EMMC dead after auto firmware update Hello,
heres log Code:
EasyJtag Suite Classic ver.: 3.0.0.0 / wxWidgets 3.1.0-W-U started.
OS ver.: Windows 10 (build 16299), 64-bit edition. Admin rights FAIL
Android Explorer ver:1.0.0.13
Autorun Agent ver:1.0.0.0
Crash Reporting ver:1.4.0.3
eMMC Odin ver:1.0.0.6
QUALCOMM Direct ver:1.0.6671.7138
Android ADB API ver:2.0.0.0
FTDI API ver:3.2.4.0
LibUSB API ver:1.2.6.0
Visual C++ Runtime ver:10.0.30319.1
Setting box Pinout ...
Вы используете самые свежие драйвера: 3.0.0.0 .
Z3X Card Activation [JTAGPLUS] : NOT ACTIVATED
Z3X Card Activation [LG] : NOT ACTIVATED
Z3X Card Activation [SAMS] : ACTIVATED
Z3X Card Activation [JTAG] : ACTIVATED
Found 3 serial devices
COM1 ACPI\VEN_PNP&DEV_0501 Последовательный порт (COM1)
COM3 FTDIBUS\COMPORT&VID_0403&PID_6001 USB Serial Port (COM3)
COM5 USB\VID_0325&PID_0032&REV_0100&MI_00 Easy Jtag Control Port (COM5)
Selected pinout: EasyJTAG GEN1 ISP Pinout
Change EasyJTAG Pinout OK
Compression is ON
Z3X EasyJtag Software ver. 3.0.0.0
Loading eMMC GEN1 Firmware... IO: 3300 mV
FW Ver.: 01.63
Напряжение подтяжки линии CMD :3155 mV
Напряжение активной линии CMD :3248 mV
Box IO Level:3300 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
HiPower mode is off!
---------- eMMC Device Information ----------
eMMC CID : 15010056335730304D00081F643630F2
eMMC CSD : D02701320F5903FFF6DBFFFF8E40406C
eMMC Manufacturer ID: 0015 , OEM ID: 0100
eMMC Date: 03/2013 Rev.0x0
eMMC NAME: V3W00M , S/N: 136274998
eMMC NAME (HEX): 56335730304D
IC Name: Samsung , KMV3W000LM-B310/16GB @FBGA153
EMMC ROM1 (Main User Data) Capacity: 15028 MB
EMMC ROM2 (Boot Раздел 1) Емкость: 4096 kB
EMMC ROM3 (Boot Раздел 2) Емкость: 4096 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
EMMC Password Locked: No
Extended CSD rev 1.6 (MMC 4.5)
Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1)
Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48.
H/W reset function [RST_N_FUNCTION]: 0x00
High-capacity WP group size [HC_WP_GRP_SIZE: 0x00014000]
Partitioning Support [PARTITIONING_SUPPORT]: 0x07
Device support partitioning feature
Device can have enhanced tech.
Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: V3W00M_ 136274998_20181022_1817.extcsd
Partition table scan:
GPT: present
Found valid GPT with protective MBR; using GPT.
Real (Hardware) Disk/Image size: 1D5A000 sectors 14.7 GiB
Soft (Partitioned) Disk/Image size: 1D59FBC sectors 14.7 GiB
Logical sector size: 0x200 bytes
Disk identifier (GUID): 52444E41-494F-2044-4D4D-43204449534B
First usable sector: 34
Last usable sector: 30777310
Found Data areas (firmware parts) count is: 21
Partition info successfully found
P0 (BOTA0) [0x400000 0x400000] Size: 4.0MB
P1 (BOTA1) [0x800000 0x400000] Size: 4.0MB
P2 (EFS) [0xc00000 0x1400000] Size: 20.0MB
P3 (M9KEFS1) [0x2000000 0x400000] Size: 4.0MB
P4 (M9KEFS2) [0x2400000 0x400000] Size: 4.0MB
P5 (M9KEFS3) [0x2800000 0x400000] Size: 4.0MB
P6 (CARRIER) [0x2c00000 0x1400000] Size: 20.0MB
P7 (PARAM) [0x4000000 0x800000] Size: 8.0MB
P8 (BOOT) [0x4800000 0x800000] Size: 8.0MB
P9 (RECOVERY) [0x5000000 0x800000] Size: 8.0MB
P10 (OTA) [0x5800000 0x800000] Size: 8.0MB
P11 (CDMA-RADIO) [0x6000000 0x800000] Size: 8.0MB
P12 (RADIO) [0x6800000 0x5800000] Size: 88.0MB
P13 (TOMBSTONES) [0xc000000 0x10000000] Size: 256.0MB
P14 (TDATA) [0x1c000000 0x400000] Size: 4.0MB
P15 (HIDDEN) [0x1c400000 0x23000000] Size: 560.0MB
P16 (PERSDATA) [0x3f400000 0xc00000] Size: 12.0MB
P17 (RESERVED2) [0x40000000 0x400000] Size: 4.0MB
P18 (CACHE) [0x40400000 0x81800000] Size: 2.23GB
P19 (SYSTEM) [0xc1c00000 0xacc00000] Size: 2.699GB
P20 (USERDATA) [0x16e800000 0x23c800000] Size: 8.945GB
------ Android information ------
Detected LINUX(Android) SYSTEM : 0x00C1C00000 (2.699GB)
Build ID: KOT49H
Display Build ID: KOT49H.I9500XXUGNH4
Release ID: 4.4.2
Device Model: GT-I9500
Device Name: ja3gxx
Architecture ABI: armeabi-v7a
Device manufacturer: samsung
Device Platform: exynos5
Product ID: ja3g
Build Description: ja3gxx-user 4.4.2 KOT49H I9500XXUGNH4 release-keys
Samsung CPU: exynos5410
Сделано.
Running:SAMSUNG: eMMC firmware update...
Init OK...
EMMC NAME: V3W00M
EMMC Part Number: KMV3W000LM-B310
Auto FW file for IC: A:\_CellPhone_\EASYJTAG\eMMC Firmware\KMV3W000LM-B310.bin
Skip loading eMMC Addon Firmware
FW Ver.: 01.63
CLK Rate:21000 kHz
Using firmware file : A:\_CellPhone_\EASYJTAG\eMMC Firmware\KMV3W000LM-B310.bin
Firmware EP Offset:00040000
Update Firmware ID Hash:2566E2653982B5EA43D01D43EF568086
Setup firmware update mode, wait 2..30 sec...
Success!
Sending eMMC firmware...
Success!
Flashing eMMC firmware...
Success!
Repairing eMMC CID...
Now Reconnect all eMMC Lines [POWER, CMD, CLK, DAT0]!
Do it until progress bar is moving (20 sec timeout)!
Can't init device, Reason: OCR Ready Timeout Error [Check VCC or eMMC DEAD]
Сделано.
Compression is ON
FW Ver.: 01.63
Напряжение подтяжки линии CMD :3165 mV
Напряжение активной линии CMD :3269 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
Сделано.
Compression is ON
FW Ver.: 01.63
Напряжение активной линии CMD :3258 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
Сделано.
Compression is ON
FW Ver.: 01.63
CLK Rate:21000 kHz
Bus Width:1bit,SDR
Can't init device, Reason: CMD Timeout Error
Сделано.
Compression is ON
FW Ver.: 01.63
CLK Rate:21000 kHz
Bus Width:1bit,SDR
Сделано.
so what is happened, why system didnt ask for my choice of firmware. Now emmc even didnt recognize, what i supposed to to? |
