Old 07-15-2016, 12:48   #16 (permalink)
Member: 1314806
Sonork: 100.1000
Thanks Meter: 80
Originally Posted by Repair4u View Post
Please add lg d855 ,if possible
Supported long time ago
Enviado desde mi SM-G925I mediante Tapatalk
Old 07-15-2016, 12:49   #17 (permalink)
Member: 1314806
Sonork: 100.1000
Thanks Meter: 80
Originally Posted by Kashembd View Post
good update..........good job......
please update sm-j700f dead bood repear.......
Old 07-15-2016, 13:13   #18 (permalink)
MARVZ_TG's Avatar
Member: 990711
Sonork: 100.1597405
Thanks Meter: 1,779
any one tested repair boot file for j700h
Loading eMMC Addon Firmware... IO: 3300 mV
Box S/N: 161609229E54864B, ,FW Ver.: 01.55
CMD Pullup Level:474 mV
CMD Active Level:2351 mV
Box IO Level:3300 mV
CLK Rate:14000 khz
HiPower™ mode is off!
eMMC Device Information
EMMC CID : 1101003430303037330084DA289962D6
EMMC CSD : D07E00320F5903FFFFFFFFE78A4000D0
EMMC Manufacturer ID: 0011 , OEM ID: 0100
EMMC Date: 06/2015 Rev.0x0
EMMC NAME: 400073 , S/N: 2228889753
EMMC NAME (HEX): 34303030373300
EMMC ROM1 (Main User Data) Capacity: 15028 MB
EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB
EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
Extended CSD rev 1.7 (MMC 5.0)
Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1)
Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48.
H/W reset function [RST_N_FUNCTION]: 0x00
High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00]
Partitioning Support [PARTITIONING_SUPPORT]: 0x07
Device support partitioning feature
Device can have enhanced tech.
Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: 400073_2228889753_20160715_1950.extcsd
Done.
Old 07-15-2016, 13:35   #19 (permalink)
Member: 1757759
upload setup on support.
big big upadte easy jtag
Old 07-15-2016, 13:45   #20 (permalink)
sureshlion's Avatar
Member: 700441
Thanks Meter: 71
Talking Goo update team
Nice update team
Regards
Kanth.suresh
Old 07-15-2016, 18:20   #21 (permalink)
Member: 1073402
Thanks Meter: 35
Help Team
I need help with this error team
http://www.youtube.com/watch?v=y5mNMGGbw1c
Old 07-15-2016, 18:56   #22 (permalink)
Member: 86034
Thanks Meter: 60
yes big update very thanks but please add more video or manual for how to use
Old 07-15-2016, 21:21   #23 (permalink)
Member: 714648
Sonork: 1609640
Thanks Meter: 931
i need pinout emmc for LG VS930
on support not show CMD
Hi,
Use CMD pinout from here:
https://gyazo.com/b7d28bfa3774ab6f53605635ee552e79
Thank you for cooperation!
Best Regards
Old 07-15-2016, 22:24   #24 (permalink)
Member: 334901
Thanks Meter: 28
you can't open bin file it's not supported for this job
Old 07-15-2016, 22:44   #25 (permalink)
Member: 1569669
Thanks Meter: 257
Hi,
At this moment Easy Repair tab works only with JTAG interface and .rcp files.
Steps to repair phone via eMMC direct interface:
1. Press Download Files From Support ;-) button in Easy Repair Tab. After that type part of phone name "SM-G360M" in <Type part of filename here >", then save searched file (typically .rar or .zip ).
2. Unpack .rar or .zip file, then use eMMC Tool tab
3. You can use Region tab to search partitions in dump (Image:Select eMMC Image file *.bin), select required partitions and write into eMMC.
We will add automatic search support file by selected model and one click repair via eMMC interface in next updates.
Thank you for cooperation and reporting problems.
Best Regards
The Following User Says Thank You to vikboston For This Useful Post:
Old 07-15-2016, 23:00   #26 (permalink)
Member: 1073402
Thanks Meter: 35
as would be the correct method of writing Dumps
Old 07-15-2016, 23:29   #27 (permalink)
Member: 1569669
Thanks Meter: 257
Easy Repair works only for JTAG interface .rcp file.
For eMMC direct, please unpack support files and use eMMC direct Flasher.
Best Regards
Old 07-15-2016, 23:30   #28 (permalink)
andreiza's Avatar
Member: 793212
Thanks Meter: 29
Originally Posted by nurulfaiq View Post
sorry after disable avast antivirus problem solved
ohhhhh nooooo..............
Old 07-16-2016, 05:50   #29 (permalink)
Member: 532514
Sonork: 100.1658309
Thanks Meter: 32
Old 07-16-2016, 06:10   #30 (permalink)
Fusion Rock's Avatar
Member: 1930738
Sonork: 100.1638397
Thanks Meter: 80
support МOTOROLA MOTO XT1022 (ISP Pinout, Dumps)
Nice update
Page generated in 0.21256 seconds with 9 queries
