02-23-2014, 12:40 | #1 (permalink) |
Freak Poster Join Date: Feb 2013
Member: 1891184 Status: Offline Thanks Meter: 3 | pinout can not found error i am new user and i also new box....you can see on the image... first when i try to repair the dead boot then i got the error "Done with errors" then i try to find out the pin....but i got error "pinout can not found" i read on the forum about the connection of some pins i am using here riff box pcb...please check on the image.. and tell me which pin number i need to join. if there is another solution then please guide me.. here the pin 2,17,19 are free pin 4.6.8.10.12.14.16.18.20 are grounds pin -3 is TRST pin- 5 is TD1 pin- 7 is TMS pin-9 is TCK pin-11 is RTCK pin-13 is TD0 pin-15 is NRST i hope i will get the answer soon... |
02-24-2014, 18:46 | #3 (permalink) |
Member: 1891184 Status: Offline Thanks Meter: 3 | i also try the jtag adapter and try to connect the i9100...but still same error ... done with error after connection.... before of this is was trying on i9100G... i am waiting answer from the product supporter ...... |
