CHUNK_TYPE_RAW : 02A13208 is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 00000001 Total data size: 0000100C CHUNK_TYPE_RAW : 02A14214 is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 0000000D Total data size: 0000D00C CHUNK_TYPE_RAW : 02A15220 is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 00000002 Total data size: 0000200C CHUNK_TYPE_RAW : 02A2222C is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 00000002 Total data size: 0000200C CHUNK_TYPE_RAW : 02A24238 is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 00000002 Total data size: 0000200C CHUNK_TYPE_RAW : 02A26244 is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 00000002 Total data size: 0000200C CHUNK_TYPE_RAW : 02A28250 is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 00000001 Total data size: 0000100C CHUNK_TYPE_RAW : 02A2A25C is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 00000002 Total data size: 0000200C CHUNK_TYPE_RAW : 02A2B268 is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 0000003B Total data size: 0003B00C CHUNK_TYPE_RAW : 02A2D274 is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 00000014 Total data size: 0001400C CHUNK_TYPE_RAW : 02A68280 is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 0000068C Total data size: 0068C00C CHUNK_TYPE_RAW : 02A7C28C is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 00000158 Total data size: 0015800C CHUNK_TYPE_RAW : 03108298 is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 00000091 Total data size: 0009100C CHUNK_TYPE_RAW : 032602A4 is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 0000000F Total data size: 0000F00C CHUNK_TYPE_RAW : 032F12B0 is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 00000059 Total data size: 0005900C CHUNK_TYPE_RAW : 033002BC is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 0000000B Total data size: 0000B00C CHUNK_TYPE_RAW : 033592C8 is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 0000001F Total data size: 0001F00C CHUNK_TYPE_RAW : 033642D4 is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 00000058 Total data size: 0005800C CHUNK_TYPE_RAW : 033832E0 is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 0000002B Total data size: 0002B00C CHUNK_TYPE_RAW : 033DB2EC is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 000000AF Total data size: 000AF00C CHUNK_TYPE_RAW : 034062F8 is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 00000021 Total data size: 0002100C CHUNK_TYPE_RAW : 034B5304 is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 00000090 Total data size: 0009000C CHUNK_TYPE_RAW : 034D6310 is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 0000008C Total data size: 0008C00C CHUNK_TYPE_RAW : 0356631C is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 000000E4 Total data size: 000E400C CHUNK_TYPE_RAW : 035F2328 is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 00000060 Total data size: 0006000C CHUNK_TYPE_RAW : 036D6334 is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 00000006 Total data size: 0000600C CHUNK_TYPE_RAW : 03736340 is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 00000007 Total data size: 0000700C CHUNK_TYPE_RAW : 0373C34C is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 0000008D Total data size: 0008D00C CHUNK_TYPE_RAW : 03743358 is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 000000D5 Total data size: 000D500C CHUNK_TYPE_RAW : 037D0364 is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 00000002 Total data size: 0000200C CHUNK_TYPE_RAW : 038A5370 is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 0000000B Total data size: 0000B00C CHUNK_TYPE_RAW : 038A737C is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 00000002 Total data size: 0000200C CHUNK_TYPE_RAW : 038B2388 is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 00000003 Total data size: 0000300C CHUNK_TYPE_RAW : 038B4394 is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 00000082 Total data size: 0008200C CHUNK_TYPE_RAW : 038B73A0 is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 00000007 Total data size: 0000700C CHUNK_TYPE_RAW : 039393AC is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 00000005 Total data size: 0000500C CHUNK_TYPE_RAW : 039403B8 is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 000000B8 Total data size: 000B800C CHUNK_TYPE_RAW : 039453C4 is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 00000120 Total data size: 0012000C CHUNK_TYPE_RAW : 039FD3D0 is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 00000003 Total data size: 0000300C CHUNK_TYPE_RAW : 03B1D3DC is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 0000000C Total data size: 0000C00C CHUNK_TYPE_RAW : 03B203E8 is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 00000072 Total data size: 0007200C CHUNK_TYPE_RAW : 03B2C3F4 is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 00000923 Total data size: 0092300C CHUNK_TYPE_RAW : 03B9E400 is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 0000000A Total data size: 0000A00C CHUNK_TYPE_RAW : 044C140C is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 00000005 Total data size: 0000500C CHUNK_TYPE_RAW : 044CB418 is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 00000037 Total data size: 0003700C CHUNK_TYPE_RAW : 044D0424 is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 0000000A Total data size: 0000A00C CHUNK_TYPE_RAW : 04507430 is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 00000B96 Total data size: 00B9600C CHUNK_TYPE_RAW : 0451143C is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 000000F5 Total data size: 000F500C CHUNK_TYPE_RAW : 050A7448 is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 00000B90 Total data size: 00B9000C CHUNK_TYPE_RAW : 0519C454 is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 00000007 Total data size: 0000700C CHUNK_TYPE_RAW : 05D2C460 is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 00000008 Total data size: 0000800C CHUNK_TYPE_RAW : 05D3346C is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 000002C0 Total data size: 002C000C CHUNK_TYPE_RAW : 05D3B478 is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 0000022F Total data size: 0022F00C CHUNK_TYPE_RAW : 05FFB484 is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 00000016 Total data size: 0001600C CHUNK_TYPE_RAW : 0622A490 is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 00000031 Total data size: 0003100C CHUNK_TYPE_RAW : 0624049C is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 00000007 Total data size: 0000700C CHUNK_TYPE_RAW : 062714A8 is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 0000001A Total data size: 0001A00C CHUNK_TYPE_RAW : 062784B4 is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 0000000F Total data size: 0000F00C CHUNK_TYPE_RAW : 062924C0 is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 00000001 Total data size: 0000100C CHUNK_TYPE_RAW : 062A14CC is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 00000003 Total data size: 0000300C CHUNK_TYPE_RAW : 062A24D8 is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 00000001 Total data size: 0000100C CHUNK_TYPE_RAW : 062A54E4 is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 00000004 Total data size: 0000400C CHUNK_TYPE_RAW : 062A64F0 is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 00000002 Total data size: 0000200C CHUNK_TYPE_RAW : 062AA4FC is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 00000005 Total data size: 0000500C CHUNK_TYPE_RAW : 062AC508 is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 00000002 Total data size: 0000200C CHUNK_TYPE_RAW : 062B1514 is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 00000001 Total data size: 0000100C CHUNK_TYPE_RAW : 062B3520 is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 00000001 Total data size: 0000100C CHUNK_TYPE_RAW : 062B452C is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 00000001 Total data size: 0000100C CHUNK_TYPE_RAW : 062B5538 is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 000010DE Total data size: 010DE00C CHUNK_TYPE_RAW : 062B6544 is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 0000010B Total data size: 0010B00C CHUNK_TYPE_RAW : 07394550 is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 0000011F Total data size: 0011F00C CHUNK_TYPE_RAW : 0749F55C is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 0000003A Total data size: 0003A00C CHUNK_TYPE_RAW : 075BE568 is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 00000076 Total data size: 0007600C CHUNK_TYPE_RAW : 075F8574 is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 00000810 Total data size: 0081000C CHUNK_TYPE_RAW : 0766E580 is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 00000A94 Total data size: 00A9400C CHUNK_TYPE_RAW : 07E7E58C is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 000002C7 Total data size: 002C700C CHUNK_TYPE_RAW : 08912598 is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 00000176 Total data size: 0017600C CHUNK_TYPE_RAW : 08BD95A4 is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 00000024 Total data size: 0002400C CHUNK_TYPE_RAW : 08D4F5B0 is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 00000026 Total data size: 0002600C CHUNK_TYPE_RAW : 08D735BC is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 00000031 Total data size: 0003100C CHUNK_TYPE_RAW : 08D995C8 is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 00000060 Total data size: 0006000C CHUNK_TYPE_RAW : 08DCA5D4 is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 00000132 Total data size: 0013200C CHUNK_TYPE_RAW : 08E2A5E0 is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 00000019 Total data size: 0001900C CHUNK_TYPE_RAW : 08F5C5EC is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 0000001F Total data size: 0001F00C CHUNK_TYPE_RAW : 08F755F8 is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 0000009C Total data size: 0009C00C CHUNK_TYPE_RAW : 08F94604 is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 0000000C Total data size: 0000C00C CHUNK_TYPE_RAW : 09030610 is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 000004FD Total data size: 004FD00C CHUNK_TYPE_RAW : 0903C61C is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 00000E94 Total data size: 00E9400C CHUNK_TYPE_RAW : 09539628 is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 0000007D Total data size: 0007D00C CHUNK_TYPE_RAW : 0A3CD634 is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 00000ABB Total data size: 00ABB00C CHUNK_TYPE_RAW : 0A44A640 is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 000000B8 Total data size: 000B800C CHUNK_TYPE_RAW : 0AF0564C is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 00000033 Total data size: 0003300C CHUNK_TYPE_RAW : 0AFBD658 is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 0000000C Total data size: 0000C00C CHUNK_TYPE_RAW : 0AFF0664 is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 00000AA6 Total data size: 00AA600C CHUNK_TYPE_RAW : 0AFFC670 is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 00000D03 Total data size: 00D0300C CHUNK_TYPE_RAW : 0BAA267C is RAW ------------------------------ Chunk type : CAC1 Reserved data : 0000 Output data size : 000003EA Total data size: 003EA00C CHUNK_TYPE_RAW : 0C7A5688 is RAW but now finished till now Last edited by QASSEM; 09-14-2015 at 06:21. |
09-14-2015, 07:40 | #67 (permalink) | |
No Life Poster Join Date: Jun 2007 Location: Rangpur Bangladesh
Member: 526223 Status: Offline Sonork: 100.1605395 Thanks Meter: 106 | Quote:
need video step by step help. how to connect. | |
09-15-2015, 06:07 | #73 (permalink) |
Member: 90307 Status: Offline Sonork: not hav e Thanks Meter: 24 | after 48 houres writing firmwar with pit not done and fone dead i need ergent help Looking for EasyJTAG box... EasyJTAG API v.1905 Setting IO Levels to 2.8V OpenUSB OK Power Controller returned=0 EasyJTAG Box Serial=0B0B151354C839B0 EasyJTAG Box Firmware=01.52 eMMC Init returned=0 eMMC NAME = eMMC Blocks Count ROM1 = 1024 eMMC Blocks Count ROM2 = 0 eMMC Blocks Count ROM3 = 0 eMMC Init completed. |
09-15-2015, 11:53 | #74 (permalink) |
No Life Poster Join Date: Dec 2014 Location: u.a.e
Member: 2320256 Status: Offline Sonork: 100.1661545 Thanks Meter: 50 | where we can find good pit file please upload in support pit file in easy jtag section |
The Following User Says Thank You to mojahed.br For This Useful Post: |
