HELLO
I HAVE BAD EMMC SANDISK 64GB ... MUST BE CHANGED
BUT I HAVE ONLY SAMSUNG 16GB
I CANT RESIZE DATA GPT0 PARTITON
EMMC CSD : D02701320F5903FFF6DBFFFF8E40406C
EMMC Manufacturer ID: 0015 , OEM ID: 0100
EMMC Date: 08/2012 Rev.0xF1
EMMC NAME: VTU00M , S/N: 3998493603
EMMC NAME (HEX): 56545530304D00
EMMC ROM1 (Main User Data) Capacity: 15028 MB
EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB
EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 512 kB
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
EMMC Password Locked: No
Extended CSD rev 1.6 (MMC 4.5)
Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured.
Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x00.
H/W reset function [RST_N_FUNCTION]: 0x00
High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000]
Partitioning Support [PARTITIONING_SUPPORT]: 0x07
Device support partitioning feature
Device can have enhanced tech.
Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: VTU00M_3998493603_20171025_1004.extcsd
Warning! Disk size is smaller than the main header indicates! Loading
Caution: invalid backup GPT header, but valid main header!
Warning! Main and backup partition tables differ!n
Warning! One or more CRCs don't match. You should repair the disk!
Partition table scan:
GPT: damaged
Caution: Found protective or hybrid MBR and corrupt GPT.
Real (Hardware) Disk/Image size: 1D5A000 sectors 14.7 GiB
Soft (Partitioned) Disk/Image size: 747BFBC sectors 58.2 GiB
Logical sector size: 0x200 bytes
Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20
First usable sector: 34
Last usable sector: 122142686
Found Data areas (firmware parts) count is: 54
Partition info successfully found
P0 (MODEM) [0x800000 0x5600000] Size: 86.0MB
P1 (SPARE1) [0x5e00000 0x200000] Size: 2.0MB
P2 (PMIC) [0x6000000 0x80000] Size: 512.0KB
P3 (SBL1) [0x6080000 0x100000] Size: 1.0MB
P4 (TZ) [0x6180000 0x100000] Size: 1.0MB
P5 (SDI) [0x6280000 0x80000] Size: 512.0KB
P6 (HYP) [0x6300000 0x80000] Size: 512.0KB
P7 (RPM) [0x6380000 0x80000] Size: 512.0KB
P8 (ABOOT) [0x6400000 0x200000] Size: 2.0MB
P9 (SBL1BAK) [0x6600000 0x100000] Size: 1.0MB
P10 (PMICBAK) [0x6700000 0x80000] Size: 512.0KB
P11 (HYPBAK) [0x6780000 0x80000] Size: 512.0KB
P12 (TZBAK) [0x6800000 0x100000] Size: 1.0MB
P13 (RPMBAK) [0x6900000 0x80000] Size: 512.0KB
P14 (ABOOTBAK) [0x6980000 0x200000] Size: 2.0MB
P15 (SDIBAK) [0x6b80000 0x80000] Size: 512.0KB
P16 (LIMITS) [0x6c00000 0x80000] Size: 512.0KB
P17 (APDP) [0x6c80000 0x80000] Size: 512.0KB
P18 (MSADP) [0x6d00000 0x80000] Size: 512.0KB
P19 (DPO) [0x6d80000 0x80000] Size: 512.0KB
P20 (SPARE2) [0x6e00000 0x200000] Size: 2.0MB
P21 (PERSISTENT) [0x7000000 0x80000] Size: 512.0KB
P22 (DEVINFO) [0x7080000 0x100000] Size: 1.0MB
P23 (SPARE3) [0x7180000 0x680000] Size: 6.500MB
P24 (MISC) [0x7800000 0x1000000] Size: 16.0MB
P25 (PERSIST) [0x8800000 0x2000000] Size: 32.0MB
P26 (MODEMST1) [0xa800000 0x180000] Size: 1.500MB
P27 (MODEMST2) [0xa980000 0x180000] Size: 1.500MB
P28 (FSG) [0xab00000 0x180000] Size: 1.500MB
P29 (FSC) [0xac80000 0x80000] Size: 512.0KB
P30 (SSD) [0xad00000 0x80000] Size: 512.0KB
P31 (KEYSTORE) [0xad80000 0x80000] Size: 512.0KB
P32 (DDR) [0xae00000 0x200000] Size: 2.0MB
P33 (SEC) [0xb000000 0x80000] Size: 512.0KB
P34 (ENCRYPT) [0xb080000 0x80000] Size: 512.0KB
P35 (EKSST) [0xb100000 0x80000] Size: 512.0KB
P36 (RCT) [0xb180000 0x80000] Size: 512.0KB
P37 (SPARE4) [0xb200000 0x600000] Size: 6.0MB
P38 (LAF) [0xb800000 0x3000000] Size: 48.0MB
P39 (BOOT) [0xe800000 0x2800000] Size: 40.0MB
P40 (RECOVERY) [0x11000000 0x2800000] Size: 40.0MB
P41 (DRM) [0x13800000 0xa00000] Size: 10.0MB
P42 (SNS) [0x14200000 0x600000] Size: 6.0MB
P43 (MPT) [0x14800000 0x2000000] Size: 32.0MB
P44 (RAW_RESOURCES) [0x16800000 0x400000] Size: 4.0MB
P45 (RAW_RESOURCESBAK) [0x16c00000 0x400000] Size: 4.0MB
P46 (FACTORY) [0x17000000 0x2e00000] Size: 46.0MB
P47 (SPARE5) [0x19e00000 0x200000] Size: 2.0MB
P48 (FOTA) [0x1a000000 0xa00000] Size: 10.0MB
P49 (FAU) [0x1aa00000 0xe00000] Size: 14.0MB
P50 (SYSTEM) [0x1b800000 0x10bc00000] Size: 4.183GB
P51 (CACHE) [0x127400000 0x4d000000] Size: 1.203GB
P52 (USERDATA) [0x174400000 0xd1b300000] Size: 52.424GB
P53 (GROW) [0xe8f700000 0xfbe00] Size: 1007.500KB
------ Android information ------
Detected LINUX(Android) SYSTEM : 0x001B800000 (4.183GB)
Unable to mount SYSTEM , code : 95
Done.
ITS POSSIBLE TO PUT THIS EMMC 16GB ?
