11-27-2016, 11:06 | #17 (permalink) | ||
No Life Poster Join Date: Jul 2002 Location: Hungary, Győr Age: 46
Member: 13569 Status: Offline Sonork: 1619596 Thanks Meter: 72 | Here is the original card: Quote:
So i think i need use a virgin card? Am I right? dazexy | ||
11-27-2016, 17:52 | #18 (permalink) | |
Freak Poster Join Date: Oct 2011 Location: uf1 b0x land
Member: 1675290 Status: Offline Thanks Meter: 177 | Quote:
just write your back up >>> Backup saved: H8G2d _ 5495392_20161127_1037.extcsd as simple as that as i see yr log has 8mb gp1 ... i guess it is asus phone ... am i allright ? | |
The Following User Says Thank You to bagus.dps For This Useful Post: |
11-27-2016, 19:13 | #19 (permalink) |
Member: 13569 Status: Offline Sonork: 1619596 Thanks Meter: 72 | Intel phone, but if I write extcsd, gp1 partition not created. And also easy jtag warns that gp positions can write only ONCE / Emmc. So I try various emmc but gp positions can't created. |
11-28-2016, 00:19 | #20 (permalink) |
Member: 1675290 Status: Offline Thanks Meter: 177 | before Selected: [SAMSUNG] moviNAND KLMAG4FEAB-B002/16GB (FBGA153) Connection status: EHCI:HUB:USB 2.00 High-speed Interface: UFI High-Speed Serial number: 0011-8179-3060 Boot version: 1.03, FW version: 1.09 (Feb 20 2016 03:47:28) Insertion test... Done. Init bus... VCC: 3.3 V, VCCQ: 2.8 V Bus: 8 bit (HS SDR 24MHz) Access mode: sector mode Power supply: dual-voltage (1.70-1.95V, 2.7-3.6V) Card/BGA: BGA (Discrete embedded) - High density MMC Manufacturer ID: 0x15 (Samsung) Product name: AFEABB (0x414645414242), rev: 0x00, serial number: 0x7A0D9B5F Manufacturing date: Mar 2013 CID: 15010041 46454142 42007A0D 9B5F30D0 CSD: D0270132 0F5903FF F6DBFFEF 8E40400C EXT_CSD revision: 1.7 (MMC v5.0, v5.01) Capacity: 14.68 GiB(15,766,913,024 bytes) Partition info: Boot1: 4096 KiB Boot2: 4096 KiB RPMB: 512 KiB User area: 14.68 GiB(15,758,000,128 bytes) Change partition size of Boot to 4096 KiB and RPMB to 4096 KiB... Done. Loading file: "\\%BACKUPS%\asus\t00f%20t00j%20zen%205\ext_csd.bi n", size: 512 bytes... Writing extcsd, 512 bytes... Done. after write extcsd Connection status: EHCI:HUB:USB 2.00 High-speed Interface: UFI High-Speed Serial number: 0011-8179-3060 Boot version: 1.03, FW version: 1.09 (Feb 20 2016 03:47:28) Insertion test... Done. Init bus... VCC: 3.3 V, VCCQ: 2.8 V Bus: 8 bit (HS SDR 52MHz) Access mode: sector mode Power supply: dual-voltage (1.70-1.95V, 2.7-3.6V) Card/BGA: BGA (Discrete embedded) - High density MMC Manufacturer ID: 0x15 (Samsung) Product name: AFEABB (0x414645414242), rev: 0x00, serial number: 0x7A0D9B5F Manufacturing date: Mar 2013 CID: 15010041 46454142 42007A0D 9B5F30D0 CSD: D0270132 0F5903FF F6DBFFEF 8E40400C EXT_CSD revision: 1.7 (MMC v5.0, v5.01) Capacity: 14.67 GiB(15,753,805,824 bytes) Partition info: Boot1: 4096 KiB Boot2: 4096 KiB RPMB: 4096 KiB User area: 14.66 GiB(15,741,222,912 bytes) GP1: 8 MiB (enhanced) Cache size: 64 MiB Hardware reset function: 1 Partition configuration: 0x00 No boot acknowledge is sent (default) Device is not boot-enabled (default) Partitioning support: 0x07 Device support partitioning feature Device can have enhanced technological features Device partitioning completed Boot configuration protection: 0x00 Boot bus conditions: 0x06 Bus width: x8 (sdr/ddr), boot mode: sdr(default), retain bus width and boot mode Boot area write protection: 0x00 Power-on write protection: possible Permanent write protection: possible Lock status: not locked User area write protection: 0x50 Password protection features: enabled Power-on write protection: possible Permanent write protection: not possible Lock status: not locked Selected: [SAMSUNG] moviNAND KLMAG4FEAB-B002/16GB (FBGA153) intel asus t00f 8 gb repair by klmag4 16 gb |
11-28-2016, 00:31 | #21 (permalink) |
Member: 1675290 Status: Offline Thanks Meter: 177 | not matter is new or 2nd emmc .. for samsung emmc you can make it new by update emmc firmware or use TP then update emmc firmware . your emmc ready to re use |
11-28-2016, 21:06 | #22 (permalink) | |
Member: 13569 Status: Offline Sonork: 1619596 Thanks Meter: 72 | Quote:
dazexy | |
The Following User Says Thank You to dazexy For This Useful Post: |
02-09-2021, 10:42 | #23 (permalink) |
Junior Member Join Date: Dec 2008
Member: 930285 Status: Offline Thanks Meter: 0 | VCC: 3.3 V, VCCQ: 3.0 V Bus: 8 bit (SDR 52MHz) Access mode: sector mode Power supply: dual-voltage (1.70-1.95V, 2.7-3.6V) Card/BGA: Card (removable) - High density MMC Manufacturer ID: 0x65 (Unknown) Product name: MMOR (0x4d204d4f5212), rev: 0x90, serial number: 0x00000726 Manufacturing date: May 2021 CID: 65646F4D 204D4F52 12900000 0726581E Bad CID detected, eMMC might be damaged !!! CSD: D0FFFF32 0F5903FF FFFFFFE7 964000EA EXT_CSD revision: 1.5 (MMC v4.41) Partition info: Boot1: 2048 KiB Boot2: 2048 KiB RPMB: 128 KiB User area: 7.22 GiB(7,752,122,368 bytes) Partition configuration: 0x78 Boot acknowledge is sent during the boot operation User area is enabled for boot Partitioning support: 0x03 Device support partitioning feature |
