03-20-2021, 06:49 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: GOOD
Member: 388862 Status: Offline Thanks Meter: 107 | eMMC Device can fix ????? Loading eMMC GEN2 Firmware... IO: 2800 mV Initial pull results: clock: 1503mV pin connected ok command: 1501mV pin connected ok data0: 1501mV pin connected ok data1: 1501mV pin connected ok data2: 1502mV pin connected ok data3: 1501mV pin connected ok data4: 1501mV pin connected ok data5: 1500mV pin connected ok data6: 1499mV pin connected ok data7: 1500mV pin connected ok Box S/N: 5B0DF49404C29B41, ,FW Ver.: 02.53 Box IO Level:2800 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is ON! ---------- eMMC Device Information ---------- eMMC CID : 02000053444D30333290FFFFFFFF29BD eMMC CSD : 8C0F002A015981E9B6D9FC1F8A4040AB eMMC Manufacturer ID: 0002 , OEM ID: 0000 eMMC Date: 02/2006 Rev.0x90 eMMC NAME: SDM032 , S/N: 4294967295 eMMC NAME (HEX): 53444D303332 EMMC ROM1 (Main User Data) Capacity: 30 MB EMMC ROM2 (Boot Partition 1) Capacity: 0 kB EMMC ROM3 (Boot Partition 2) Capacity: 0 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x08] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x02 , width 8bits , Partition config [179]: 0x08. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x01 --------------------------------------------- Backup saved: SDM032_4294967295_20210320_1344.extcsd Partition info not found Done. |
