05-17-2016, 14:45 | #32 (permalink) |
Freak Poster Join Date: Jan 2008 Location: phone care
Member: 667941 Status: Offline Sonork: 100.1611812 Thanks Meter: 61 | this time and first time got success with j700h .easyjtag rock.keep smile on. EasyJtag Suite ver.: 2.1.1.1 / wxWidgets 3.1.0-W-U started. Operating system ver.: Windows 7 (build 7601, Service Pack 1), 64-bit edition. undefined Android Explorer ver.: 1.0.0.5 eMMC ODIN ver.: 1.0.0.7 Successfully connected to box on COM5 Box S/N: 0F0FFB06B6B7995C, ,FW Ver.: 01.55 Box Working Mode: JTAG Box. Box Drivers version: 3.0.1.0, are OK Z3X Card Serial : AA20-FE5C , ver: 22 Z3X Card Activation [LG] : NOT ACTIVATED , ACTIVATE NOW Z3X Card Activation [SAMS] : NOT ACTIVATED , ACTIVATE NOW Z3X Card Activation [JTAG] : ACTIVATED Z3X EasyJtag Software ver. 2.1.1.1 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: 0F0FFB06B6B7995C, ,FW Ver.: 01.55 CMD Pullup Level:505 mV CMD Active Level:1959 mV Box IO Level:2800 mV CLK Rate:14000 khz HiPower™ mode is off! eMMC Device Information EMMC CID : 1101003430303037330047D2B8ECA284 EMMC CSD : D07E00320F5903FFFFFFFFE78A4000D0 EMMC Manufacturer ID: 0011 , OEM ID: 0100 EMMC Date: 10/2015 Rev.0x0 EMMC NAME: 400073 , S/N: 1204992236 EMMC NAME (HEX): 34303030373300 EMMC ROM1 (Main User Data) Capacity: 15028 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD rev 1.7 (MMC 5.0) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: 400073_1204992236_20160517_1635.extcsd Searching for partition tables... Detected GPT over MBR... Warning: Header Size = 512 (expected 92) Medium UUID: 52444E41-494F-2044-4D4D-43204449534B Warning: Entries Count = 128 MMCBLK0P0 (BOTA0) Range: [0X400000,0X7FFE00] ,Len: 400000 MMCBLK0P1 (BOTA1) Range: [0X800000,0XBFFE00] ,Len: 400000 MMCBLK0P2 (EFS) Range: [0XC00000,0X1FFFE00] ,Len: 1400000 MMCBLK0P3 (CPEFS) Range: [0X2000000,0X27FFE00] ,Len: 800000 MMCBLK0P4 (M9KEFS1) Range: [0X2800000,0X2BFFE00] ,Len: 400000 MMCBLK0P5 (M9KEFS2) Range: [0X2C00000,0X2FFFE00] ,Len: 400000 MMCBLK0P6 (M9KEFS3) Range: [0X3000000,0X33FFE00] ,Len: 400000 MMCBLK0P7 (CARRIER) Range: [0X3400000,0X34FFE00] ,Len: 100000 MMCBLK0P8 (PARAM) Range: [0X3500000,0X3CFFE00] ,Len: 800000 MMCBLK0P9 (BOOT) Range: [0X3D00000,0X5CFFE00] ,Len: 2000000 MMCBLK0P10 (RECOVERY) Range: [0X5D00000,0X82FFE00] ,Len: 2600000 MMCBLK0P11 (OTA) Range: [0X8300000,0X8AFFE00] ,Len: 800000 MMCBLK0P12 (CDMA-RADIO) Range: [0X8B00000,0X8EFFE00] ,Len: 400000 MMCBLK0P13 (RADIO) Range: [0X8F00000,0XE6FFE00] ,Len: 5800000 MMCBLK0P14 (TOMBSTONES) Range: [0XE700000,0XE7FFE00] ,Len: 100000 MMCBLK0P15 (DNT) Range: [0XE800000,0XE8FFE00] ,Len: 100000 MMCBLK0P16 (PERSISTENT) Range: [0XE900000,0XE97FE00] ,Len: 80000 MMCBLK0P17 (PERSDATA) Range: [0XE980000,0XF57FE00] ,Len: C00000 MMCBLK0P18 (RESERVED2) Range: [0XF580000,0XF7FFE00] ,Len: 280000 MMCBLK0P19 (SYSTEM) Range: [0XF800000,0X92FFFE00] ,Len: 83800000 MMCBLK0P20 (CACHE) Range: [0X93000000,0X9F7FFE00] ,Len: C800000 MMCBLK0P21 (HIDDEN) Range: [0X9F800000,0XA1FFFE00] ,Len: 2800000 MMCBLK0P22 (USERDATA) Range: [0XA2000000,0X3AAFFFE00] ,Len: 309000000 Done...Presets has been updated... Done. You must select flash file first! Checking NAND Image : F:\sasmung\j700h\dump\SAMSUNG_SM_J700F_ROM2_J700HX XU2APD1_ROM2_ROM3\ROM2_J700HXXU2APD1.bin File successefuly loaded! Processing file...F:\sasmung\j700h\dump\SAMSUNG_SM_J700F_ROM2 _J700HXXU2APD1_ROM2_ROM3\ROM2_J700HXXU2APD1.bin Z3X EasyJtag Software ver. 2.1.1.1 Skip loading eMMC Addon Firmware CMD Pullup Level:505 mV CMD Active Level:1959 mV Input file : F:\sasmung\j700h\dump\SAMSUNG_SM_J700F_ROM2_J700HX XU2APD1_ROM2_ROM3\ROM2_J700HXXU2APD1.bin Writing 0000400000 bytes to 00000000 ...ROM2 (BOOT1 ROM) Done. Write Speed: 1437 kB/s Checking NAND Image : F:\sasmung\j700h\dump\SAMSUNG_SM_J700F_ROM2_J700HX XU2APD1_ROM2_ROM3\ROM3_J700HXXU2APD1.bin File successefuly loaded! Processing file...F:\sasmung\j700h\dump\SAMSUNG_SM_J700F_ROM2 _J700HXXU2APD1_ROM2_ROM3\ROM3_J700HXXU2APD1.bin Z3X EasyJtag Software ver. 2.1.1.1 Skip loading eMMC Addon Firmware CMD Pullup Level:505 mV CMD Active Level:1959 mV Input file : F:\sasmung\j700h\dump\SAMSUNG_SM_J700F_ROM2_J700HX XU2APD1_ROM2_ROM3\ROM3_J700HXXU2APD1.bin Writing 0000400000 bytes to 00000000 ...ROM3 (BOOT2 ROM) Done. Write Speed: 1639 kB/s |
The Following User Says Thank You to anjuman For This Useful Post: |
05-19-2016, 22:48 | #37 (permalink) | |
Freak Poster Join Date: Oct 2013
Member: 2037770 Status: Offline Thanks Meter: 114 | Quote:
bro can you upload a photo for the connections on PCB please? i really need this for my own dead J700H BR, | |
The Following User Says Thank You to mr.p3rfekt For This Useful Post: |
05-19-2016, 23:16 | #38 (permalink) |
Member: 667941 Status: Offline Sonork: 100.1611812 Thanks Meter: 61 | this time sorry i don`t have any device in hand if i will get .i will show. you...no problem. |
05-28-2016, 07:38 | #42 (permalink) |
Freak Poster Join Date: Feb 2011 Location: JEMBER - indonesia Age: 36
Member: 1506640 Status: Offline Thanks Meter: 38 | if the feature scatter mtk flasher no easy jtag, I believe no longer be left behind by its .. mtk flasher flash features via an ISP or socket adapter, is needed in china mtk mobile phone repair and auto partition .. This may represent all the input from my mobile phone technicians I apologize if my criticisms made z3x team upset ... |
The Following User Says Thank You to ari.s For This Useful Post: |
05-30-2016, 06:26 | #43 (permalink) |
Insane Poster Join Date: Mar 2016 Location: nepal
Member: 2544709 Status: Offline Sonork: shivapradhan0 Thanks Meter: 25 | there is something wrong in easy jtag .....today when i tried to deadboot repair karbonn titanium s5 ...connected isp pinout...but jtag was unable to find jtag pinout ....could not connect phone....then when i tried with atf jtag all gone success....successfully repaired with atf jtag.....why is this problem with my easy jtag.....i am running latest updates....latest box firmware....plz reply team i have got this errors on many phones.....no pinout found |
05-30-2016, 10:17 | #45 (permalink) | |
Product Supporter Join Date: May 2011
Member: 1569669 Status: Offline Thanks Meter: 257 | Quote:
Try to use pull-up resistors 100 ohm between CMD and 1.8V, DAT0 and 1.8V like ATF. Please, show log, let me know phone model, make photo of your setup etc. I need more info to resolve this problem ! It can be box hw issue (some soldering problem) or some ISP to box incorrect connection (some third party ISP adapters has incorrect GND connection). Best Regards Last edited by vikboston; 05-30-2016 at 10:41. | |
The Following User Says Thank You to vikboston For This Useful Post: |
