09-09-2017, 21:41 | #1 (permalink) |
Product Supporter Join Date: Mar 2013 Location: JTAG/eMMC/UFS
Member: 1902789 Status: Offline Thanks Meter: 1,100 | 'eMMC Dump' Read Done From SAMSUNG SM-G316HU Galaxy S DUOS 3 - By Easy Jtag EasyJTAG API ver. 2008 Setting IO Levels to 1.8V Setting frequence to 21 Mhz HiPower mode is OFF OpenUSB returned = 0 Power Controller returned = 0 EasyJTAG Box Serial = XXXXXXXXXXXXXXX EasyJTAG Box Firmware = 01.60 HiPower mode is OFF Frequence: 21 Mhz CMD Pullup Level: 1753 mV CMD Active Level: 1773 mV eMMC Init returned = 0 EMMC Device Information : EMMC CID: 90014A48344732621101F9292651B1C0 EMMC CSD: D07F01320F5903FFFFFFFFEF8A4040DA EMMC Manufacture Name: SKHYNIX EMMC Manufacture ID: 0x90 , OEM ID: 014A EMMC Manufacture Date: 11/2014 , Rev: 01 EMMC NAME: H4G2b , S/N: F9292651 , rev. 01 EMMC NAME (HEX): 483447326211 EMMC ROM 1 (Main User Data) Capacity: 3728 MB (0000E9000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.6 (MMC 4.5, MMC 4.51) Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: H4G2b_F9292651_20170909_222234.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: SBOOT, [000000400000 - 000000600000], size: 000000200000 Partition: SBOOT2, [000000600000 - 000000800000], size: 000000200000 Partition: wfixnv1, [000000800000 - 000000900000], size: 000000100000 Partition: wfixnv2, [000000900000 - 000000A00000], size: 000000100000 Partition: tdfixnv2, [000000B00000 - 000000C00000], size: 000000100000 WDSP, [000000C00000 - 000001000000], size: 000000400000 MODEM, [000001000000 - 000001800000], size: 000000800000 MODEM2, [000001800000 - 000002000000], size: 000000800000 TDDSP, [000002000000 - 000002400000], size: 000000400000 FOTA_SIG, [000002400000 - 000002500000], size: 000000100000 wruntimenv1, [000002500000 - 000002600000], size: 000000100000 wruntimenv2, [000002600000 - 000002700000], size: 000000100000 tdruntimenv1, [000002700000 - 000002800000], size: 000000100000 tdruntimenv2, [000002800000 - 000002900000], size: 000000100000 PARAM, [000002900000 - 000002B00000], size: 000000200000 efs, [000002B00000 - 000003F00000], size: 000001400000 prodnv, [000003F00000 - 000004400000], size: 000000500000 RESERVED2, [000004400000 - 000004500000], size: 000000100000 KERNEL, [000004500000 - 000005500000], size: 000001000000 RECOVERY, [000005500000 - 000006500000], size: 000001000000 CSC, [000006500000 - 000012D00000], size: 00000C800000 Partition: system, [000012D00000 - 00005DD00000], size: 00004B000000 Partition: HIDDEN, [00005DD00000 - 000065D00000], size: 000008000000 Partition: userdata, [000065D00000 - 0000E8100000], size: 000082400000 GPT header successfully parsed Get firmware version Brand = samsung Model = SM-G316HU CPU Abi = armeabi-v7a Firmware version = KTU84P.G316HUDDU0AOE2 Firmware date = Tue May 19 20:15:28 KST 2015 Looking for EasyJTAG box... EasyJTAG API ver. 2008 Setting IO Levels to 1.8V Setting frequence to 21 Mhz HiPower mode is OFF OpenUSB returned = 0 Power Controller returned = 0 EasyJTAG Box Serial = XXXXXXXXXXXXXXX EasyJTAG Box Firmware = 01.60 HiPower mode is OFF Frequence: 21 Mhz CMD Active Level: 1794 mV eMMC Init returned = 0 EMMC Device Information : EMMC CID: 90014A48344732621101F9292651B1C0 EMMC CSD: D07F01320F5903FFFFFFFFEF8A4040DA EMMC Manufacture Name: SKHYNIX EMMC Manufacture ID: 0x90 , OEM ID: 014A EMMC Manufacture Date: 11/2014 , Rev: 01 EMMC NAME: H4G2b , S/N: F9292651 , rev. 01 EMMC NAME (HEX): 483447326211 EMMC ROM 1 (Main User Data) Capacity: 3728 MB (0000E9000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.6 (MMC 4.5, MMC 4.51) Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: H4G2b_F9292651_20170909_222349.extcsd EMMC Init completed. Reading from: ROM1 , start: 0x000000000000 , size: 0x000040000000 Output file: C:\Users\BABU\Desktop\New folder (2)\EMMC_H4G2b_ROM1_000000000000_000040000000.bin eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 1025.47 Kb/s Reading from: ROM2 , start: 0x000000000000 , size: 0x000000400000 Output file: C:\Users\BABU\Desktop\New folder (2)\EMMC_H4G2b_ROM2_000000000000_000000400000.bin eMMC switching to ROM2 Reading partition... Done reading partition. Read speed: 1403.58 Kb/s Reading from: ROM3 , start: 0x000000000000 , size: 0x000000400000 Output file: C:\Users\BABU\Desktop\New folder (2)\EMMC_H4G2b_ROM3_000000000000_000000400000.bin eMMC switching to ROM3 Reading partition... Done reading partition. Read speed: 1405.05 Kb/s Here is Video Link... https://www.youtube.com/watch?v=R1yyc52jGQg ( 1 small Request to every viewers Please Like, Share My Videos & Subscribe My Channel ) |
The Following 3 Users Say Thank You to Pijush Das For This Useful Post: |
