Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Easy-Jtag
Old 03-24-2019, 19:17   #676 (permalink)
Member: 2901369
htc_pmewl htc 10 emmc pinout and help needed for dead repair thanks
Old 03-26-2019, 14:15   #677 (permalink)
Mobile_Control's Avatar
Member: 998119
Thanks Meter: 54
need emmc isp meizu M6
Old 03-28-2019, 09:28   #678 (permalink)
Member: 883886
Sonork: 1664059
Thanks Meter: 97
Cool HUAWEI_P8_Lite_(PRA-LA1)_emmc_direct_pinout working
https://www.4shared.com/photo/jauAzS...A1__emmc_.html
Tested Report.....
3/27/2019 8:36:11 PM>
Looking for EasyJTAG box...
EasyJTAG API ver. 2201
Setting IO Levels to 1.8V
Setting frequence to 21 Mhz
EasyJTAG Box Serial = 10007022E9040C38
EasyJTAG Box Firmware = 1.63
CMD Pullup Level: 1753 mV
CMD Active Level: 1753 mV
eMMC Init returned = 0
EMMC Device Information :
EMMC CID: 150100524531424D420DD2ED6818140A
EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C
EMMC Manufacture : SAMSUNG , EMMC NAME: RE1BMB , HEX: 524531424D42 , S/N: D2ED6818 , rev. 0x0D
EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 1/2017
EMMC ROM 1 (Main User Data) Capacity: 14910 MB (0003A3E00000)
EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000)
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
Extended CSD Information :
Extended CSD rev: 1.8 (MMC 5.1)
Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1)
Boot Bus Config: 0x02 , width 8bit
H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled
Supported partition features [PARTITIONING_SUPPORT]: 0x07
Device supports partitioning features
Device can have enhanced technological features in partitions and user data area
Device can have extended partitions attribute
Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: RE1BMB_D2ED6818_20190327_203613.extcsd
EMMC Init completed.
The Following User Says Thank You to mransar For This Useful Post:
Old 04-30-2019, 02:30   #679 (permalink)
Member: 1978538
Has anyone got the pinout for the HTC Desire 650
Old 05-03-2019, 18:04   #680 (permalink)
Member: 2764406
Thanks Meter: 3
that's very helpful, thanks men i can very clear see all what you mentioned
Old 05-21-2019, 14:04   #681 (permalink)
Member: 504048
hello
any one have pinout for j510 ??
Old 06-07-2019, 02:01   #682 (permalink)
Member: 2911011
thanks for the good images very usefull.
BR,
Old 07-18-2019, 15:34   #683 (permalink)
Member: 797019
Thanks Meter: 22
plase pinout samsung A750G
Old 07-23-2019, 21:29   #684 (permalink)
Member: 975554
Thanks Meter: 51
need lgmp450 emmc pinout
Old 07-27-2019, 22:12   #685 (permalink)
Crazy Poster
Member: 2104824
Thanks Meter: 17
HTC One M9PLUS- OPK7110
---------- eMMC Device Information ----------
eMMC CID : 15010042474E44335201B2D9B677421E
eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C
eMMC Manufacturer ID: 0015 , OEM ID: 0100
eMMC Date: 04/2015 Rev.0x1
eMMC NAME: BGND3R , S/N: 3000612471
eMMC NAME (HEX): 42474E443352
IC Name: Samsung , KLMBG4GEND-B031/32GB @FBGA153
EMMC ROM1 (Main User Data) Capacity: 29820 MB
EMMC ROM2 (Boot Раздел 1) Емкость: 4096 kB
EMMC ROM3 (Boot Раздел 2) Емкость: 4096 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB
EMMC RPMB is programmed and written 0 times
EMMC Password Locked: No
Extended CSD rev 1.7 (MMC 5.0)
Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1)
Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x48.
H/W reset function [RST_N_FUNCTION]: 0x01
High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000]
Partitioning Support [PARTITIONING_SUPPORT]: 0x07
Device support partitioning feature
Device can have enhanced tech.
Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: BGND3R_3000612471_20190727_2142.extcsd
Caution: invalid backup GPT header, but valid main header!
Warning! Main and backup partition tables differ!n
Warning! One or more CRCs don't match. You should repair the disk!
Partition table scan:
GPT: damaged
Caution: Found protective or hybrid MBR and corrupt GPT.
Real (Hardware) Disk/Image size: 3A3E000 sectors 29.1 GiB
Soft (Partitioned) Disk/Image size: 3A337FF sectors 29.1 GiB
Logical sector size: 0x200 bytes
Disk identifier (GUID): 00000000-0000-0000-0000-000000000000
First usable sector: 1024
Last usable sector: 61029375
Partition info successfully found
Found Data areas (firmware parts) count is: 44
P0 (PROINFO) [0x80000 0x300000] Size: 3.0MB
P1 (NVRAM) [0x380000 0x500000] Size: 5.0MB
P2 (PROTECT1) [0x880000 0xa00000] Size: 10.0MB
P3 (PROTECT2) [0x1280000 0xa00000] Size: 10.0MB
P4 (PERSIST) [0x1c80000 0x3000000] Size: 48.0MB
P5 (KB) [0x4c80000 0x100000] Size: 1.0MB
P6 (DKB) [0x4d80000 0x100000] Size: 1.0MB
P7 (SECCFG) [0x4e80000 0x40000] Size: 256.0KB
P8 (PG1FS) [0x4ec0000 0x400000] Size: 4.0MB
P9 (RESERVE1) [0x52c0000 0xd40000] Size: 13.250MB
P10 (PG2FS) [0x6000000 0x1000000] Size: 16.0MB
P11 (LK) [0x7000000 0x100000] Size: 1.0MB
P12 (SECRO) [0x7100000 0x600000] Size: 6.0MB
P13 (PARA) [0x7700000 0x80000] Size: 512.0KB
P14 (LOGO) [0x7780000 0x800000] Size: 8.0MB
P15 (FRP) [0x7f80000 0x80000] Size: 512.0KB
P16 (HOSD) [0x8000000 0x2000000] Size: 32.0MB
P17 (HTCSEC) [0xa000000 0x100000] Size: 1.0MB
P18 (TOOL_DIAG) [0xa100000 0xa00000] Size: 10.0MB
P19 (RESERVE2) [0xab00000 0x1500000] Size: 21.0MB
P20 (FATALDEVLOG) [0xc000000 0x1400000] Size: 20.0MB
P21 (DEVLOG) [0xd400000 0x1400000] Size: 20.0MB
P22 (EXPDB) [0xe800000 0xa00000] Size: 10.0MB
P23 (TEE1) [0xf200000 0x500000] Size: 5.0MB
P24 (TEE2) [0xf700000 0x500000] Size: 5.0MB
P25 (METADATA) [0xfc00000 0x2000000] Size: 32.0MB
P26 (LKBACKUP) [0x11c00000 0x100000] Size: 1.0MB
P27 (OTAFW) [0x11d00000 0x4000000] Size: 64.0MB
P28 (SENSOR_HUB) [0x15d00000 0x80000] Size: 512.0KB
P29 (CIR_IMG) [0x15d80000 0x8000] Size: 32.0KB
P30 (CARRIER) [0x15d88000 0x1400000] Size: 20.0MB
P31 (CONTROL) [0x17188000 0x8000] Size: 32.0KB
P32 (BATTERY) [0x17190000 0xa00000] Size: 10.0MB
P33 (APPPRELOAD) [0x17b90000 0x12200000] Size: 290.0MB
P34 (COTA) [0x29d90000 0x3c00000] Size: 60.0MB
P35 (EXTRA) [0x2d990000 0x10000] Size: 64.0KB
P36 (ANDINFO) [0x2d9a0000 0x8000] Size: 32.0KB
P37 (RESERVE) [0x2d9a8000 0x658000] Size: 6.343MB
P38 (CACHE) [0x2e000000 0x14000000] Size: 320.0MB
P39 (BOOT) [0x42000000 0x2000000] Size: 32.0MB
P40 (RECOVERY) [0x44000000 0x2000000] Size: 32.0MB
P41 (SYSTEM) [0x46000000 0x127000000] Size: 4.609GB
P42 (USERDATA) [0x16d000000 0x5d8800000] Size: 23.382GB
P43 (FLASHINFO) [0x745800000 0x1000000] Size: 16.0MB
------ Android information ------
Detected LINUX(Android) SYSTEM : 0x0046000000 (4.609GB)
Device Model: HTC One M9PLUS
Build ID: MRA58K
Display Build ID: MRA58K release-keys
Release Incremental ID: 821792.1
Release Base ID: 6.0
Device Model: htc_hiau_ml_tuhl
Device Name: hiau_ml_tuhl_htc_europe
Architecture ABI: arm64-v8a
Device manufacturer: HTC
Device Platform: mt6795
I hope this time do not remove my hologram
Old 08-27-2019, 10:34   #686 (permalink)
Member: 2013385
Sonork: 100.1646109
I need XT1602 emmc pinout ???
Old 09-02-2019, 15:05   #687 (permalink)
Member: 744052
Sonork: john
Thanks Meter: 4
thank you bro for sharing........................................... .....
Old 09-03-2019, 02:11   #688 (permalink)
Member: 744052
Sonork: john
Thanks Meter: 4
samsung j100
sir samsung j100 pinout.. thanks
Old 09-12-2019, 23:09   #689 (permalink)
Member: 2842853
honor 8 pro pinout emmc scandisk scandisk SDINADFA4-64G
Old 09-17-2019, 22:24   #690 (permalink)
Member: 2014671
Thanks Meter: 13
Hello.
Please share pinout for Samsung A50 (SM-A505G / SM-A505F)
I know that riffbox has that pinout but I do not own it. I only have Medusa and Easy Jtag.
Page generated in 0.18843 seconds with 8 queries
