02-10-2014, 14:02 | #1 (permalink) |
Freak Poster Join Date: Aug 2013 Location: Kepler22 Age: 46
Member: 2014892 Status: Offline Sonork: 100.1646397 Thanks Meter: 5 | emmc factory reset ok but nand format failed Successfully connected to box on COM64 Box S/N: 0E0E0F1880619087, ,FW Ver.: 01.48 Loading eMMC Addon Firmware... CMD Pullup Level:1990 mV CMD Active Level:2062 mV EMMC CID 15010056545530304DF154645B748F8F EMMC CSD D02701320F5903FFF6DBFFFF8E40406D EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 08/2012 FW rev.0xf1 EMMC NAME: VTU00M , S/N: 1415863156 EMMC ROM1 (Main User Data) Capacity: 15028 MB (High Density Card) EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. Backup saved: VTU00M_1415863156_20140101_1451.extcsd Sending Internal Reconfiguration Request... Waiting configuration Apply!!! eMMC ACK Error !! |
02-11-2014, 09:44 | #3 (permalink) |
Member: 2014892 Status: Offline Sonork: 100.1646397 Thanks Meter: 5 | now tried to write and it failed.its damaged i guess. Successfully connected to box on COM64 Box S/N: 0E0E0F1880619087, ,FW Ver.: 01.48 Loading eMMC Addon Firmware... CMD Pullup Level:1990 mV CMD Active Level:2072 mV EMMC CID 15010056545530304DF154645B748F8F EMMC CSD D02701320F5903FFF6DBFFFF8E40406D EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 08/2012 FW rev.0xf1 EMMC NAME: VTU00M , S/N: 1415863156 EMMC ROM1 (Main User Data) Capacity: 15028 MB (High Density Card) EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. Writing 000000200000 bytes to 00000000 ...ROM2 Retry writing adress 0x00000000 Retry writing adress 0x00000000 Retry writing adress 0x00000000 Retry writing adress 0x00000000 |
02-11-2014, 15:49 | #4 (permalink) |
Member: 2014892 Status: Offline Sonork: 100.1646397 Thanks Meter: 5 | another emmc,again detected and factory reset ok but nand format failed.is it because of bad box hw or voltage? Successfully connected to box on COM64 Box S/N: 0E0E0F1880619087, ,FW Ver.: 01.48 Loading eMMC Addon Firmware... CMD Pullup Level:1949 mV CMD Active Level:2041 mV EMMC CID 15010056545530304DF16EDD58E85FE1 EMMC CSD D02701320F5903FFF6DBFFFF8E40406D EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 05/2012 FW rev.0xf1 EMMC NAME: VTU00M , S/N: 1859999976 EMMC ROM1 (Main User Data) Capacity: 15028 MB (High Density Card) EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. Backup saved: VTU00M_1859999976_20140102_1640.extcsd Sending Internal Reconfiguration Request... Waiting configuration Apply!!! eMMC ACK Error !!! |
02-24-2014, 08:23 | #5 (permalink) |
No Life Poster Join Date: Aug 2006 Location: Always Here Age: 37
Member: 333494 Status: Offline Sonork: 100.1607053 Thanks Meter: 190 | hi i have the same problem i can red and write but not format http://forum.gsmhosting.com/vbb/f672.../#post10119094 |
