Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Easy-Jtag
Old 11-23-2018, 15:59   #646 (permalink)
Member: 1034504
How to update my Z3X pro
Old 11-23-2018, 16:55   #647 (permalink)
Member: 1034504
Help me ser....i neet pinout samsung Note N910H
Old 11-27-2018, 19:45   #648 (permalink)
Member: 2705090
Hi, I have to recover user data from An emmc chip Toshiba thgbmag8a4jba4r from LG D955, i use medusabox, i can see the partition but when i go to content extractor it is showing no userdata. Please help
Old 11-28-2018, 09:25   #649 (permalink)
sheraziking110's Avatar
Member: 2486822
Sonork: 100.1659206
Thanks Meter: 67
Q mobile z9 emmc pinout need
Old 12-13-2018, 10:43   #650 (permalink)
Member: 1831621
mga sir master jan na nag jjtag ask ko lang po pag natanggalan siya ng isang resistor pwede pa po ba siya ma jaytag like yung CMD,DATA,CLK...sana may makatulong po at makasagot maraming salamat po
Old 12-13-2018, 10:43   #651 (permalink)
Member: 1831621
Old 12-13-2018, 10:45   #652 (permalink)
Member: 1831621
Easy jtag
Old 12-14-2018, 15:27   #653 (permalink)
Member: 405194
hi I need Meizu M2 Note pinout please help
Old 12-22-2018, 03:36   #654 (permalink)
Mobile_Control's Avatar
Member: 998119
Thanks Meter: 54
SM-j810F/DS isp pinout. hi z3x team
22.12.2018 11:56:05> EMMC Информация :
22.12.2018 11:56:05> EMMC CID: 150100475836424D42006356DEE4651B
22.12.2018 11:56:05> EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D
22.12.2018 11:56:05> EMMC Производитель : SAMSUNG , EMMC Имя: GX6BMB , HEX: 475836424D42 , S/N: 6356DEE4 , rev. 0x00
22.12.2018 11:56:05> EMMC Производитель ID: 0x15 , OEM ID: 0x00 , Тип устройства: BGA (Discrete embedded) , Дата: 6/2018
22.12.2018 11:56:05> EMMC ROM 1 (Данные пользователя) Объем: 29820 MB (000747C00000)
22.12.2018 11:56:05> EMMC ROM 2/3 (Загрузочный раздел 1/2) Объем: 4096 KB (000000400000)
22.12.2018 11:56:05> eMMC RPMB (защищенный блок данных): емкость: 16384 KB (000001000000)
22.12.2018 11:56:05> EMMC Постоянная защита записи: Нет
22.12.2018 11:56:05> EMMC Временная защита записи: Нет
22.12.2018 11:56:05> Extended CSD информация :
22.12.2018 11:56:05> Extended CSD ревизия: 1.8 (MMC 5.1)
22.12.2018 11:56:05> Конфигурация загрузки [PARTITION_CONFIG]: 0x38 , Загрузка из: ROM1 (Раздел пользователя)
22.12.2018 11:56:05> Boot Bus Config: 0x00 , width 1bit
22.12.2018 11:56:05> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n сигнал постоянно включен
22.12.2018 11:56:05> Поддержка управления разделами [PARTITIONING_SUPPORT]: 0x07
22.12.2018 11:56:05> Устройство поддерживает функции разбиения
22.12.2018 11:56:05> Устройство может иметь расширенные технологические возможности в разделах и области пользовательских данных
22.12.2018 11:56:05> Устройство может иметь атрибуты расширенных разделов
22.12.2018 11:56:05> Свойства раздела [PARTITION_SETTING_COMPLETED]: 0x00
22.12.2018 11:56:05> Бэкап сохранён: GX6BMB_6356DEE4_20181222_115605.extcsd
The Following User Says Thank You to Mobile_Control For This Useful Post:
Old 12-22-2018, 08:41   #655 (permalink)
rico_deep's Avatar
Member: 159757
Thanks Meter: 439
can not write firmware via vendor no supported yet
Old 12-23-2018, 09:49   #656 (permalink)
Member: 998119
Thanks Meter: 54
J330F isp
Setting interface to EasyJtag2/E-Socket
Setting bus width to 4 Bit
Setting frequence to 42 Mhz
EMMC Device Information :
EMMC CID: 150100514536334D4200C450CCCC5447
EMMC Manufacture : SAMSUNG , EMMC NAME: QE63MB , HEX: 514536334D42 , S/N: C450CCCC , rev. 0x00
EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 5/2017
EMMC ROM 1 (Main User Data) Capacity: 15028 MB (0003AB400000)
EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000)
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
Extended CSD Information :
Extended CSD rev: 1.8 (MMC 5.1)
Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1)
Boot Bus Config: 0x01 , width 4bit
H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled
Supported partition features [PARTITIONING_SUPPORT]: 0x07
Device supports partitioning features
Device can have enhanced technological features in partitions and user data area
Device can have extended partitions attribute
Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: QE63MB_C450CCCC_20181223_190517.extcsd
EMMC Init completed.
Get firmware version
Brand = samsung
Manufacturer = samsung
Model = SM-J330F
Phone platform = exynos5
CPU Abi = armeabi-v7a
Android release = 7.0
Firmware version = NRD90M.J330FXXU3ARC5
Firmware date = Tue Mar 27 08:59:57 KST 2018
Old 12-23-2018, 09:51   #657 (permalink)
Member: 2747373
Alcatel 3c 5026d full dump need
Boot dead alcatel 3c 5026d full dump need help
Old 12-24-2018, 08:41   #658 (permalink)
Member: 2884745
eMMC Pinouts Motorola G5s Plus
I need schematic of the moto g5s points eMMC soldering.
The steps as steps of the conection and on/off power.
thanks
Old 12-29-2018, 11:46   #659 (permalink)
Member: 2333062
Sonork: 100.1671476
Thanks Meter: 4
a700l .zbin file6.0.1wanted badlyor a700l emmc pinout .plz any one have these file
Old 12-30-2018, 09:26   #660 (permalink)
Member: 1630066
Sonork: 520074
Thanks Meter: 178
Sm-g720n0 isp pinouts tested BY CHAND MOBILES
The Following User Says Thank You to ilyasrao For This Useful Post:
Page generated in 0.25054 seconds with 8 queries
