11-18-2018, 14:44 | #1 (permalink) |
Freak Poster Join Date: Oct 2001
Member: 6769 Status: Offline Thanks Meter: 6 | emmc 221 no need cahnge cid the samsunge emmc 221 no need cid change easy jtag plus z3x adapter see log EMMC Device Information : EMMC CID: 150100514531334D420D750E90548403 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: QE13MB , HEX: 514531334D42 , S/N: 750E9054 , rev. 0x0D EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 8/2017 EMMC ROM 1 (Main User Data) Capacity: 14910 MB (0003A3E00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QE13MB_750E9054_20181118_154231.extcsd EMMC Init completed. Repairing eMMC CID... Success! Now Reconnect all eMMC Lines [POWER, CMD, CLK, DAT0] to finalize CID Patch ! ---------------------------------------------------- Running:SAMSUNG: CID patch... Writing CID! Checking security ... Skip loading eMMC Addon Firmware Box IO Level:2800 mV CLK Rate:42000 kHz Repairing eMMC CID... Success! Now Reconnect all eMMC Lines [POWER, CMD, CLK, DAT0] to finalize CID Patch ! after re connect the cid no change what this problem Last edited by sedeco; 11-18-2018 at 14:53. |
The Following User Says Thank You to sedeco For This Useful Post: |
11-18-2018, 17:17 | #2 (permalink) | |
Freak Poster Join Date: Jul 2008
Member: 818380 Status: Offline Thanks Meter: 56 | Quote:
The Following User Says Thank You to duythangvn For This Useful Post: |
12-24-2018, 10:25 | #11 (permalink) | |
No Life Poster Join Date: Mar 2013 Location: Nepal Age: 41
Member: 1906979 Status: Offline Sonork: 100.1681049 Thanks Meter: 162 | Quote:
12-24-2018, 17:40 | #14 (permalink) |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | most eMMC with Extended CSD rev: 1.7 (MMC 5.0) is allow to eMMC CID change (for Samsung eMMC) please provide proof of your words: I want it. commands that are sent to eMMC is not change since eMMC rev 4.41. New eMMC rev 5.1 doesn't allow it Last edited by layder; 12-24-2018 at 17:45. |
The Following 2 Users Say Thank You to layder For This Useful Post: |
