Old 11-19-2016, 23:10   #1 (permalink)
dazexy's Avatar
Member: 13569
Sonork: 1619596
Thanks Meter: 72
Emmc cloning question
Dear supporters!
I like to ask a question.
Is it possible to replace a faulty EMMC (hynix 8gb write protect) with a (used samsung 8GB working) ? I mean can I remove working emmc from other phone and write (ROM1,2,3 and EXTCSD) from the WP EMMC?? Will this work?
Many thanks for help!
Dazexy
Old 11-20-2016, 07:38   #2 (permalink)
Jani-Jan's Avatar
Member: 19737
Thanks Meter: 133
Yes its possible.. Simply mach boot configuration and boot sizes etc
The Following User Says Thank You to Jani-Jan For This Useful Post:
Old 11-20-2016, 16:08   #3 (permalink)
dazexy's Avatar
Member: 13569
Sonork: 1619596
Thanks Meter: 72
Are there some tutorial or similar? I made size changes, write rom1,2,3 installed emmc but not success. Any place, post or something to learn how to use this feature?
The Following User Says Thank You to dazexy For This Useful Post:
Old 11-20-2016, 18:12   #4 (permalink)
BABAK NURI's Avatar
Member: 131131
Sonork: 100.1606847
Thanks Meter: 4,475
Hi
1-What is your phone model?
2-What is exact part number of WP eMMC?
3-What is exact part number of new samsung eMMC?
The Following User Says Thank You to BABAK NURI For This Useful Post:
Old 11-20-2016, 18:48   #5 (permalink)
dazexy's Avatar
Member: 13569
Sonork: 1619596
Thanks Meter: 72
Originally Posted by BABAK NURI View Post
Hi
- opendott W032i-c3, (intel, tab, not phone)
- SKhynix
H26M42003GMB
e-NAND 324A
- SAMSUNG
KLM8G4DEDD-A101
thanx for helping!!!
dazexy
Old 11-23-2016, 19:53   #6 (permalink)
BABAK NURI's Avatar
Member: 131131
Sonork: 100.1606847
Thanks Meter: 4,475
Hi
i think you can use :
SDIN7DU2-8GB
SDIN7DP2-8GB
KLM8G2FE3B-B001
also you can use exactly part number from some huawei phone like H30-u10 or G750-Uxx
Old 11-23-2016, 21:27   #7 (permalink)
dazexy's Avatar
Member: 13569
Sonork: 1619596
Thanks Meter: 72
Hi
SDIN7DU2-8GB
SDIN7DP2-8GB
KLM8G2FE3B-B001
Thanks for suggestion.
One more complex question. It's enough to make erase used emmc, than make rom1,2,3,rpmb same size than original emmc, than write Rom1,2,3? Or need to change emmc card CID to same as original was?
Old 11-23-2016, 21:37   #8 (permalink)
Jani-Jan's Avatar
Member: 19737
Thanks Meter: 133
I think no need change cid..
Old 11-24-2016, 09:04   #9 (permalink)
BABAK NURI's Avatar
Member: 131131
Sonork: 100.1606847
Thanks Meter: 4,475
It's complected..somtimes you need ,somtimes no need
some cpu need rom2 or 3 ,some cpu need only rom1
have different rules
The Following 3 Users Say Thank You to BABAK NURI For This Useful Post:
Old 11-25-2016, 16:00   #10 (permalink)
Member: 1675290
Thanks Meter: 177
Dear supporters!
Dazexy
if you can read old emmc data .... you can used it to write new emmc example old emmc klm8g ( 8gb emmc ) you can write to new klm8g klmag klmbg 8/16/32 gb or if you have kmvtu kmv3w kmv2w (emcp 16/32 or higher ) you can write it also . and your phone will alive like old phone no data erase or missing
and the backup can also repair another phone with same type ... but usually there a problem security so after another phone alive it need to repair imei
Old 11-25-2016, 16:22   #11 (permalink)
Member: 1675290
Thanks Meter: 177
it is not complex at all ... yes you can use used emmc you you can erase and write the extcsd/rom2-3/rom1 .... except MTK cpu the preloader contain emmc support data ,,, so you must patch / rename cid to emmc that support to the preloader
The Following 3 Users Say Thank You to bagus.dps For This Useful Post:
Old 11-25-2016, 16:42   #12 (permalink)
Member: 1675290
Thanks Meter: 177
i guess you missing the basic emmc
1. ext_csd contain confiq and boot size etc
2. rom2 rom 3 contain boot file
3. rom1 user area data
some times it contain rpmb and gp1
first to write is extcsd to make config and partition
second is boot1/2
third rpmb/gp1
last and must at last is userarea
you must write step by step
problem is you must read those data from normal phone to make repair file
this example emmc contain gp1
i use ufi box but the proses is similar cause i use easyjtag before (direct emmc)
Old 11-25-2016, 18:00   #13 (permalink)
dazexy's Avatar
Member: 13569
Sonork: 1619596
Thanks Meter: 72
Many thanks for information for ALL!
But i have one question about MTK CID patching. Why need it to patch cid, when CM2MTK can bypass HW identification at firmware writing? Is there any other connection between CID and preloader in FW?
many thanx
dazexy
Old 11-25-2016, 19:35   #14 (permalink)
Member: 1168670
Thanks Meter: 20
hello excuse me
are this log of ufi box ?
Old 11-26-2016, 07:51   #15 (permalink)
Member: 1675290
Thanks Meter: 177
many thanx
dazexy
preloader contain emmc cid - emmc confiq - data partition , writing wrong preloader will cause phone death.... , cid only identity of emmc .
writing with bypass security or hw identity will caused death phone . you can use bin file of cm 2/miracle chinese box ... but you must sure its from same type of phone
The Following 2 Users Say Thank You to bagus.dps For This Useful Post:
Page generated in 0.23066 seconds with 8 queries
