04-08-2019, 13:58 | #1 (permalink) |
Junior Member Join Date: Nov 2009
Member: 1167736 Status: Offline Sonork: c080413e Thanks Meter: 5 | Problem running interface EasyJTAG Plus i have problem in EasyJTAG Plus Not working on win10 bit 32 bit 64 But it works on win 7 Possible solution to the problem |
04-08-2019, 15:03 | #2 (permalink) | |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | Quote:
you need more detailiase of you problem to get help from us i work with box at win 10 x64 more, when 2 years | |
The Following User Says Thank You to layder For This Useful Post: |
04-08-2019, 16:31 | #3 (permalink) | |
Member: 1167736 Status: Offline Sonork: c080413e Thanks Meter: 5 | Quote:
I'm working on this release easyjtag_emmc_plus_1.5.3.0 the box Works on Windows 7 100% But on Windows all bit does not work And what data are required of me? But the latest version of EasyJtag_Release_v3.4.RC5 Works 100% on the same Windows 10 | |
04-08-2019, 20:42 | #4 (permalink) | |
screenshot of drivers at device manager, screenshot of plus software error | |
04-09-2019, 16:10 | #6 (permalink) |
Member: 13148 Status: Offline Thanks Meter: 2,948 | try to tempory disable RIM Virtual Serial ports and Find USB-EasyJTAG HiSpeed device, change view - Select "Device by connection", search JTAG Com port, and change EasyJTAG COM number to COM2 |
03-18-2020, 20:38 | #9 (permalink) |
Member: 13148 Status: Offline Thanks Meter: 2,948 | try use admin rights I use EasyJTAG Plus software at win10x64 3-4 year and all work or ask ofаicial supporter - mr. Blang |
03-19-2020, 12:51 | #10 (permalink) |
No Life Poster Join Date: Apr 2012
Member: 1743727 Status: Offline Thanks Meter: 76 | even i found no problem with easy jteg and i m using win10 64 bit also but u can face problem if u installed wrong drivers and if u have v1 box (personally experience when i have v1 box ) |
03-30-2020, 17:59 | #11 (permalink) |
Junior Member Join Date: Aug 2018 Location: Polska
Member: 2861727 Status: Offline Thanks Meter: 1 | You must disable Driver Signature Verification on 64-Bit Windows 8 or 10 So That You Can Install Unsigned Drivers, don't forget to install the drivers manually later. |
10-05-2020, 13:37 | #13 (permalink) |
Junior Member Join Date: Jan 2018
Member: 2803904 Status: Offline Thanks Meter: 0 | easyjtag plus is not running at windows 10 help easyjtag is working fine at windows 10 but plus is not working. i have also windows 8.1 installed another pc, there is no any problem with windows 8.1. |
