11-07-2019, 23:14 | #1 (permalink) |
Freak Poster Join Date: Oct 2011 Location: Annaba, ALGERIA
Member: 1678953 Status: Offline Thanks Meter: 67 | Succes Report : Oppo F1 Data Recovery i wanted to share with you a succes report of a "chip off" data recovery of an oppo F1f, i do this because of the high speed of the operation, so thank you EasyJtag Plus team for this, here is the log : Code: eMMC_tool Suite ver. 1.6.2.0 (release date: 30.06.2019) Microsoft Windows 8 (64 bit) build 2600 (10.0.18362.418) Looking for EasyJTAG box... EasyJTAG API ver. 3307 EasyJTAG Box Serial = E5E2527729103A7A Card Serial = AA125B25 EasyJTAG Box Firmware = 2.48 Changelog: 30.06.2019 (ver 1.6.1.0) Fix: Bugs that have been found through your crash report Setting interface to EasyJtag2/E-Socket Setting bus width to 8 Bit Setting frequence to 42 MHz EMMC Device Information : EMMC CID: 150100524531424D420781B8DE563391 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: RE1BMB , HEX: 524531424D42 , S/N: 81B8DE56 , rev. 0x07 EMMC ROM 1 (Main User Data) Capacity: 14910 MB (0003A3E00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 0 , Response: Clean Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [179] / Boot Bus Config [177] / H/W Reset Function [162]: 0x38 / 0x00 / 0x01 Supported partition features [PARTITIONING_SUPPORT]: 0x07 Backup saved: RE1BMB_81B8DE56_20191107_224236.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: modem, [000004000000 - 000008000000], size: 000004000000 (64,0 MB) Partition: DDR, [000008000000 - 000008008000], size: 000000008000 (32,0 KB) Partition: fsg, [000008008000 - 000008188000], size: 000000180000 (1,50 MB) Partition: sec, [000008188000 - 00000818C000], size: 000000004000 (16,0 KB) Partition: fsc, [00000C000000 - 00000C000400], size: 000000000400 (1,00 KB) Partition: ssd, [00000C000400 - 00000C002400], size: 000000002000 (8,00 KB) Partition: sbl1, [00000C002400 - 00000C082400], size: 000000080000 (512 KB) Partition: sbl1bak, [00000C082400 - 00000C102400], size: 000000080000 (512 KB) Partition: aboot, [000010000000 - 000010100000], size: 000000100000 (1,00 MB) Partition: abootbak, [000010100000 - 000010200000], size: 000000100000 (1,00 MB) Partition: rpm, [000014000000 - 000014080000], size: 000000080000 (512 KB) Partition: rpmbak, [000014080000 - 000014100000], size: 000000080000 (512 KB) Partition: tz, [000014100000 - 000014180000], size: 000000080000 (512 KB) Partition: tzbak, [000014180000 - 000014200000], size: 000000080000 (512 KB) Partition: hyp, [000014200000 - 000014280000], size: 000000080000 (512 KB) Partition: hypbak, [000014280000 - 000014300000], size: 000000080000 (512 KB) Partition: modemst1, [000014300000 - 000014480000], size: 000000180000 (1,50 MB) Partition: modemst2, [000014480000 - 000014600000], size: 000000180000 (1,50 MB) Partition: oppodycnvbk, [000014600000 - 000015000000], size: 000000A00000 (10,0 MB) Partition: oppostanvbk, [000015000000 - 000015A00000], size: 000000A00000 (10,0 MB) Partition: LOGO, [000015A00000 - 000016A00000], size: 000001000000 (16,0 MB) Partition: boot, [000018000000 - 00001A000000], size: 000002000000 (32,0 MB) Partition: recovery, [00001A000000 - 00001C000000], size: 000002000000 (32,0 MB) Partition: system, [00001C000000 - 0000CC000000], size: 0000B0000000 (2,75 GB) Partition: devinfo, [0000CC000000 - 0000CC100000], size: 000000100000 (1,00 MB) Partition: cache, [0000D0000000 - 0000D8000000], size: 000008000000 (128 MB) Partition: persist, [0000D8000000 - 0000DA000000], size: 000002000000 (32,0 MB) Partition: misc, [0000DA000000 - 0000DA100000], size: 000000100000 (1,00 MB) Partition: keystore, [0000DA100000 - 0000DA180000], size: 000000080000 (512 KB) Partition: config, [0000DA180000 - 0000DA188000], size: 000000008000 (32,0 KB) Partition: oem, [0000DA188000 - 0000DE188000], size: 000004000000 (64,0 MB) Partition: DRIVER, [0000DE188000 - 0000E0188000], size: 000002000000 (32,0 MB) Partition: reserve1, [0000E0188000 - 0000E0388000], size: 000000200000 (2,00 MB) Partition: reserve2, [0000E0388000 - 0000E1388000], size: 000001000000 (16,0 MB) Partition: reserve3, [0000E1388000 - 0000E1588000], size: 000000200000 (2,00 MB) Partition: reserve4, [0000E1588000 - 0000E2588000], size: 000001000000 (16,0 MB) Partition: userdata, [0000E2588000 - 0003A3DFBE00], size: 0002C1873E00 (11,0 GB) GPT header successfully parsed Get firmware version Brand = OPPO Manufacturer = OPPO Device = F1f Model = F1f Phone platform = msm8916 CPU Abi = arm64-v8a Android release = 5.1.1 Firmware version = F1EX_11_171125 Firmware date = Sat Nov 25 12:25:36 CST 2017 Setting interface to EasyJtag2/E-Socket Setting bus width to 8 Bit Setting frequence to 42 MHz EMMC Device Information : EMMC CID: 150100524531424D420781B8DE563391 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: RE1BMB , HEX: 524531424D42 , S/N: 81B8DE56 , rev. 0x07 EMMC ROM 1 (Main User Data) Capacity: 14910 MB (0003A3E00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 0 , Response: Clean Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [179] / Boot Bus Config [177] / H/W Reset Function [162]: 0x38 / 0x00 / 0x01 Supported partition features [PARTITIONING_SUPPORT]: 0x07 Backup saved: RE1BMB_81B8DE56_20191107_224302.extcsd EMMC Init completed. Operation: File Explorer... Scan from: RE1BMB Vendor: Qualcomm Searching GPT ... GPT header is found and is valid GPT header successfully parsed Scan done Mount [modem] successfully PartType: FAT16 Mount [system] successfully PartType: LINUX Mount [cache] successfully PartType: LINUX Mount [persist] successfully PartType: LINUX Mount [config] SKIPPED PartType: FRP <<< FRP !!! Mount [data] successfully PartType: LINUX Get firmware version Brand = OPPO Manufacturer = OPPO Device = F1f Model = F1f Phone platform = msm8916 CPU Abi = arm64-v8a Android release = 5.1.1 Firmware version = F1EX_11_171125 Firmware date = Sat Nov 25 12:25:36 CST 2017 Saving dir: [0] Completed: [00:09:26:551] All done |
