Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Easy-Jtag
Old 12-09-2016, 07:08   #16 (permalink)
Member: 2204951
nice update z3x team
thank you
Old 12-09-2016, 07:11   #17 (permalink)
Member: 2488951
easy jtag usb mode flashing is possible....
Old 12-09-2016, 07:52   #18 (permalink)
reset12345's Avatar
Member: 694652
Sonork: 100.1669706
Thanks Meter: 173
Arrow
Like That Samsung Lg.Must Be Adding
Old 12-09-2016, 12:28   #19 (permalink)
telmagdy's Avatar
Member: 1494964
Sonork: 100.100.573
Thanks Meter: 97
nice update,thank u team .....
Old 12-09-2016, 13:18   #20 (permalink)
NoName®'s Avatar
Member: 129885
Sonork: 100:1603514
Thanks Meter: 5,752
We left some food for jellyfishes )
The Following User Says Thank You to NoName® For This Useful Post:
Old 12-09-2016, 14:30   #21 (permalink)
Member: 2461262
Thanks Meter: 10
where is j320h i cant find z3x shell please, give me link
Old 12-09-2016, 14:58   #22 (permalink)
Member: 2461262
Thanks Meter: 10
after shell update i found j320h dump
Old 12-09-2016, 15:16   #23 (permalink)
Member: 809650
Thanks Meter: 12
EMMC CID : 02000053444D30333290FFFFFFFF29BC
EMMC CSD : 8C0F002A015981E9B6D9FC1F8A4040AA
EMMC Manufacturer ID: 0002 , OEM ID: 0000
EMMC Date: 02/2006 Rev.0x90
EMMC NAME: SDM032 , S/N: 4294967295
EMMC NAME (HEX): 53444D30333200
EMMC ROM1 (Main User Data) Capacity: 30 MB
EMMC ROM2 (Boot Partition 1) Capacity: 0 kB
EMMC ROM3 (Boot Partition 2) Capacity: 0 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 0 kB
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
EMMC Password Locked: No
Extended CSD rev 1.0 (MMC 4.0)
Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured.
Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00.
H/W reset function [RST_N_FUNCTION]: 0x00
High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000]
Partitioning Support [PARTITIONING_SUPPORT]: 0x00
Device NOT support partitioning feature
Device cannot have enhanced tech.
Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: SDM032_4294967295_20161209_1911.extcsd
Done.
Z3X EasyJtag Software ver. 2.5.0.3
Skip loading eMMC Addon Firmware
CMD Pullup Level:2093 mV
CMD Active Level:2423 mV
Box IO Level:2800 mV
CLK Rate:14000 khz
Reading 0x000000020000 bytes from 0x000000000000 ...ROM1 ( USER ROM)
Output file :C:\Users\student79\Desktop\e330s dump\EMMC_ROM1_SDM032_4294967295_00000000_00020000 .bin
Retry reading adress 0x00000000 (Attempt #0)
Retry Fail!
Retry Fail!
Retry Fail!
Retry Fail!
Retry Fail!
Read Block Failed, Reason: CARD Data FIFO Timeout Error
Done.
Running:eMMC: Factory Format...
CLK Rate:14000 khz
Formatting eMMC card, please wait up to 3 min...
Setting Service Mode FAILED....
eMMC Format Failed.
Done.
sandisk emmc format failed mr Blang anything wrong from my side?
Old 12-09-2016, 15:47   #24 (permalink)
trashed's Avatar
Member: 8303
Thanks Meter: 127
hi,
is it possible to add support for iphones? storage space upgrading to be exact. copying contents from old nand to new nand with auto-adjust resizing?
The Following User Says Thank You to trashed For This Useful Post:
Old 12-09-2016, 16:53   #25 (permalink)
Member: 1569669
Thanks Meter: 245
Done.
CLK Rate:14000 khz
Retry Fail!
Retry Fail!
Retry Fail!
Retry Fail!
Retry Fail!
Done.
CLK Rate:14000 khz
eMMC Format Failed.
Done.
Hi,
eMMC name SDM032 means not connected VCC or eMMC dead.
Universal Factory format can't repair dead eMMC !
Universal Factory format for eMMC 4.41 and higher revision can only erase ROM1.
Universal Factory format for older eMMC revision (like eMMC 4.2) can erase ROM1, ROM2, ROM3, RPMB and clean WP.
Best Regards
Old 12-09-2016, 20:03   #26 (permalink)
Member: 1725706
Thanks Meter: 188
Very nice this update
Mr blang pleas add claer log in emmc tool tab
Thanks br.masoud salamat
The Following User Says Thank You to ISFAHAN_GSM1 For This Useful Post:
Old 12-09-2016, 20:10   #27 (permalink)
Member: 2167320
Sonork: hoangnhupr
Best solutions update ! I can't write and read gp1 on asus , when i can i read it on my asus brother board ?
When i change new emmc on my asus , i can't find gp1 partitions, i think z3 emmc team can update next time, same ufi for easy change emmc
Old 12-09-2016, 20:18   #28 (permalink)
Multi-COM's Avatar
Member: 43823
Sonork: 100.79167
Thanks Meter: 296
Originally Posted by trashed View Post
hi,
Z3x not support NAND protocol and it's not possible due hardware limitations (completely different protocol than eMMC or even boundary scan aka JTAG)
Old 12-10-2016, 06:01   #29 (permalink)
Member: 2336297
Sonork: akashkakon
Thanks Meter: 23
Thanks Z3x Team..
Old 12-10-2016, 07:38   #30 (permalink)
alamtelecom458's Avatar
Member: 2006027
Sonork: 1645658
Thanks Meter: 27
Hy Z3x team very good update but add Samsung J700F haynix emmc full suport
Thanks
The Following User Says Thank You to alamtelecom458 For This Useful Post:
Page generated in 0.40083 seconds with 7 queries
