11-19-2016, 23:10 | #1 (permalink) |
No Life Poster Join Date: Jul 2002 Location: Hungary, Győr Age: 46
Member: 13569 Status: Offline Sonork: 1619596 Thanks Meter: 72 | Emmc cloning question I like to ask a question. Is it possible to replace a faulty EMMC (hynix 8gb write protect) with a (used samsung 8GB working) ? I mean can I remove working emmc from other phone and write (ROM1,2,3 and EXTCSD) from the WP EMMC?? Will this work? Many thanks for help! Dazexy |
11-20-2016, 16:08 | #3 (permalink) |
Member: 13569 Status: Offline Sonork: 1619596 Thanks Meter: 72 | Are there some tutorial or similar? I made size changes, write rom1,2,3 installed emmc but not success. Any place, post or something to learn how to use this feature? |
The Following User Says Thank You to dazexy For This Useful Post: |
11-20-2016, 18:12 | #4 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi 1-What is your phone model? 2-What is exact part number of WP eMMC? 3-What is exact part number of new samsung eMMC? |
The Following User Says Thank You to BABAK NURI For This Useful Post: |
11-23-2016, 19:53 | #6 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi i think you can use : SDIN7DU2-8GB SDIN7DP2-8GB KLM8G2FE3B-B001 also you can use exactly part number from some huawei phone like H30-u10 or G750-Uxx |
11-23-2016, 21:27 | #7 (permalink) | |
Member: 13569 Status: Offline Sonork: 1619596 Thanks Meter: 72 | Quote:
One more complex question. It's enough to make erase used emmc, than make rom1,2,3,rpmb same size than original emmc, than write Rom1,2,3? Or need to change emmc card CID to same as original was? | |
11-24-2016, 09:04 | #9 (permalink) | |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Quote:
some cpu need rom2 or 3 ,some cpu need only rom1 have different rules | |
The Following 3 Users Say Thank You to BABAK NURI For This Useful Post: |
11-25-2016, 16:00 | #10 (permalink) | |
Freak Poster Join Date: Oct 2011 Location: uf1 b0x land
Member: 1675290 Status: Offline Thanks Meter: 177 | Quote:
and the backup can also repair another phone with same type ... but usually there a problem security so after another phone alive it need to repair imei | |
11-25-2016, 16:22 | #11 (permalink) | |
The Following 3 Users Say Thank You to bagus.dps For This Useful Post: |
11-25-2016, 16:42 | #12 (permalink) | |
1. ext_csd contain confiq and boot size etc 2. rom2 rom 3 contain boot file 3. rom1 user area data some times it contain rpmb and gp1 first to write is extcsd to make config and partition second is boot1/2 third rpmb/gp1 last and must at last is userarea you must write step by step problem is you must read those data from normal phone to make repair file this example emmc contain gp1 i use ufi box but the proses is similar cause i use easyjtag before (direct emmc) | |
11-25-2016, 18:00 | #13 (permalink) |
Member: 13569 Status: Offline Sonork: 1619596 Thanks Meter: 72 | Many thanks for information for ALL! But i have one question about MTK CID patching. Why need it to patch cid, when CM2MTK can bypass HW identification at firmware writing? Is there any other connection between CID and preloader in FW? many thanx dazexy |
11-25-2016, 19:35 | #14 (permalink) | |
Insane Poster Join Date: Nov 2009 Location: iran .. sari
Member: 1168670 Status: Offline Thanks Meter: 20 | Quote:
hello excuse me are this log of ufi box ? | |
11-26-2016, 07:51 | #15 (permalink) | |
writing with bypass security or hw identity will caused death phone . you can use bin file of cm 2/miracle chinese box ... but you must sure its from same type of phone | |
The Following 2 Users Say Thank You to bagus.dps For This Useful Post: |
