09-06-2018, 19:39 | #1 (permalink) |
Moderator Join Date: Jan 2008 Location: <jeddah al saudia> Age: 36
Member: 668050 Status: Offline Sonork: 100.1656307 Thanks Meter: 991 | EMMC i9500 KMV3W000LM-B310 NOT SUPPORTED ---------------------------------------------------------- ---------- eMMC Device Information ---------- eMMC CID : 15010056335730304D003C0015C05088 eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 05/2013 Rev.0x0 eMMC NAME: V3W00M , S/N: 1006638528 eMMC NAME (HEX): 56335730304D IC Name: Samsung , KMV3W000LM-B310/16GB @FBGA153 EMMC ROM1 (Main User Data) Capacity: 15028 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 512 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.7 (MMC 5.0) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: V3W00M_1006638528_20180906_2125.extcsd Done. Running:SAMSUNG: eMMC firmware update... Init OK... EMMC NAME: V3W00M EMMC Part Number: KMV3W000LM-B310 Auto FW file for IC: C:\Program Files\Z3X\EASYJTAG\eMMC Firmware\KMV3W000LM-B310.bin Z3X EasyJtag Software ver. 3.1.0.0 Skip loading eMMC Addon Firmware Box S/N: 1201401CBB19DC97, ,FW Ver.: 01.63 CMD Pullup Level:1990 mV CMD Active Level:2145 mV Box IO Level:2800 mV CLK Rate:21000 kHz Using firmware file : C:\Program Files\Z3X\EASYJTAG\eMMC Firmware\KMV3W000LM-B310.bin Firmware EP Offset:00040000 Update Firmware ID Hash:2566E2653982B5EA43D01D43EF568086 Setup firmware update mode, wait 2..30 sec... Success! Sending eMMC firmware... Success! Flashing eMMC firmware... Success! Repairing eMMC CID... Now Reconnect all eMMC Lines [POWER, CMD, CLK, DAT0]! Do it until progress bar is moving (20 sec timeout)! Can't init device, Reason: OCR Ready Timeout Error [Check VCC or eMMC DEAD] Done. --------------------------------------------------------------------- with ATF its working ----------------------- 21:29:04 : ================================================== ==== 21:29:04 : Loading ATF eMMC Firmware File... (Please Wait) 21:29:04 : ================================================== ==== 21:29:04 : 21:29:07 : 21:29:09 : File Author: ATF Team @ X-Shadow 21:29:09 : Date Created: 23/04/2015 (dd/mm/yyyy) 21:29:09 : Description: Samsung eMMC Firmware 21:29:09 : eMMC Part Number: KMV3W000LM-B310 21:29:09 : eMMC Product Name: V3W00M 21:29:09 : eMMC Product Rev: 0.0 21:29:09 : 21:29:09 : Preparing eMMC for Firmware Update... 21:29:17 : Sending eMMC Firmware Blocks... 21:29:20 : All Blocks Sent! 21:29:20 : NAND Write Delay: 1 Second (Please Wait) 21:29:21 : Applying eMMC Firmware Update... 21:29:21 : Waiting for Device Re-Initialization... 21:29:21 : Firmware Write Protect Delay: 1 Second (Please Wait) 21:29:22 : Checking eMMC Firmware Update Status... 21:29:32 : eMMC Firmware Update Successful! 21:29:32 : |
