Old 11-18-2018, 14:44   #1 (permalink)
Member: 6769
Thanks Meter: 6
emmc 221 no need cahnge cid
hi all
the samsunge emmc 221 no need cid change
easy jtag plus z3x adapter
see log
EMMC Device Information :
EMMC CID: 150100514531334D420D750E90548403
EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D
EMMC Manufacture : SAMSUNG , EMMC NAME: QE13MB , HEX: 514531334D42 , S/N: 750E9054 , rev. 0x0D
EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 8/2017
EMMC ROM 1 (Main User Data) Capacity: 14910 MB (0003A3E00000)
EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000)
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
Extended CSD Information :
Extended CSD rev: 1.8 (MMC 5.1)
Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1)
Boot Bus Config: 0x00 , width 1bit
H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled
Supported partition features [PARTITIONING_SUPPORT]: 0x07
Device supports partitioning features
Device can have enhanced technological features in partitions and user data area
Device can have extended partitions attribute
Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: QE13MB_750E9054_20181118_154231.extcsd
EMMC Init completed.
Repairing eMMC CID...
Success! Now Reconnect all eMMC Lines [POWER, CMD, CLK, DAT0] to finalize CID Patch !
Running:SAMSUNG: CID patch...
Writing CID!
Checking security ...
Skip loading eMMC Addon Firmware
Box IO Level:2800 mV
CLK Rate:42000 kHz
Success!
after re connect the cid no change what this problem
The Following User Says Thank You to sedeco For This Useful Post:
Old 11-18-2018, 17:17   #2 (permalink)
Member: 818380
Thanks Meter: 56
Originally Posted by sedeco View Post
hi all
see log
Writing CID!
CLK Rate:42000 kHz
Success!
emmc 5.0 and newer this time no way to patch cid or update fw
The Following User Says Thank You to duythangvn For This Useful Post:
Old 11-19-2018, 10:09   #3 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
hi all
see log
eMMC 5.1 does not allow to change CID
The Following 4 Users Say Thank You to layder For This Useful Post:
Old 11-19-2018, 10:13   #4 (permalink)
Member: 6769
Thanks Meter: 6
so can i change cid in preloader file and how can do this
Old 11-19-2018, 10:26   #5 (permalink)
Member: 818380
Thanks Meter: 56
if your device dont use sign preloader, you can try another preloader same cpu from another devices.
Old 11-19-2018, 10:31   #6 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
You can't easy change CID at preloader. It's no work
Youi need to find pleloader from another phone with you CID for you CPU, and use it, if phone not use sing firmware
The Following 5 Users Say Thank You to layder For This Useful Post:
Old 11-19-2018, 10:35   #7 (permalink)
Member: 6769
Thanks Meter: 6
the device is huawei cun-l21
Old 11-19-2018, 11:08   #8 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
Device with SEC loader - you need find eMMC with CID from preloader.
The Following 3 Users Say Thank You to layder For This Useful Post:
Old 11-19-2018, 11:16   #9 (permalink)
Member: 6769
Thanks Meter: 6
thanks my dear why all time Norton remove the jtag plus file
Old 11-19-2018, 12:19   #10 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
update you Norton virus database. or use another Antivirus software
The Following User Says Thank You to layder For This Useful Post:
Old 12-24-2018, 10:25   #11 (permalink)
Member: 1906979
Sonork: 100.1681049
Thanks Meter: 162
hi all
see log
Writing CID!
CLK Rate:42000 kHz
Success!
easy jtag cant do this for now. other device can do.
Old 12-24-2018, 12:25   #12 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
Post logs, please. Where is eMMC 5.1 CID changed
Old 12-24-2018, 15:08   #13 (permalink)
Member: 1906979
Sonork: 100.1681049
Thanks Meter: 162
easy jtag also cant change 1.7 5.0
Old 12-24-2018, 17:40   #14 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
most eMMC with Extended CSD rev: 1.7 (MMC 5.0) is allow to eMMC CID change (for Samsung eMMC)
please provide proof of your words:
I want it.
commands that are sent to eMMC is not change since eMMC rev 4.41.
New eMMC rev 5.1 doesn't allow it
The Following 2 Users Say Thank You to layder For This Useful Post:
Old 12-31-2018, 15:14   #15 (permalink)
Member: 1906979
Sonork: 100.1681049
Thanks Meter: 162
I want it.
sure, wait for logs.
The Following User Says Thank You to KE6SOLTI For This Useful Post:
Page generated in 0.23352 seconds with 8 queries
